The EntityComponentManager constructs, deletes, and returns components and entities. A component can be of any class which inherits from components::BaseComponent. More...
#include <ignition/gazebo/EntityComponentManager.hh>
 EntityComponentManager ()
 ~EntityComponentManager ()
msgs::SerializedState ChangedState () const
 Get a message with the serialized state of all entities and components that are changing in the current iteration. More...
void ChangedState (msgs::SerializedStateMap &_state) const
template<typename ... ComponentTypeTs>
std::vector< Entity > ChildrenByComponents (Entity _parent, const ComponentTypeTs &..._desiredComponents) const
 Get all entities which match the value of all the given components and are immediate children of a given parent entity. For example, the following will return a child of entity parent which has an int component equal to 123, and a string component equal to "name": More...
template<typename ComponentTypeT >
ComponentTypeT * Component (const ComponentKey &_key)
 Get a mutable component based on a key. More...
const ComponentTypeT * Component (const ComponentKey &_key) const
 Get a component based on a key. More...
ComponentTypeT * Component (const Entity _entity)
 Get a mutable component assigned to an entity based on a component type. More...
const ComponentTypeT * Component (const Entity _entity) const
 Get a component assigned to an entity based on a component type. More...
std::optional< typename ComponentTypeT::Type > ComponentData (const Entity _entity) const
 Get the data from a component. More...
ComponentTypeT * ComponentDefault (Entity _entity, const typename ComponentTypeT::Type &_default=typename ComponentTypeT::Type())
 Get a mutable component assigned to an entity based on a component type. If the component doesn't exist, create it and initialize with the given default value. More...
gz::sim::ComponentState ComponentState (const Entity _entity, const ComponentTypeId _typeId) const
 Get a component's state. More...
std::unordered_set< ComponentTypeId > ComponentTypes (Entity _entity) const
 Get the type IDs of all components attached to an entity. More...
std::unordered_set< ComponentTypeId > ComponentTypesWithPeriodicChanges () const
 Get the components types that are marked as periodic changes. More...
ComponentKey CreateComponent (const Entity _entity, const ComponentTypeT &_data)
 Create a component of a particular type. This will copy the _data parameter. More...
Entity CreateEntity ()
 Creates a new Entity. More...
std::unordered_set< Entity > Descendants (Entity _entity) const
 Get all entities which are descendants of a given entity, including the entity itself. More...
void Each (typename identity< std::function< bool(const Entity &_entity, ComponentTypeTs *...)>>::type _f)
 Get all entities which contain given component types, as well as the mutable components. Note that an entity marked for removal (but not processed yet) will be included in the list of entities iterated by this call. More...
void Each (typename identity< std::function< bool(const Entity &_entity, const ComponentTypeTs *...)>>::type _f) const
 Get all entities which contain given component types, as well as the components. Note that an entity marked for removal (but not processed yet) will be included in the list of entities iterated by this call. More...
template<typename... ComponentTypeTs>
void EachNew (typename identity< std::function< bool(const Entity &_entity, ComponentTypeTs *...)>>::type _f)
 Get all newly created entities which contain given component types, as well as the components. This "newness" is cleared at the end of a simulation step. More...
void EachNew (typename identity< std::function< bool(const Entity &_entity, const ComponentTypeTs *...)>>::type _f) const
 Get all newly created entities which contain given component types, as well as the components. This "newness" is cleared at the end of a simulation step. This is the const version. More...
void EachNoCache (typename identity< std::function< bool(const Entity &_entity, ComponentTypeTs *...)>>::type _f)
 A version of Each() that doesn't use a cache. The cached version, Each(), is preferred. Get all entities which contain given component types, as well as the mutable components. More...
void EachNoCache (typename identity< std::function< bool(const Entity &_entity, const ComponentTypeTs *...)>>::type _f) const
 A version of Each() that doesn't use a cache. The cached version, Each(), is preferred. Get all entities which contain given component types, as well as the components. More...
void EachRemoved (typename identity< std::function< bool(const Entity &_entity, const ComponentTypeTs *...)>>::type _f) const
 Get all entities which contain given component types and are about to be removed, as well as the components. More...
const EntityGraph & Entities () const
 Get a graph with all the entities. Entities are vertices and edges point from parent to children. More...
std::vector< Entity > EntitiesByComponents (const ComponentTypeTs &..._desiredComponents) const
 Get all entities which match the value of all the given components. For example, the following will return the entities which have a name component equal to "camera" and a sensor component: More...
