include/gz/sim/Types.hh File Reference
#include <chrono>
#include <cstdint>
#include <functional>
#include <utility>
#include <gz/common/Time.hh>
Classes | |
struct | UpdateInfo |
Information passed to systems on the update callback. More... | |
Namespaces | |
ignition | |
This library is part of the Ignition Robotics project. | |
ignition::gazebo | |
Typedefs | |
using | ComponentId = int |
A unique identifier for a component instance. The uniqueness of a ComponentId is scoped to the component's type. More... | |
using | ComponentKey = std::pair< ComponentTypeId, ComponentId > |
A key that uniquely identifies, at the global scope, a component instance. More... | |
using | ComponentTypeId = uint64_t |
A unique identifier for a component type. A component type must be derived from components::BaseComponent and can contain plain data or something more complex like gz::math::Pose3d . More... | |
using | EntityQueryCallback = std::function< void(const UpdateInfo, EntityComponentManager &)> |
typedef for query callbacks More... | |
Enumerations | |
enum | ComponentState { NoChange = 0, PeriodicChange = 1, OneTimeChange = 2 } |
Possible states for a component. More... | |
Variables | |
static const ComponentId | kComponentIdInvalid = -1 |
Id that indicates an invalid component. More... | |
static const ComponentTypeId | kComponentTypeIdInvalid = UINT64_MAX |
Id that indicates an invalid component type. More... | |
