Physics data plotting handler that keeps track of the registered components, update them and update the plot. More...
#include <Plotting.hh>
Public Slots
std::string ComponentName (const uint64_t &_typeId)
 Get Component Name based on its type Id.
void RegisterChartToComponent (uint64_t _entity, uint64_t _typeId, std::string _type, std::string _attribute, int _chart)
 Add a chart to a specific component attribute.
void UnRegisterChartFromComponent (uint64_t _entity, uint64_t _typeId, std::string _attribute, int _chart)
 Remove a chart from a specific component attribute.
 Plotting ()
 ~Plotting ()
void LoadConfig (const tinyxml2::XMLElement *) override
void SetData (std::string _Id, const double &_value)
 Set the Component data of given id to the given number.
void SetData (std::string _Id, const gz::math::Pose3d &_pose)
 Set the Component data of given id to the given pose.
void SetData (std::string _Id, const gz::math::Vector3d &_vector)
 Set the Component data of given id to the given vector.
void SetData (std::string _Id, const math::SphericalCoordinates &_sc)
 Set the Component data of given id to the given spherical coordinates.
void SetData (std::string _Id, const msgs::Light &_light)
 Set the Component data of given id to the given light.
void SetData (std::string _Id, const sdf::Physics &_physics)
 Set the Component data of given id to the given physics properties.
◆ Plotting()
Plotting ( )
◆ ~Plotting()
~Plotting ( )
◆ ComponentName
std::string ComponentName ( const uint64_t &  _typeId)
slot
[in]_typeIdtype Id of the component
Component name
◆ LoadConfig()
void LoadConfig ( const tinyxml2::XMLElement *  )
◆ RegisterChartToComponent
void RegisterChartToComponent ( uint64_t  _entity,
uint64_t  _typeId,
std::string  _type,
int  _chart
slot
[in]_entityentity id in the simulation
[in]_typeIdtype identifier unique to each component type
[in]_typeComponent Datatype ("Pose3d","Vector3d","double")
[in]_attributecomponent attribute to add the chart to it ex: x attribute in Pose3d Component will be "x"
[in]_chartchart ID to be registered
◆ SetData() [1/6]
void SetData ( std::string  _Id,
const double &  _value
[in]_IdComponent Key of the components map
[in]_valuedouble Data to be set to the component valid for types (double, float, int, bool)
◆ SetData() [2/6]
const gz::math::Pose3d &  _pose
[in]_posePosition Data to be set to the component
◆ SetData() [3/6]
const gz::math::Vector3d &  _vector
[in]_vectorVector Data to be set to the component
◆ SetData() [4/6]
const math::SphericalCoordinates &  _sc
[in]_scData to be set to the component
◆ SetData() [5/6]
const msgs::Light &  _light
[in]_lightVector Data to be set to the component
◆ SetData() [6/6]
const sdf::Physics &  _physics
[in]_physicsPhysics data to be set to the component
◆ UnRegisterChartFromComponent
void UnRegisterChartFromComponent ( uint64_t  _entity,
uint64_t  _typeId,
int  _chart
slot
[in]_attributecomponent attribute to remove the chart from it ex: x attribute in Pose3d Component will be "x"
[in]_chartchart ID to be unregistered
Reimplemented from GuiSystem.
