include/gz/sim/Types.hh
16 */
17 #ifndef GZ_GAZEBO_TYPES_HH_
18 #define GZ_GAZEBO_TYPES_HH_
20 #include <chrono>
21 #include <cstdint>
22 #include <functional>
23 #include <utility>
24 #include <gz/common/Time.hh>
25
26 namespace ignition
27 {
28  namespace gazebo
29  {
30  // Inline bracket to help doxygen filtering.
31  inline namespace IGNITION_GAZEBO_VERSION_NAMESPACE {
32  // Forward declarations.
33  class EntityComponentManager;
34
37  struct UpdateInfo
38  {
41  std::chrono::steady_clock::duration simTime{0};
42
45  std::chrono::steady_clock::duration realTime{0};
46
48  std::chrono::steady_clock::duration dt{0};
49
51  // cppcheck-suppress unusedStructMember
52  uint64_t iterations{0};
53
59  // cppcheck-suppress unusedStructMember
60  bool paused{true};
61  };
62
64  enum class ComponentState
65  {
67  NoChange = 0,
68
71  PeriodicChange = 1,
72
76  OneTimeChange = 2
77  };
78
82  using ComponentId = int;
83
87  using ComponentTypeId = uint64_t;
88
92
94  using EntityQueryCallback = std::function<void (const UpdateInfo,
96
98  static const ComponentId kComponentIdInvalid = -1;
99
101  static const ComponentTypeId kComponentTypeIdInvalid = UINT64_MAX;
102  }
103  }
104 }
105 #endif
Simulation time handled during a single update.
Definition: include/gz/sim/Types.hh:48
Definition: gz/sim/EntityComponentManager.hh:65
Total wall clock time elapsed while simulation is running. This will not increase while paused.
Definition: include/gz/sim/Types.hh:45
@ PeriodicChange
Component value has changed, and is changing periodically. This indicates to systems that it is ok to...
Total time elapsed in simulation. This will not increase while paused.
Definition: include/gz/sim/Types.hh:41
uint64_t iterations
Total number of elapsed simulation iterations.
Definition: include/gz/sim/Types.hh:52
Id that indicates an invalid component type.
Definition: include/gz/sim/Types.hh:101
@ NoChange
Component value has not changed.
Definition: include/gz/sim/Types.hh:37
ComponentState
Possible states for a component.
Definition: include/gz/sim/Types.hh:64
@ OneTimeChange
Component value has suffered a one-time change. This indicates to systems that this change must be pr...
int ComponentId
A unique identifier for a component instance. The uniqueness of a ComponentId is scoped to the compon...
Definition: include/gz/sim/Types.hh:82
Id that indicates an invalid component.
Definition: include/gz/sim/Types.hh:98
bool paused
True if simulation is paused, which means the simulation time is not currently running,...
Definition: include/gz/sim/Types.hh:60
uint64_t ComponentTypeId
A unique identifier for a component type. A component type must be derived from components::BaseCompo...
Definition: include/gz/sim/Types.hh:87
