Configuration parameters for a Server. An instance of this object can be used to construct a Server with a particular configuration. More...
#include <gz/sim/ServerConfig.hh>
class  PluginInfo
Public Types
enum class  SdfErrorBehavior { EXIT_IMMEDIATELY , CONTINUE_LOADING }
 SDF error behavior. More...
enum class  SourceType { kNone , kSdfRoot , kSdfFile , kSdfString }
 Type of SDF source. More...
 ServerConfig ()
 ServerConfig (const ServerConfig &_config)
 Copy constructor.
 ~ServerConfig ()
void AddLogRecordTopic (const std::string &_topic)
 Add a topic to record.
void AddPlugin (const PluginInfo &_info)
 Instruct simulation to attach a plugin to a specific entity when simulation starts.
void AddPlugins (const std::list< PluginInfo > &_plugins)
 Add multiple plugins to the simulation.
SdfErrorBehavior BehaviorOnSdfErrors () const
 Get the behavior when SDF errors are encountered while.
void ClearLogRecordTopics ()
 Clear topics to record. This will remove all topics set using AddLogRecordTopic.
bool HeadlessRendering () const
 Get the headless mode.
double InitialSimTime () const
 Get the initial simulation time in seconds.
const std::string LogPlaybackPath () const
 Get path to recorded states to play back.
PluginInfo LogPlaybackPlugin () const
 Generate PluginInfo for Log playback based on the internal state of this ServerConfig object:
std::string LogRecordCompressPath () const
 Get file path to compress log files to.
const std::string LogRecordPath () const
 Get path to place recorded states.
std::chrono::steady_clock::duration LogRecordPeriod () const
 Get time period to record states.
PluginInfo LogRecordPlugin () const
 Generate PluginInfo for Log recording based on the internal state of this ServerConfig object:
bool LogRecordResources () const
 Get whether meshes and material files are recorded.
const std::vector< std::string > & LogRecordTopics () const
 Get the topics to record that were added using AddLogRecordTopic.
std::string NetworkRole () const
 Get the network role. See SetNetworkRole(const std::string &_role) for more information about distributed simulation and network roles.
unsigned int NetworkSecondaries () const
 Get the number of secondary servers that a primary server should expect.
ServerConfig & operator= (const ServerConfig &_cfg)
 Equal operator.
const std::string & PhysicsEngine () const
 Physics engine plugin library to load.
const std::list< PluginInfo > & Plugins () const
 Get all the plugins that should be loaded.
const std::string & RenderEngineGui () const
 Render engine plugin library to load.
const std::string & RenderEngineGuiApiBackend () const
const std::string & RenderEngineServer () const
const std::string & RenderEngineServerApiBackend () const
const std::string & ResourceCache () const
 Path to where simulation resources, such as models downloaded from fuel.gazebosim.org, should be stored.
std::string SdfFile () const
 Get the SDF file that has been set. An empty string will be returned if an SDF file has not been set.
std::optional< sdf::Root > & SdfRoot () const
 Get the SDF Root DOM object.
std::string SdfString () const
 Get the SDF String that has been set. An empty string will be returned if an SDF string has not been set.
unsigned int Seed () const
 The given random seed.
void SetBehaviorOnSdfErrors (SdfErrorBehavior _behavior)
 Set the server behavior when SDF errors are encountered while.
void SetHeadlessRendering (const bool _headless)
 Set the headless mode.
void SetInitialSimTime (const double &_initialSimTime) const
 Set the initial simulation time in seconds.
void SetLogPlaybackPath (const std::string &_playbackPath)
 Set path to recorded states to play back.
void SetLogRecordCompressPath (const std::string &_path)
 Set file path to compress log files to.
void SetLogRecordPath (const std::string &_recordPath)
 Set path to place recorded states.
void SetLogRecordPeriod (const std::chrono::steady_clock::duration &_period)
 Set time period to record states.