Entity EntityByComponents (const ComponentTypeTs &..._desiredComponents) const
 Get an entity which matches the value of all the given components. For example, the following will return the entity which has an name component equal to "name" and has a model component: More...
size_t EntityCount () const
 Get the number of entities on the server. More...
bool EntityHasComponent (const Entity _entity, const ComponentKey &_key) const
 Check whether an entity has a specific component. More...
bool EntityHasComponentType (const Entity _entity, const ComponentTypeId &_typeId) const
 Check whether an entity has a specific component type. More...
bool EntityMatches (Entity _entity, const std::set< ComponentTypeId > &_types) const
 Get whether an entity has all the given component types. More...
ComponentTypeT * First ()
 The first component instance of the specified type. More...
const ComponentTypeT * First () const
bool HasComponentType (const ComponentTypeId _typeId) const
 Get whether a component type has ever been created. More...
bool HasEntitiesMarkedForRemoval () const
 Get whether there are any entities marked to be removed. More...
bool HasEntity (const Entity _entity) const
 Get whether an Entity exists. More...
bool HasNewEntities () const
 Get whether there are new entities. More...
bool HasOneTimeComponentChanges () const
 Get whether there are one-time component changes. These changes do not happen frequently and should be processed immediately. More...
Entity ParentEntity (const Entity _entity) const
 Get the first parent of the given entity. More...
void RebuildViews ()
 Rebuild all the views. This could be an expensive operation. More...
bool RemoveComponent (const Entity _entity, const ComponentKey &_key)
 Remove a component from an entity based on a key. More...
bool RemoveComponent (const Entity _entity, const ComponentTypeId &_typeId)
 Remove a component from an entity based on a type id. More...
bool RemoveComponent (Entity _entity)
 Remove a component from an entity based on a type. More...
void RequestRemoveEntities ()
 Request to remove all entities. This will insert the request into a queue. The queue is processed toward the end of a simulation update step. More...
void RequestRemoveEntity (const Entity _entity, bool _recursive=true)
 Request an entity deletion. This will insert the request into a queue. The queue is processed toward the end of a simulation update step. More...
void SetChanged (const Entity _entity, const ComponentTypeId _type, gz::sim::ComponentState _c=ComponentState::OneTimeChange)
 Set the changed state of a component. More...
bool SetComponentData (const Entity _entity, const typename ComponentTypeT::Type &_data)
 Set the data from a component. More...
void SetEntityCreateOffset (uint64_t _offset)
 All future entities will have an id that starts at _offset. This can be used to avoid entity id collisions, such as during log playback. More...
bool SetParentEntity (const Entity _child, const Entity _parent)
 Set the parent of an entity. More...
void SetState (const msgs::SerializedState &_stateMsg)
 Set the absolute state of the ECM from a serialized message. Entities / components that are in the new state but not in the old one will be created. Entities / components that are marked as removed will be removed, but they won't be removed if they're not present in the state. More...
void SetState (const msgs::SerializedStateMap &_stateMsg)
msgs::SerializedState State (const std::unordered_set< Entity > &_entities={}, const std::unordered_set< ComponentTypeId > &_types={}) const
 Get a message with the serialized state of the given entities and components. More...
void State (msgs::SerializedStateMap &_state, const std::unordered_set< Entity > &_entities={}, const std::unordered_set< ComponentTypeId > &_types={}, bool _full=false) const
template<class Function , class... ComponentTypeTs>
static void ForEach (Function _f, const ComponentTypeTs &... _components)
 Call a function for each parameter in a pack. More...
void ClearNewlyCreatedEntities ()
 Clear the list of newly added entities so that a call to EachAdded after this will have no entities to iterate. This function is protected to facilitate testing. More...
void ProcessRemoveEntityRequests ()
 Process all entity remove requests. This will remove entities and their components. This function is protected to facilitate testing. More...
void SetAllComponentsUnchanged ()
 Mark all components as not changed. More...
