ResourceSpawner Class Reference
Provides interface for communicating to backend for generation of local models. More...
#include <ResourceSpawner.hh>
Public Slots
void DisplayResources ()
 Displays the resources to the qml grid abiding by all search and sort criteria. More...
void OnDownloadFuelResource (const QString &_path, const QString &_name, const QString &_owner, int index)
 Callback when a request is made to download a fuel resource. More...
void OnOwnerClicked (const QString &_owner)
 Callback when a fuel owner is selected, will clear the currently loaded resources and load the ones belonging to the specified owner. More...
void OnPathClicked (const QString &_path)
 Callback when a resource path is selected, will clear the currently loaded resources and load the ones at the specified path. More...
void OnResourceSpawn (const QString &_sdfPath)
 Callback when a resource is selected. More...
void OnSearchEntered (const QString &_searchKeyword)
 Callback when a search request is made. More...
void OnSortChosen (const QString &_sortType)
 Callback when a sort request is made. More...
Signals
void resourceSpawnerError (const QString &_errorMsg)
 Signal emitted when an error is encountered regarding an owner. More...
 ResourceSpawner ()
 ~ResourceSpawner () override
Q_INVOKABLE bool AddOwner (const QString &_owner)
 Add owner to the list of owners whose resources would be fetched from Fuel. More...
void AddPath (const std::string &_path)
 Adds a path to the path list model. More...
void FilterResources (std::vector< Resource > &_resources)
 Filters the vector of resources by the previously entered search keyword. More...
std::vector< Resource > FuelResources (const std::string &_owner)
 Returns the fuel resources as a vector belonging to the passed in owner. More...
Q_INVOKABLE bool IsDefaultOwner (const QString &_owner) const
 Determine if owner is the default owner. More...
Resource LocalResource (const std::string &_path)
 Returns the resource corresponding to the model.config file. More...
std::vector< Resource > LocalResources (const std::string &_path)
 Returns the local resources as a vector located under the passed in path. More...
Q_INVOKABLE void RemoveOwner (const QString &_owner)
 Remove owner from the list of owners whose resources would be fetched from Fuel. More...
void Resources (std::vector< Resource > &_resources)
 Populates the passed in _resources vector with the currently selected group of resources. More...
void SetThumbnail (const std::string &_thumbnailPath, Resource &_resource)
 Finds a thumbnail on the provided thumbnail path and sets the model's thumbnail path attribute to it, no action is taken if no thumbnail is found. More...
void SortResources (std::vector< Resource > &_resources)
 Sorts the vector of resources by the previously entered sort method. The sorting types as a string, are "Most Recent", "A - Z", "Z - A", and "Downloaded." The sort defaults to "Most Recent.". More...
Q_INVOKABLE void UpdateOwnerListModel (ignition::gazebo::Resource _resource)
 Called form a download thread to update the GUI's list of resources. More...
◆ ResourceSpawner()
◆ ~ResourceSpawner()
~ResourceSpawner ( )
◆ AddOwner()
Q_INVOKABLE bool AddOwner ( const QString &  _owner)
[in]_ownerName of owner.
True if the owner was successfully added.
◆ AddPath()
void AddPath ( const std::string &  _path)
[in]_pathThe path to add
◆ DisplayResources
void DisplayResources ( )
slot
◆ FilterResources()
void FilterResources ( std::vector< Resource > &  _resources)
[in,out]_resourcesThe vector of resources to filter
◆ FuelResources()
std::vector<Resource> FuelResources ( const std::string &  _owner)
[in]_ownerThe name of the owner
◆ IsDefaultOwner()
Q_INVOKABLE bool IsDefaultOwner ( const QString &  _owner) const
◆ LoadConfig()
◆ LocalResource()
Resource LocalResource ( const std::string &  _path)
[in]_pathThe path of the model.config file
The local resource
◆ LocalResources()
std::vector<Resource> LocalResources ( const std::string &  _path)
[in]_pathThe path to search
◆ OnDownloadFuelResource
void OnDownloadFuelResource ( const QString &  _path,
const QString &  _name,
const QString &  _owner,
int  index
slot
[in]_pathURI to the fuel resource
[in]_nameName of the resource
[in]indexThe index of the grid pane to update
◆ OnOwnerClicked
void OnOwnerClicked ( const QString &  _owner)
slot
◆ OnPathClicked
void OnPathClicked ( const QString &  _path)
slot
[in]_pathThe path to search resources
◆ OnResourceSpawn
void OnResourceSpawn ( const QString &  _sdfPath)
slot
[in]_sdfPathThe absolute path to the resource's sdf file
◆ OnSearchEntered
void OnSearchEntered ( const QString &  _searchKeyword)
slot
[in]_searchKeywordThe search keyword, applies to either the resource's name or owner
◆ OnSortChosen
void OnSortChosen ( const QString &  _sortType)
slot
[in]_sortTypeThe sorting type as a string, accepts "Most Recent", "A - Z", "Z - A", and "Downloaded." Defaults to "Most Recent."
◆ RemoveOwner()
Q_INVOKABLE void RemoveOwner ( const QString &  _owner)
◆ Resources()
void Resources ( std::vector< Resource > &  _resources)
[in,out]_resourcesThe vector of resources to populate
◆ resourceSpawnerError
void resourceSpawnerError ( const QString &  _errorMsg)
signal
[in]_errorMsgError message to be displayed.
◆ SetThumbnail()
void SetThumbnail ( const std::string &  _thumbnailPath,
Resource &  _resource
[in]_thumbnailPathThe path to search for a thumbnail
[in]_resourceThe model to update with the thumbnail information
◆ SortResources()
void SortResources ( std::vector< Resource > &  _resources)
[in,out]_resourcesThe vector of resources to sort
◆ UpdateOwnerListModel()
Q_INVOKABLE void UpdateOwnerListModel ( ignition::gazebo::Resource  _resource)
[in]_resourceThe resource fetched from Fuel. Note that it is passed by value as a copy is necessary to update the resource if it's cached.