void SetLogRecordResources (bool _recordResources)
 Set whether meshes and material files are recorded.
void SetNetworkRole (const std::string &_role)
 Set the network role, which is one of [primary, secondary]. If primary is used, then make sure to also set the number of network secondaries via SetNetworkSecondaries(unsigned int _secondaries).
void SetNetworkSecondaries (unsigned int _secondaries)
 Set the number of network secondary servers that the primary server should expect. This value is valid only when SetNetworkRole("primary") is also used.
void SetPhysicsEngine (const std::string &_physicsEngine)
 Set the physics engine plugin library.
void SetRenderEngineGui (const std::string &_renderEngineGui)
 Set the render engine gui plugin library.
void SetRenderEngineGuiApiBackend (const std::string &_apiBackend)
 Set the render engine gui API backend.
void SetRenderEngineServer (const std::string &_renderEngineServer)
 Set the render engine server plugin library.
void SetRenderEngineServerApiBackend (const std::string &_apiBackend)
 Set the render engine server API backend.
void SetResourceCache (const std::string &_path)
 Set the path to where simulation resources, such as models downloaded from fuel.gazebosim.org, should be stored.
bool SetSdfFile (const std::string &_file)
 Set an SDF file to be used with the server.
void SetSdfRoot (const sdf::Root &_root) const
 Set the SDF Root DOM object. The sdf::Root object will take precedence over ServerConfig::SdfString() and ServerConfig::SdfFile().
bool SetSdfString (const std::string &_sdfString)
 Set an SDF string to be used by the server.
void SetSeed (unsigned int _seed)
 Set the random seed.
void SetUpdateRate (const double &_hz)
 Set the update rate in Hertz. Value <=0 are ignored.
void SetUseLevels (const bool _levels)
 Get whether the server is using the level system.
void SetUseLogRecord (const bool _record)
 Set whether the server is recording states.
void SetWaitForAssets (bool _set)
 Set whether simulation should wait for assets to download before starting. The default value is true.
SourceType Source () const
 Get the type of source.
const std::chrono::time_point< std::chrono::system_clock > & Timestamp () const
 Get the timestamp of this ServerConfig. This is the system time when this ServerConfig was created. The timestamp is used internally to create log file paths so that both state and console logs are co-located.
std::optional< std::chrono::steady_clock::duration > UpdatePeriod () const
 Get the update period duration.
std::optional< double > UpdateRate () const
 Get the update rate in Hertz.
bool UseDistributedSimulation () const
 Get whether the server is using the distributed sim system.
bool UseLevels () const
bool UseLogRecord () const
 Get whether the server is recording states.
bool WaitForAssets () const
 Get whether simulation should wait for assets to download before starting. The default value is true.
◆ SdfErrorBehavior
strong
SDF error behavior.
Enumerator
EXIT_IMMEDIATELY
Exit the server immediately.
CONTINUE_LOADING
Continue loading the server if possible.
◆ SourceType
strong
Type of SDF source.
Enumerator
kNone
kSdfRoot
kSdfFile
kSdfString
◆ ServerConfig() [1/2]
◆ ServerConfig() [2/2]
ServerConfig ( const ServerConfig &  _config)
Copy constructor.
[in]_configServerConfig to copy.
◆ ~ServerConfig()
◆ AddLogRecordTopic()
void AddLogRecordTopic ( const std::string &  _topic)
[in]_topicTopic name, which can include wildcards.
◆ AddPlugin()
void AddPlugin ( const PluginInfo &  _info)
[in]_infoInformation about the plugin to load.
◆ AddPlugins()
void AddPlugins ( const std::list< PluginInfo > &  _plugins)
[in]_pluginsList of Information about the plugin to load.
◆ BehaviorOnSdfErrors()
SdfErrorBehavior BehaviorOnSdfErrors ( ) const
loading the server.
Server behavior when SDF errors are encountered.