◆ EntityComponentManager()
◆ ~EntityComponentManager()
◆ ChangedState() [1/2]
msgs::SerializedState ChangedState ( ) const
Currently supported:
  • New entities and all of their components
  • Removed entities and all of their components
Future work:
  • Entities which had a component added
  • Entities which had a component removed
  • Entities which had a component modified
The header of the message will not be populated, it is the responsibility of the caller to timestamp it before use.
◆ ChangedState() [2/2]
void ChangedState ( msgs::SerializedStateMap &  _state) const
Future work:
[in]_stateNew serialized state.
◆ ChildrenByComponents()
std::vector<Entity> ChildrenByComponents ( Entity  _parent,
const ComponentTypeTs &...  _desiredComponents
) const
auto entity = ChildrenByComponents(parent, 123, std::string("name"));
Component type must have inequality operator.
[in]_parentEntity which should be an immediate parent of the returned entity.
[in]_desiredComponentsAll the components which must match.
All matching entities, or an empty vector if no child entity has the exact components.
◆ ClearNewlyCreatedEntities()
void ClearNewlyCreatedEntities ( )
◆ Component() [1/4]
ComponentTypeT* Component ( const ComponentKey &  _key)
[in]_keyA key that uniquely identifies a component.
The component associated with the key, or nullptr if the component could not be found.
◆ Component() [2/4]
const ComponentTypeT* Component ( const ComponentKey &  _key) const
◆ Component() [3/4]
ComponentTypeT* Component ( const Entity  _entity)
[in]_entityThe entity.
The component of the specified type assigned to specified Entity, or nullptr if the component could not be found.
◆ Component() [4/4]
const ComponentTypeT* Component ( const Entity  _entity) const
Referenced by ignition::gazebo::enableComponent(), and Pose3d::UpdateView().
◆ ComponentData()
std::optional<typename ComponentTypeT::Type> ComponentData ( const Entity  _entity) const
  • If the component type doesn't hold any data, this won't compile.
  • If the entity doesn't have that component, it will return nullopt.
  • If the entity has the component, return its data.
    Template Parameters
    ComponentTypeTComponent type
    The data of the component of the specified type assigned to specified Entity, or nullptr if the component could not be found.
◆ ComponentDefault()
ComponentTypeT* ComponentDefault ( Entity  _entity,
const typename ComponentTypeT::Type &  _default = typename ComponentTypeT::Type()
[in]_defaultThe value that should be used to construct the component in case the component doesn't exist.
The component of the specified type assigned to the specified entity.
◆ ComponentState()
gz::sim::ComponentState ComponentState ( const Entity  _entity,
) const
[in]_entityEntity that contains the component.
[in]_typeIdComponent type ID.
Component's current state
◆ ComponentTypes()
std::unordered_set<ComponentTypeId> ComponentTypes ( Entity  _entity) const
[in]_entityEntity to check.
All the component type IDs.
◆ ComponentTypesWithPeriodicChanges()
std::unordered_set<ComponentTypeId> ComponentTypesWithPeriodicChanges ( ) const
All the components that at least one entity marked as periodic changes.
◆ CreateComponent()
ComponentKey CreateComponent ( const Entity  _entity,
const ComponentTypeT &  _data
[in]_entityThe entity that will be associated with the component.
[in]_dataData used to construct the component.
Key that uniquely identifies the component.
Referenced by ignition::gazebo::enableComponent().
