ServerConfig::PluginInfo Class Reference
#include <ServerConfig.hh>
 PluginInfo ()
 Default constructor.
 PluginInfo (const PluginInfo &_info)
 Copy constructor.
 PluginInfo (const std::string &_entityName, const std::string &_entityType, const sdf::Plugin &_plugin)
 Constructor with plugin information specified.
 ~PluginInfo ()
const std::string & EntityName () const
 Get the name of the entity which should receive this plugin. The name is used in conjunction with _entityType to uniquely identify an entity.
const std::string & EntityType () const
 Get the entity type which should receive this plugin. The type is used in conjunction with EntityName to uniquely identify an entity.
PluginInfo & operator= (const PluginInfo &_info)
 Equal operator.
sdf::Plugin & Plugin ()
 Get a mutable version of the SDF plugin information.
const sdf::Plugin & Plugin () const
 Get the SDF plugin information.
void SetEntityName (const std::string &_entityName)
 Set the name of the entity which should receive this plugin. The name is used in conjunction with _entityType to uniquely identify an entity.
void SetEntityType (const std::string &_entityType)
 Set the type of the entity which should receive this plugin. The type is used in conjunction with EntityName to uniquely identify an entity.
void SetPlugin (const sdf::Plugin &_plugin) const
 Set the SDF plugin information.
Currently supports attaching a plugin to an entity given its type and name, but it can't tell apart multiple entities with the same name in different parts of the entity tree.
const std::list<PluginInfo> &Plugins() const
◆ PluginInfo() [1/3]
◆ ~PluginInfo()
~PluginInfo ( )
◆ PluginInfo() [2/3]
PluginInfo ( const std::string &  _entityName,
const std::string &  _entityType,
const sdf::Plugin &  _plugin
[in]_entityNameName of the entity which should receive this plugin. The name is used in conjunction with _entityType to uniquely identify an entity.
[in]_entityTypeEntity type which should receive this plugin. The type is used in conjunction with _entityName to uniquely identify an entity.
[in]_pluginSDF Plugin library information.
◆ PluginInfo() [3/3]
PluginInfo ( const PluginInfo &  _info)
Copy constructor.
[in]_infoPlugin to copy.
◆ EntityName()
const std::string & EntityName ( ) const
Entity name.
◆ EntityType()
const std::string & EntityType ( ) const
Entity type string.
◆ operator=()
PluginInfo & operator= ( const PluginInfo &  _info)
Equal operator.
[in]_infoPluginInfo to copy.
Reference to this class.
◆ Plugin() [1/2]
sdf::Plugin & Plugin ( )
The SDF Plugin object.
◆ Plugin() [2/2]
const sdf::Plugin & Plugin ( ) const
◆ SetEntityName()
void SetEntityName ( const std::string &  _entityName)
[in]_entityNameEntity name.
◆ SetEntityType()
void SetEntityType ( const std::string &  _entityType)
[in]_entityTypeEntity type string.
◆ SetPlugin()
void SetPlugin ( const sdf::Plugin &  _plugin) const
[in]_pluginThe SDF Plugin object to use.
