The server instantiates and controls simulation. More...
#include <gz/sim/Server.hh>
Public Types
enum class  Status { EXITED , STOPPED , RUNNING }
 Lifecycle states of the server. More...
 Server (const ServerConfig &_config=ServerConfig())
 Construct the server using the parameters specified in a ServerConfig.
 ~Server ()
std::optional< bool > AddSystem (const sdf::Plugin &_plugin, std::optional< Entity > _entity, const unsigned int _worldIndex=0)
 Add a System to the server. The server must not be running when calling this.
std::optional< bool > AddSystem (const std::shared_ptr< System > &_system, const unsigned int _worldIndex=0)
std::optional< bool > AddSystem (const std::shared_ptr< System > &_system, std::optional< Entity > _entity, std::optional< std::shared_ptr< const sdf::Element > > _sdf, const unsigned int _worldIndex=0)
std::optional< bool > AddSystem (const SystemPluginPtr &_system, const unsigned int _worldIndex=0)
std::optional< bool > AddSystem (const SystemPluginPtr &_system, std::optional< Entity > _entity, std::optional< std::shared_ptr< const sdf::Element > > _sdf, const unsigned int _worldIndex=0)
std::optional< Entity > EntityByName (const std::string &_name, const unsigned int _worldIndex=0) const
 Get an Entity based on a name.
std::optional< size_t > EntityCount (const unsigned int _worldIndex=0) const
 Get the number of entities on the server.
Status GetStatus () const
 Get the current lifecycle status of the server.
bool HasEntity (const std::string &_name, const unsigned int _worldIndex=0) const
 Return true if the specified world has an entity with the provided name.
std::optional< uint64_t > IterationCount (const unsigned int _worldIndex=0) const
 Get the number of iterations the server has executed.
std::optional< bool > Paused (const unsigned int _worldIndex=0) const
 Get whether a world simulation instance is paused. When paused is true, then simulation for the world is not stepping forward.
bool RequestRemoveEntity (const Entity _entity, bool _recursive=true, const unsigned int _worldIndex=0)
 Return true if the specified world has an entity with the provided id and the entity was queued for deletion. Note that the entity is not removed immediately. Entity deletion happens at the end of the next (or current depending on when this function is called) simulation step.
bool RequestRemoveEntity (const std::string &_name, bool _recursive=true, const unsigned int _worldIndex=0)
 Return true if the specified world has an entity with the provided name and the entity was queued for deletion. Note that the entity is not removed immediately. Entity deletion happens at the end of the next (or current depending on when this function is called) simulation step.
bool Reset (const std::size_t _runnerId)
 Reset a specific runner in this server.
void ResetAll ()
 Reset all runners in this simulation.
bool Run (const bool _blocking=false, const uint64_t _iterations=0, const bool _paused=true)
 Run the server. By default this is a non-blocking call, which means the server runs simulation in a separate thread. Pass in true to the _blocking argument to run the server in the current thread.
bool Running () const
 Get whether the server is running. The server can have zero or more simulation worlds, each of which may or may not be running. See Running(const unsigned int) to get the running status of a world.
std::optional< bool > Running (const unsigned int _worldIndex) const
 Get whether a world simulation instance is running. When running is true, then systems are being updated but simulation may or may not be stepping forward. Check the value of Paused() to determine if a world simulation instance is stepping forward. If Paused() returns true, then simulation is not stepping forward.
bool RunOnce (const bool _paused=true)
 Run the server once, all systems will be updated once and then this returns. This is a blocking call.
bool SetPaused (const bool _paused, const unsigned int _worldIndex=0) const
 Set whether a world simulation instance is paused. When paused is true, then simulation for the world is not stepping forward.
void SetUpdatePeriod (const std::chrono::steady_clock::duration &_updatePeriod, const unsigned int _worldIndex=0)
 Set the update period. The update period is the wall-clock time between ECS updates. Note that this is different from the simulation update rate. ECS systems will be updated even while sim time is paused.
void Stop ()
 Stop the server. This will stop all running simulations.
std::optional< size_t > SystemCount (const unsigned int _worldIndex=0) const
 Get the number of systems on the server.
Example Usage
A basic simulation server can be instantiated and run using
Server server;
server.Run();
An SDF File can be passed into the server via a ServerConfig object. The server will parse the SDF file and create entities for the elements contained in the file.
ServerConfig config;
config.SetSdfFile("path_to_file.sdf");
Server server(config);
server.Run();
The Run() function accepts a few arguments, one of which is whether simulation should start in a paused state. The default value of this argument is true, which starts simulation paused. This means that by default, running the server will cause systems to update but some systems may not update because paused == true. For example, a physics system will not update its state when paused is true. So, while a Server can be Running, simulation itself can be paused.
Simulation is paused by default because a common use case is to load a world from the command line. If simulation starts running, the GUI client may miss the first few simulation iterations.
Services
The following are services provided by the Server. The <world_name> in the service list is the name of the simulated world.
List syntax: service_name(request_msg_type) : response_msg_type
  1. /world/<world_name>/scene/info(none) : gz::msgs::Scene
    • Returns the current scene information.
  2. /gazebo/resource_paths/get(gz::msgs::Empty) : gz::msgs::StringMsg_V
    • Get list of resource paths.
  3. /gazebo/resource_paths/add(gz::msgs::StringMsg_V) : gz::msgs::Empty
    • Add new resource paths.
  4. /server_control(gz::msgs::ServerControl) : gz::msgs::Boolean
    • Control the simulation server.