◆ ClearLogRecordTopics()
void ClearLogRecordTopics ( )
◆ HeadlessRendering()
bool HeadlessRendering ( ) const
◆ InitialSimTime()
double InitialSimTime ( ) const
The initial simulation time in seconds.
◆ LogPlaybackPath()
const std::string LogPlaybackPath ( ) const
Path to recorded states
◆ LogPlaybackPlugin()
PluginInfo LogPlaybackPlugin ( ) const
LogPlaybackPath
◆ LogRecordCompressPath()
std::string LogRecordCompressPath ( ) const
File path to compress log files to
◆ LogRecordPath()
const std::string LogRecordPath ( ) const
Path to place recorded states
◆ LogRecordPeriod()
std::chrono::steady_clock::duration LogRecordPeriod ( ) const
Time period to record states
◆ LogRecordPlugin()
PluginInfo LogRecordPlugin ( ) const
UseLogRecord
LogRecordPath
LogRecordResources
LogRecordTopics
◆ LogRecordResources()
bool LogRecordResources ( ) const
True if resources should be recorded.
◆ LogRecordTopics()
const std::vector< std::string > & LogRecordTopics ( ) const
The topics to record.
◆ NetworkRole()
std::string NetworkRole ( ) const
The network role.
◆ NetworkSecondaries()
unsigned int NetworkSecondaries ( ) const
Number of secondary servers.
◆ operator=()
ServerConfig & operator= ( const ServerConfig &  _cfg)
Equal operator.
[in]_cfgServerConfig to copy.
Reference to this class.
◆ PhysicsEngine()
const std::string & PhysicsEngine ( ) const
File containing physics engine library.
◆ Plugins()
const std::list< PluginInfo > & Plugins ( ) const
A list of all the plugins specified via AddPlugin(const PluginInfo &).
◆ RenderEngineGui()
const std::string & RenderEngineGui ( ) const
File containing render engine library.
◆ RenderEngineGuiApiBackend()
const std::string & RenderEngineGuiApiBackend ( ) const
Api backend for gui. See SetRenderEngineGuiApiBackend()
◆ RenderEngineServer()
const std::string & RenderEngineServer ( ) const
◆ RenderEngineServerApiBackend()
const std::string & RenderEngineServerApiBackend ( ) const
Api backend for server. See SetRenderEngineServerApiBackend()
◆ ResourceCache()
const std::string & ResourceCache ( ) const
Path to a location on disk. An empty string indicates that the default value will be used, which is currently ~/.gz/fuel.
◆ SdfFile()
std::string SdfFile ( ) const
The full path to the SDF file, or empty string.
◆ SdfRoot()
std::optional< sdf::Root > & SdfRoot ( ) const
SDF Root object to use, or std::nullopt if the sdf::Root has not been set via ServerConfig::SetSdfRoot().
◆ SdfString()
std::string SdfString ( ) const
The full contents of the SDF string, or empty string.
◆ Seed()
unsigned int Seed ( ) const
The random seed or 0 if not specified.
◆ SetBehaviorOnSdfErrors()
void SetBehaviorOnSdfErrors ( SdfErrorBehavior  _behavior)
loading the server.
[in]_behaviorServer behavior when SDF errors are encountered.
◆ SetHeadlessRendering()
void SetHeadlessRendering ( const bool  _headless)
◆ SetInitialSimTime()
void SetInitialSimTime ( const double &  _initialSimTime) const
[in]_initialSimTimeThe desired initial simulation time in seconds.
◆ SetLogPlaybackPath()
void SetLogPlaybackPath ( const std::string &  _playbackPath)
[in]_playbackPathPath to recorded states
◆ SetLogRecordCompressPath()
void SetLogRecordCompressPath ( const std::string &  _path)
[in]_pathFile path to compress log files to
◆ SetLogRecordPath()
void SetLogRecordPath ( const std::string &  _recordPath)
[in]_recordPathPath to place recorded states
◆ SetLogRecordPeriod()
void SetLogRecordPeriod ( const std::chrono::steady_clock::duration &  _period)
[in]_periodTime period to record states
◆ SetLogRecordResources()
void SetLogRecordResources ( bool  _recordResources)
[in]_recordResourcesValue to set
◆ SetNetworkRole()
void SetNetworkRole ( const std::string &  _role)
[in]_roleNetwork role, one of [primary, secondary].