◆ CreateEntity()
Entity CreateEntity ( )
An id for the Entity, or kNullEntity on failure.
◆ Descendants()
std::unordered_set<Entity> Descendants ( Entity  _entity) const
[in]_entityEntity whose descendants we want.
All child entities recursively, including _entity. It will be empty if the entity doesn't exist.
◆ Each() [1/2]
void Each ( typename identity< std::function< bool(const Entity &_entity, ComponentTypeTs *...)>>::type  _f)
[in]_fCallback function to be called for each matching entity. The function parameter are all the desired component types, in the order they're listed on the template. The callback function can return false to stop subsequent calls to the callback, otherwise a true value should be returned.
Template Parameters
ComponentTypeTsAll the desired mutable component types.
Warning
This function should not be called outside of System's PreUpdate, Update, or PostUpdate callbacks.
◆ Each() [2/2]
void Each ( typename identity< std::function< bool(const Entity &_entity, const ComponentTypeTs *...)>>::type  _f) const
Template Parameters
ComponentTypeTsAll the desired component types.
Warning
◆ EachNew() [1/2]
void EachNew ( typename identity< std::function< bool(const Entity &_entity, ComponentTypeTs *...)>>::type  _f)
Template Parameters
Warning
Since entity creation occurs during PreUpdate, this function should not be called in a System's PreUpdate callback (it's okay to call this function in the Update callback). If you need to call this function in a system's PostUpdate callback, you should use the const version of this method.
◆ EachNew() [2/2]
void EachNew ( typename identity< std::function< bool(const Entity &_entity, const ComponentTypeTs *...)>>::type  _f) const
Template Parameters
Warning
Since entity creation occurs during PreUpdate, this function should not be called in a System's PreUpdate callback (it's okay to call this function in the Update or PostUpdate callback).
◆ EachNoCache() [1/2]
void EachNoCache ( typename identity< std::function< bool(const Entity &_entity, ComponentTypeTs *...)>>::type  _f)
Template Parameters
Warning
◆ EachNoCache() [2/2]
void EachNoCache ( typename identity< std::function< bool(const Entity &_entity, const ComponentTypeTs *...)>>::type  _f) const
Template Parameters
Warning
◆ EachRemoved()
void EachRemoved ( typename identity< std::function< bool(const Entity &_entity, const ComponentTypeTs *...)>>::type  _f) const
Template Parameters
Warning
This function should not be called outside of System's PostUpdate callback.
◆ Entities()
const EntityGraph& Entities ( ) const
Entity graph.
◆ EntitiesByComponents()
std::vector<Entity> EntitiesByComponents ( const ComponentTypeTs &...  _desiredComponents) const
auto entities = EntitiesByComponents(components::Name("camera"), components::Sensor());
◆ EntityByComponents()
Entity EntityByComponents ( const ComponentTypeTs &...  _desiredComponents) const
auto entity = EntityByComponents(components::Name("name"), components::Model());
Entity or kNullEntity if no entity has the exact components.
◆ EntityCount()
size_t EntityCount ( ) const
Entity count.
◆ EntityHasComponent()
bool EntityHasComponent ( const Entity  _entity,
) const
[in]_entityThe entity to check.
[in]_keyThe component to check.
True if the component key belongs to the entity.
◆ EntityHasComponentType()
bool EntityHasComponentType ( const Entity  _entity,
const ComponentTypeId &  _typeId
) const
[in]_typeIdComponent type id to check.
True if the entity exists and has at least one component with the provided type.
◆ EntityMatches()
bool EntityMatches ( Entity  _entity,
const std::set< ComponentTypeId > &  _types
) const
[in]_typesComponent types to check that the Entity has.
True if the given entity has all the given types.
◆ First() [1/2]
ComponentTypeT* First ( )
First component instance of the specified type, or nullptr if the type does not exist.
◆ First() [2/2]
const ComponentTypeT* First ( ) const
◆ ForEach()
static void ForEach ( Function  _f,
static
[in]_fFunction to be called.