Topics
The following are topics provided by the Server. The <world_name> in the service list is the name of the simulated world.
List syntax: topic_name : published_msg_type
  1. /world/<world_name>/clock : gz::msgs::Clock
  2. /world/<world_name>/stats : gz::msgs::WorldStatistics
    • This topic is throttled to 5Hz.
  3. /gazebo/resource_paths : gz::msgs::StringMsg_V
    • Updated list of resource paths.
◆ Status
enum class Status
strong
Enumerator
EXITED
The server encountered a critical error during initialization (e.g., an SDF parsing error while SdfErrorBehavior is set to EXIT_IMMEDIATELY) and is in a terminal state. Calls to Run() or RunOnce() will return false.
STOPPED
The server is initialized and ready, but not currently running.
RUNNING
The server is currently running.
◆ Server()
Server ( const ServerConfig &  _config = ServerConfig())
[in]_configServer configuration parameters. If this parameter is omitted, then an empty world is loaded.
◆ ~Server()
~Server ( )
◆ AddSystem() [1/5]
std::optional< bool > AddSystem ( const sdf::Plugin &  _plugin,
const unsigned int  _worldIndex = 0
[in]_pluginsystem plugin to be added with any additional XML contents.
[in]_entityEntity of system to be added. If _entity is std::nullopt, it will be added to the world entity.
[in]_worldIndexIndex of the world to query.
Whether the system was added successfully, or std::nullopt if _worldIndex is invalid.
◆ AddSystem() [2/5]
std::optional< bool > AddSystem ( const std::shared_ptr< System > &  _system,
[in]_systemSystem to be added
[in]_worldIndexIndex of the world to add to.
◆ AddSystem() [3/5]
[in]_sdfPointer to the SDF element of a <plugin> tag with configuration options for the system being added
◆ AddSystem() [4/5]
std::optional< bool > AddSystem ( const SystemPluginPtr &  _system,
[in]_systemsystem to be added
◆ AddSystem() [5/5]
[in]_sdfPointer to the SDF element of a <plugin> tag with configuration options for the system being added.
◆ EntityByName()
std::optional< Entity > EntityByName ( const std::string &  _name,
) const
If multiple entities with the same name exist, the first entity found will be returned.
[in]_nameName of the entity to get from the specified world.
The entity, or std::nullopt if the entity or world doesn't exist.
◆ EntityCount()
std::optional< size_t > EntityCount ( const unsigned int  _worldIndex = 0) const
Entity count, or std::nullopt if _worldIndex is invalid.
◆ GetStatus()
Status GetStatus ( ) const
The current status (EXITED, STOPPED, or RUNNING).
◆ HasEntity()
bool HasEntity ( const std::string &  _name,
) const
[in]_nameName of the entity.
[in]_worldIndexIndex of the world.
True if the _worldIndex is valid and the entity exists in the world.
◆ IterationCount()
std::optional< uint64_t > IterationCount ( const unsigned int  _worldIndex = 0) const
The current iteration count, or std::nullopt if _worldIndex is invalid.
◆ Paused()
std::optional< bool > Paused ( const unsigned int  _worldIndex = 0) const
True if the world simulation instance is paused, false if stepping forward, or std::nullopt if _worldIndex is invalid.
◆ RequestRemoveEntity() [1/2]
bool RequestRemoveEntity ( const Entity  _entity,
bool  _recursive = true,
[in]_entityThe entity to delete.
True if the entity exists in the world and it was queued for deletion.
◆ RequestRemoveEntity() [2/2]
bool RequestRemoveEntity ( const std::string &  _name,
If multiple entities with the same name exist, only the first entity found will be deleted.
[in]_nameName of the entity to delete.
◆ Reset()
bool Reset ( const std::size_t  _runnerId)
[in]_runnerId- The runner which you want to reset \ return False if the runner does not exist, true otherwise.
◆ ResetAll()
void ResetAll ( )
◆ Run()
bool Run ( const bool  _blocking = false,
const uint64_t  _iterations = 0,
const bool  _paused = true
[in]_blockingFalse to run the server in a new thread. True to run the server in the current thread.
[in]_iterationsNumber of steps to perform. A value of zero will run indefinitely.
[in]_pausedTrue to start simulation in a paused state, false, to start simulation unpaused.
In non-blocking mode, the return value is true if a thread was successfully created. In blocking mode, true will be returned if the Server ran for the specified number of iterations or was terminated. False will always be returned if signal handlers could not be initialized, and if the server is already running.
◆ Running() [1/2]
bool Running ( ) const
True if the server is running.
◆ Running() [2/2]
std::optional< bool > Running ( const unsigned int  _worldIndex) const
True if the server is running, or std::nullopt if _worldIndex is invalid.
◆ RunOnce()
bool RunOnce ( const bool  _paused = true)
[in]_pausedTrue to run the simulation in a paused state, false to run simulation unpaused. The simulation iterations will be increased by 1.
False if the server was terminated before completing, not being initialized, or if the server is already running.
◆ SetPaused()
bool SetPaused ( const bool  _paused,
) const
[in]_pausedTrue to pause the world, false to unpause.
True if the world referenced by _worldIndex exists, false otherwise.
◆ SetUpdatePeriod()
void SetUpdatePeriod ( const std::chrono::steady_clock::duration &  _updatePeriod,
[in]_updatePeriodDuration between updates.
◆ Stop()
void Stop ( )
◆ SystemCount()
std::optional< size_t > SystemCount ( const unsigned int  _worldIndex = 0) const
System count, or std::nullopt if _worldIndex is invalid.