Note
Setting a network role enables distributed simulation.
◆ SetNetworkSecondaries()
void SetNetworkSecondaries ( unsigned int  _secondaries)
[in]_secondariesNumber of secondary servers.
NetworkRole() const
◆ SetPhysicsEngine()
void SetPhysicsEngine ( const std::string &  _physicsEngine)
[in]_physicsEngineFile containing physics engine library.
◆ SetRenderEngineGui()
void SetRenderEngineGui ( const std::string &  _renderEngineGui)
[in]_renderEngineGuiFile containing render engine library.
◆ SetRenderEngineGuiApiBackend()
void SetRenderEngineGuiApiBackend ( const std::string &  _apiBackend)
[in]_apiBackendSee –render-engine-gui-api-backend for possible options
◆ SetRenderEngineServer()
void SetRenderEngineServer ( const std::string &  _renderEngineServer)
[in]_renderEngineServerFile containing render engine library.
◆ SetRenderEngineServerApiBackend()
void SetRenderEngineServerApiBackend ( const std::string &  _apiBackend)
[in]_apiBackendSee –render-engine-server-api-backend for possible options
◆ SetResourceCache()
void SetResourceCache ( const std::string &  _path)
[in]_pathPath to a location on disk. An empty string indicates that the default value will be used, which is currently ~/.gz/fuel.
◆ SetSdfFile()
bool SetSdfFile ( const std::string &  _file)
Setting the SDF file will override any value set by SetSdfString.
[in]_fileFull path to an SDF file.
True if the file was set, false if the file was not set. The file will not be set if the provided _file string is empty.
◆ SetSdfRoot()
void SetSdfRoot ( const sdf::Root &  _root) const
[in]_rootSDF Root object to use.
◆ SetSdfString()
bool SetSdfString ( const std::string &  _sdfString)
Setting the SDF string will override any value set by SetSdfFile.
[in]_sdfStringFull contents of the SDF string.
(reserved for future use)
◆ SetSeed()
void SetSeed ( unsigned int  _seed)
[in]_seedThe seed.
◆ SetUpdateRate()
void SetUpdateRate ( const double &  _hz)
[in]_hzThe desired update rate of the server in Hertz.
◆ SetUseLevels()
void SetUseLevels ( const bool  _levels)
[in]_levelsValue to set.
◆ SetUseLogRecord()
void SetUseLogRecord ( const bool  _record)
[in]_recordValue to set
◆ SetWaitForAssets()
void SetWaitForAssets ( bool  _set)
[in]_setTrue to wait while assets download. False will download assets in a background thread.
◆ Source()
SourceType Source ( ) const
The source type.
◆ Timestamp()
const std::chrono::time_point< std::chrono::system_clock > & Timestamp ( ) const
Time when this ServerConfig was created.
◆ UpdatePeriod()
std::optional< std::chrono::steady_clock::duration > UpdatePeriod ( ) const
The desired update period, or nullopt if an UpdateRate has not been set.
◆ UpdateRate()
std::optional< double > UpdateRate ( ) const
The desired update rate of the server in Hertz, or nullopt if an UpdateRate has not been set.
◆ UseDistributedSimulation()
bool UseDistributedSimulation ( ) const
True if the server is set to use the distributed simulation system
◆ UseLevels()
bool UseLevels ( ) const
True if the server is set to use the level system
◆ UseLogRecord()
bool UseLogRecord ( ) const
True if the server is set to record states
◆ WaitForAssets()
bool WaitForAssets ( ) const
True if simulation should wait while assets download. False indicates assets should be downloaded in a separate thread.