[in]_componentsParameters which should be passed to the function.
◆ HasComponentType()
bool HasComponentType ( const ComponentTypeId  _typeId) const
[in]_typeIdID of the component type to check.
True if the provided _typeId has been created.
◆ HasEntitiesMarkedForRemoval()
bool HasEntitiesMarkedForRemoval ( ) const
True if there are entities marked to be removed.
◆ HasEntity()
bool HasEntity ( const Entity  _entity) const
[in]_entityEntity to confirm.
True if the Entity exists.
◆ HasNewEntities()
bool HasNewEntities ( ) const
True if there are new entities.
◆ HasOneTimeComponentChanges()
bool HasOneTimeComponentChanges ( ) const
True if there are any components with one-time changes.
◆ ParentEntity()
Entity ParentEntity ( const Entity  _entity) const
Entities are not expected to have multiple parents. TODO(louise) Either prevent multiple parents or provide full support for multiple parents.
[in]_entityEntity.
The parent entity or kNullEntity if there's none.
◆ ProcessRemoveEntityRequests()
void ProcessRemoveEntityRequests ( )
◆ RebuildViews()
void RebuildViews ( )
◆ RemoveComponent() [1/3]
bool RemoveComponent ( const Entity  _entity,
True if the entity and component existed and the component was removed.
◆ RemoveComponent() [2/3]
[in]_typeIdComponent's type Id.
◆ RemoveComponent() [3/3]
bool RemoveComponent ( Entity  _entity)
Template Parameters
Componenttype.
◆ RequestRemoveEntities()
void RequestRemoveEntities ( )
◆ RequestRemoveEntity()
void RequestRemoveEntity ( const Entity  _entity,
bool  _recursive = true
It is recommended that systems don't call this function directly, and instead use the sim::SdfEntityCreator class to remove entities.
[in]_entityEntity to be removed.
◆ SetAllComponentsUnchanged()
void SetAllComponentsUnchanged ( )
◆ SetChanged()
void SetChanged ( const Entity  _entity,
gz::sim::ComponentState  _c = ComponentState::OneTimeChange
[in]_typeType of the component.
[in]_cChanged state value, defaults to one-time-change.
◆ SetComponentData()
bool SetComponentData ( const Entity  _entity,
const typename ComponentTypeT::Type &  _data
  • If the entity doesn't have that component, the component will be created.
  • If the entity has the component, its data will be updated.
    [in]_dataNew component data
    Template Parameters
    True if data has changed. It will always be true if the data type doesn't have an equality operator.
◆ SetEntityCreateOffset()
void SetEntityCreateOffset ( uint64_t  _offset)
[in]_offsetOffset value.
◆ SetParentEntity()
bool SetParentEntity ( const Entity  _child,
It is recommended that systems don't call this function directly, and instead use the sim::SdfEntityCreator class to create entities that have the correct parent-child relationship.
[in]_childEntity to set the parent
[in]_parentEntity which should be an immediate parent _child entity.
True if successful. Will fail if entities don't exist.
◆ SetState() [1/2]
void SetState ( const msgs::SerializedState &  _stateMsg)
The header of the message will not be handled, it is the responsibility of the caller to use the timestamp.
[in]_stateMsgMessage containing state to be set.
◆ SetState() [2/2]
void SetState ( const msgs::SerializedStateMap &  _stateMsg)
◆ State() [1/2]
msgs::SerializedState State ( const std::unordered_set< Entity > &  _entities = {},
const std::unordered_set< ComponentTypeId > &  _types = {}
) const
[in]_entitiesEntities to be serialized. Leave empty to get all entities.
[in]_typesType ID of components to be serialized. Leave empty to get all components.
◆ State() [2/2]
void State ( msgs::SerializedStateMap &  _state,
const std::unordered_set< ComponentTypeId > &  _types = {},
bool  _full = false
) const
[in]_stateserialized state
[in]_fullTrue to get all the entities and components. False will get only components and entities that have changed.
