ignition::gazebo::components Namespace Reference
Components represent data, such as position information. An Entity usually has one or more associated components. More...
class  BaseComponent
 Base class for all components. More...
class  Component
 A component type that wraps any data type. The intention is for this class to be used to create simple components while avoiding a lot of boilerplate code. The Identifier must be a unique type so that type aliases can be used to create new components. However the type does not need to be defined anywhere eg. More...
class  Component< NoData, Identifier, Serializer >
class  ComponentDescriptor
 A class for an object responsible for creating components. More...
class  ComponentDescriptorBase
 A base class for an object responsible for creating components. More...
struct  DetachableJointInfo
 Data structure to hold information about the parent and child links connected by a detachable joint. More...
class  Factory
 A factory that generates a component based on a string type. More...
class  StorageDescriptor
 A class for an object responsible for creating storages. More...
class  StorageDescriptorBase
 A base class for an object responsible for creating storages. More...
using Actor = Component< sdf::Actor, class ActorTag, serializers::ActorSerializer >
 This component contains actor source information. For more information on actors, see SDF's Actor element. More...
using Actuators = Component< msgs::Actuators, class ActuatorsTag, serializers::MsgSerializer >
 A component type that contains a msgs::Actuators message. This is used for example, to communicate between the MulticopterMotorModel and MulticopterVelocityControl systems. More...
using AirPressureSensor = Component< sdf::Sensor, class AirPressureSensorTag, serializers::SensorSerializer >
 A component type that contains an air pressure sensor, sdf::AirPressure, information. More...
using Altimeter = Component< sdf::Sensor, class AltimeterTag, serializers::SensorSerializer >
 A component type that contains an altimeter sensor, sdf::Altimeter, information. More...
using AngularAcceleration = Component< math::Vector3d, class AngularAccelerationTag >
 A component type that contains angular acceleration of an entity represented by gz::math::Vector3d. More...
using AngularVelocity = Component< math::Vector3d, class AngularVelocityTag >
 A component type that contains angular velocity of an entity represented by gz::math::Vector3d. More...
using AngularVelocityCmd = Component< math::Vector3d, class AngularVelocityCmdTag >
 A component type that contains the commanded angular velocity of an entity, in its own frame, represented by gz::math::Vector3d. More...
using Atmosphere = Component< sdf::Atmosphere, class AtmosphereTag, serializers::AtmosphereSerializer >
 This component holds atmosphere properties of the world. More...
using AxisAlignedBox = Component< gz::math::AxisAlignedBox, class AxisAlignedBoxTag, serializers::AxisAlignedBoxSerializer >
 A component type that contains axis aligned box, gz::math::AxisAlignedBox, information. The axis aligned box is created from collisions in the entity. More...
using BatterySoC = Component< float, class BatterySoCTag >
using Camera = Component< sdf::Sensor, class CameraTag, serializers::SensorSerializer >
 A component type that contains a camera sensor, sdf::Camera, information. More...
using CanonicalLink = Component< NoData, class CanonicalLinkTag >
 A component that identifies an entity as being a canonical link. More...
using CastShadows = Component< bool, class CastShadowsTag >
 A component used to indicate that an entity casts shadows e.g. visual entities. More...
using CenterOfVolume = Component< math::Vector3d, class CenterOfVolumeTag >
 A component for an entity's center of volume. Units are in meters. The Vector3 value indicates center of volume of an entity. The position of the center of volume is relative to the pose of the parent entity, which is usually a link. More...
using ChildLinkName = Component< std::string, class ChildLinkNameTag >
 A component used to indicate that a model is childlinkname (i.e. not moveable). More...
using Collision = Component< NoData, class CollisionTag >
 A component that identifies an entity as being a collision. More...
using ContactSensor = Component< sdf::ElementPtr, class ContactSensorTag >
 TODO(anyone) Substitute with sdf::Contact once that exists? This is currently the whole <sensor> element. More...
using ContactSensorData = Component< msgs::Contacts, class ContactSensorDataTag, serializers::MsgSerializer >
 A component type that contains a list of contacts. More...
using DepthCamera = Component< sdf::Sensor, class DepthCameraTag, serializers::SensorSerializer >
 A component type that contains a depth camera sensor, sdf::Camera, information. More...
using DetachableJoint = Component< DetachableJointInfo, class DetachableJointTag, serializers::DetachableJointInfoSerializer >
 A component that identifies an entity as being a detachable joint. It also contains additional information about the joint. More...
using ExternalWorldWrenchCmd = Component< msgs::Wrench, class ExternalWorldWrenchCmdTag, serializers::MsgSerializer >
 A component type that contains the external wrench to be applied on an entity expressed in the world frame and represented by gz::msgs::Wrench. Currently this is used for applying wrenches on links. Although the msg::Wrench type has a force_offset member, the value is currently ignored. Instead, the force is applied at the link origin. The wrench uses SI units (N for force and N⋅m for torque). More...
using Geometry = Component< sdf::Geometry, class GeometryTag, serializers::GeometrySerializer >
 This component holds an entity's geometry. More...
using GpuLidar = Component< sdf::Sensor, class GpuLidarTag, serializers::SensorSerializer >
 A component type that contains a GPU Lidar sensor, sdf::Lidar, information. More...
using Gravity = Component< math::Vector3d, class GravityTag >
 Store the gravity acceleration. More...
using Imu = Component< sdf::Sensor, class ImuTag, serializers::SensorSerializer >
 A component type that contains an IMU sensor, sdf::IMU, information. More...
using Inertial = Component< math::Inertiald, class InertialTag, serializers::InertialSerializer >
 This component holds an entity's inertial. More...
using Joint = Component< NoData, class JointTag >
 A component that identifies an entity as being a joint. More...
