GlobalIlluminationVct Class Reference
Enable and configure Global Illumination using VCT (Voxel Cone Tracing) More...
#include <GlobalIlluminationVct.hh>
Signals
void DebugVisualizationModeChanged ()
 Notify debug visualization has changed.
void EnabledChanged ()
 Notify this property has changed.
void LightingChanged ()
 Notify fast-to-rebuild properties may have changed.
void SettingsChanged ()
 Notify various properties may have changed.
 GlobalIlluminationVct ()
 ~GlobalIlluminationVct () override
Q_INVOKABLE bool Anisotropic () const
 See rendering::GlobalIlluminationVct::Anisotropic.
Q_INVOKABLE uint32_t BounceCount () const
 See rendering::GlobalIlluminationVct::BounceCount.
Q_INVOKABLE bool ConserveMemory () const
 See rendering::GlobalIlluminationVct::ConserveMemory.
Q_INVOKABLE uint32_t DebugVisualizationMode () const
 See rendering::GlobalIlluminationVct::DebugVisualizationMode.
Q_INVOKABLE bool Enabled () const
 See rendering::GlobalIlluminationVct::Enabled.
Q_INVOKABLE bool HighQuality () const
 See rendering::GlobalIlluminationVct::HighQuality.
bool LoadGlobalIlluminationVct ()
 Load the scene and attach LidarVisual to the scene.
Q_INVOKABLE uint32_t OctantCountX () const
 See rendering::GlobalIlluminationVct::OctantCount.
Q_INVOKABLE uint32_t OctantCountY () const
Q_INVOKABLE uint32_t OctantCountZ () const
Q_INVOKABLE uint32_t ResolutionX () const
 See rendering::GlobalIlluminationVct::Resolution.
Q_INVOKABLE uint32_t ResolutionY () const
Q_INVOKABLE uint32_t ResolutionZ () const
Q_INVOKABLE void SetAnisotropic (const bool _anisotropic)
 See rendering::GlobalIlluminationVct::SetAnisotropic.
Q_INVOKABLE void SetBounceCount (const uint32_t _bounces)
 See rendering::GlobalIlluminationVct::SetBounceCount.
Q_INVOKABLE void SetConserveMemory (const bool _conserveMemory)
 See rendering::GlobalIlluminationVct::SetConserveMemory.
Q_INVOKABLE void SetDebugVisualizationMode (const uint32_t _visMode)
 See rendering::GlobalIlluminationVct::SetDebugVisualizationMode.
Q_INVOKABLE void SetEnabled (const bool _enabled)
 See rendering::GlobalIlluminationVct::SetEnabled & rendering::Scene::SetActiveGlobalIllumination.
Q_INVOKABLE void SetHighQuality (const bool _quality)
 See rendering::GlobalIlluminationVct::SetHighQuality.
Q_INVOKABLE void SetOctantCountX (const uint32_t _octantCount)
 See rendering::GlobalIlluminationVct::SetOctantCount.
Q_INVOKABLE void SetOctantCountY (const uint32_t _octantCount)
Q_INVOKABLE void SetOctantCountZ (const uint32_t _octantCount)
Q_INVOKABLE void SetResolutionX (const uint32_t _res)
 See rendering::GlobalIlluminationVct::SetResolution.
Q_INVOKABLE void SetResolutionY (const uint32_t _res)
Q_INVOKABLE void SetResolutionZ (const uint32_t _res)
Q_INVOKABLE void SetThinWallCounter (const float _thinWallCounter)
 See rendering::GlobalIlluminationVct::SetThinWallCounter.
Q_INVOKABLE float ThinWallCounter () const
 See rendering::GlobalIlluminationVct::ThinWallCounter.
Q_INVOKABLE void UpdateDebugVisualizationMode (int _mode)
 Set debug visualization mode GlogbalIllumination.
Q_INVOKABLE void UpdateOctantCount (int _axis, uint32_t _count)
 Set VCT octant count.
Q_INVOKABLE void UpdateResolution (int _axis, uint32_t _res)
 Set VCT resolution.
- Public Member Functions inherited from GuiSystem
virtual void Update (const UpdateInfo &_info, EntityComponentManager &_ecm)
Properties
bool anisotropic
int bounceCount
bool conserveMemory
int debugVisualizationMode
bool enabled
 Enabled QML binding. Anything that isn't GUI-only (i.e. affects simulation) needs it.
bool highQuality
int octantCountX
int octantCountY
int octantCountZ
int resolutionX
int resolutionY
int resolutionZ
float thinWallCounter
Due to how QML bindings work, we must split Vectors into each component so e.g. the following Javascript code:
cascade.resolutionX = 16 cascade.resolutionY = 32 cascade.resolutionZ = 64
Will end up calling:
cascade->SetResolutionX(16); cascade->SetResolutionY(32); cascade->SetResolutionZ(64);
Even though in C++ we would normally do resolution = {16, 32, 64}; The same goes for each property.
◆ GlobalIlluminationVct()
◆ ~GlobalIlluminationVct()
~GlobalIlluminationVct ( )
◆ Anisotropic()
Q_INVOKABLE bool Anisotropic ( ) const
◆ BounceCount()
Q_INVOKABLE uint32_t BounceCount ( ) const
◆ ConserveMemory()
Q_INVOKABLE bool ConserveMemory ( ) const
◆ DebugVisualizationMode()
Q_INVOKABLE uint32_t DebugVisualizationMode ( ) const
◆ DebugVisualizationModeChanged
void DebugVisualizationModeChanged ( )
signal
◆ Enabled()
Q_INVOKABLE bool Enabled ( ) const
◆ EnabledChanged
void EnabledChanged ( )
signal
◆ eventFilter()
QEvent *  _event
◆ HighQuality()
Q_INVOKABLE bool HighQuality ( ) const
◆ LightingChanged
void LightingChanged ( )
signal
◆ LoadConfig()
◆ LoadGlobalIlluminationVct()
bool LoadGlobalIlluminationVct ( )
True if GI VCT is loaded successfully, false otherwise.
◆ OctantCountX()
Q_INVOKABLE uint32_t OctantCountX ( ) const
◆ OctantCountY()
Q_INVOKABLE uint32_t OctantCountY ( ) const
◆ OctantCountZ()
Q_INVOKABLE uint32_t OctantCountZ ( ) const
◆ ResolutionX()
Q_INVOKABLE uint32_t ResolutionX ( ) const
◆ ResolutionY()
Q_INVOKABLE uint32_t ResolutionY ( ) const
◆ ResolutionZ()
Q_INVOKABLE uint32_t ResolutionZ ( ) const
◆ SetAnisotropic()
Q_INVOKABLE void SetAnisotropic ( const bool  _anisotropic)
[in]_anisotropicSee GlobalIlluminationVct::SetAnisotropic
◆ SetBounceCount()
Q_INVOKABLE void SetBounceCount ( const uint32_t  _bounces)
[in]_bouncesSee GlobalIlluminationVct::SetBounceCount
◆ SetConserveMemory()
Q_INVOKABLE void SetConserveMemory ( const bool  _conserveMemory)
[in]_conserveMemorySee GlobalIlluminationVct::SetConserveMemory
◆ SetDebugVisualizationMode()
Q_INVOKABLE void SetDebugVisualizationMode ( const uint32_t  _visMode)
[in]_visModeSee GlobalIlluminationVct::SetDebugVisualizationMode
◆ SetEnabled()
Q_INVOKABLE void SetEnabled ( const bool  _enabled)
[in]_enabledSee GlobalIlluminationVct::SetEnabled
◆ SetHighQuality()
Q_INVOKABLE void SetHighQuality ( const bool  _quality)
[in]_qualitySee GlobalIlluminationVct::SetHighQuality
◆ SetOctantCountX()
Q_INVOKABLE void SetOctantCountX ( const uint32_t  _octantCount)
[in]_octantCountSee GlobalIlluminationVct::SetOctantCount
◆ SetOctantCountY()
Q_INVOKABLE void SetOctantCountY ( const uint32_t  _octantCount)
◆ SetOctantCountZ()
Q_INVOKABLE void SetOctantCountZ ( const uint32_t  _octantCount)
◆ SetResolutionX()
Q_INVOKABLE void SetResolutionX ( const uint32_t  _res)
[in]_resSee GlobalIlluminationVct::SetResolution
◆ SetResolutionY()
Q_INVOKABLE void SetResolutionY ( const uint32_t  _res)
◆ SetResolutionZ()
Q_INVOKABLE void SetResolutionZ ( const uint32_t  _res)
◆ SetThinWallCounter()
Q_INVOKABLE void SetThinWallCounter ( const float  _thinWallCounter)
[in]_thinWallCounterSee GlobalIlluminationVct::SetThinWallCounter
◆ SettingsChanged
void SettingsChanged ( )
signal
◆ ThinWallCounter()
Q_INVOKABLE float ThinWallCounter ( ) const
◆ UpdateDebugVisualizationMode()
Q_INVOKABLE void UpdateDebugVisualizationMode ( int  _mode)
[in]_modeIndex of selected debug visualization mode
◆ UpdateOctantCount()
Q_INVOKABLE void UpdateOctantCount ( int  _axis,
uint32_t  _count
[in]_axisAxis (width, height, depth). In range [0; 3)
[in]_countNew octant count
◆ UpdateResolution()
Q_INVOKABLE void UpdateResolution ( int  _axis,
uint32_t  _res
Set VCT resolution.
[in]_resNew resolution
Property Documentation
◆ anisotropic
bool anisotropic
readwrite
◆ bounceCount
int bounceCount
readwrite
◆ conserveMemory
bool conserveMemory
readwrite
◆ debugVisualizationMode
readwrite
◆ enabled
bool enabled
readwrite
◆ highQuality
bool highQuality
readwrite
◆ octantCountX
int octantCountX
readwrite
◆ octantCountY
int octantCountY
readwrite
◆ octantCountZ
int octantCountZ
readwrite
◆ resolutionX
int resolutionX
readwrite
◆ resolutionY
int resolutionY
readwrite
◆ resolutionZ
int resolutionZ
readwrite
◆ thinWallCounter
readwrite