using JointAxis = Component< sdf::JointAxis, class JointAxisTag, serializers::JointAxisSerializer >
 A component that contains the joint axis . This is a simple wrapper around sdf::JointAxis. More...
using JointEffortLimitsCmd = Component< std::vector< gz::math::Vector2d >, class JointEffortLimitsCmdTag, serializers::VectorSerializer< gz::math::Vector2d > >
 Command for setting effort limits of a joint. Data are a vector with a Vector2 for each DOF. The X() component of the Vector2 specifies the minimum effort limit, the Y() component stands for maximum limit. Set to +-infinity to disable the limits. More...
using JointForce = Component< std::vector< double >, class JointForceTag, serializers::VectorDoubleSerializer >
 Force applied to a joint in SI units (Nm for revolute, N for prismatic). More...
using JointForceCmd = Component< std::vector< double >, class JointForceCmdTag >
 Commanded joint forces (or torques) to be applied to a joint in SI units (Nm for revolute, N for prismatic). The component wraps a std::vector and systems that set this component need to ensure that the vector has the same size as the degrees of freedom of the joint. More...
using JointPosition = Component< std::vector< double >, class JointPositionTag, serializers::VectorDoubleSerializer >
 Joint positions in SI units (rad for revolute, m for prismatic). The component wraps a std::vector of size equal to the degrees of freedom of the joint. More...
using JointPositionLimitsCmd = Component< std::vector< gz::math::Vector2d >, class JointPositionLimitsCmdTag, serializers::VectorSerializer< gz::math::Vector2d > >
 Command for setting position limits of a joint. Data are a vector with a Vector2 for each DOF. The X() component of the Vector2 specifies the minimum positional limit, the Y() component stands for maximum limit. Set to +-infinity to disable the limits. More...
using JointPositionReset = Component< std::vector< double >, class JointPositionResetTag, serializers::VectorDoubleSerializer >
 Joint positions in SI units (rad for revolute, m for prismatic). More...
using JointType = Component< sdf::JointType, class JointTypeTag, serializers::JointTypeSerializer >
 A component that contains the joint type. This is a simple wrapper around sdf::JointType. More...
using JointVelocity = Component< std::vector< double >, class JointVelocityTag, serializers::VectorDoubleSerializer >
 Base class which can be extended to add serialization. More...
using JointVelocityCmd = Component< std::vector< double >, class JointVelocityCmdTag, serializers::VectorDoubleSerializer >
using JointVelocityLimitsCmd = Component< std::vector< gz::math::Vector2d >, class JointVelocityLimitsCmdTag, serializers::VectorSerializer< gz::math::Vector2d > >
 Command for setting velocity limits of a joint. Data are a vector with a Vector2 for each DOF. The X() component of the Vector2 specifies the minimum velocity limit, the Y() component stands for maximum limit. Set to +-infinity to disable the limits. More...
using JointVelocityReset = Component< std::vector< double >, class JointVelocityResetTag, serializers::VectorDoubleSerializer >
 Joint velocities in SI units (rad/s for revolute, m/s for prismatic). More...
using LaserRetro = Component< double, class LaserRetroTag >
 A component used to indicate an lidar reflective value. More...
using Level = Component< NoData, class LevelTag >
 This component identifies an entity as being a level. More...
using LevelBuffer = Component< double, class LevelBufferTag >
 A component that holds the buffer setting of a level's geometry. More...
using LevelEntityNames = Component< std::set< std::string >, class LevelEntityNamesTag, serializers::LevelEntityNamesSerializer >
 A component that holds a list of names of entities to be loaded in a level. More...
using Lidar = Component< sdf::Sensor, class LidarTag, serializers::SensorSerializer >
 A component type that contains a Lidar sensor, sdf::Lidar, information. More...
using Light = Component< sdf::Light, class LightTag, serializers::LightSerializer >
 This component contains light source information. For more information on lights, see SDF's Light element. More...
using LinearAcceleration = Component< math::Vector3d, class LinearAccelerationTag >
 A component type that contains linear acceleration of an entity represented by gz::math::Vector3d. More...
using LinearVelocity = Component< math::Vector3d, class LinearVelocityTag >
 A component type that contains linear velocity of an entity represented by gz::math::Vector3d. More...
using LinearVelocityCmd = Component< math::Vector3d, class LinearVelocityCmdTag >
using LinearVelocitySeed = Component< math::Vector3d, class LinearVelocitySeedTag >
 A component type that contains linear velocity seed of an entity expressed in the local frame of the entity and represented by gz::math::Vector3d. This seed can used to generate linear velocities by applying transformations and adding noise. More...
using Link = Component< NoData, class LinkTag >
 A component that identifies an entity as being a link. More...
using LogicalAudioSource = Component< logical_audio::Source, class LogicalAudioSourceTag, serializers::LogicalAudioSourceSerializer >
 A component that contains a logical audio source, which is represented by logical_audio::Source. More...
using LogicalAudioSourcePlayInfo = Component< logical_audio::SourcePlayInfo, class LogicalAudioSourcePlayInfoTag, serializers::LogicalAudioSourcePlayInfoSerializer >
 A component that contains a logical audio source's playing information, which is represented by logical_audio::SourcePlayInfo. More...
using LogicalCamera = Component< sdf::ElementPtr, class LogicalCameraTag >
 TODO(anyone) Substitute with sdf::LogicalCamera once that exists? This is currently the whole <sensor> element. More...
using LogicalMicrophone = Component< logical_audio::Microphone, class LogicalMicrophoneTag, serializers::LogicalMicrophoneSerializer >
 A component that contains a logical microphone, which is represented by logical_audio::Microphone. More...
using LogPlaybackStatistics = Component< gz::msgs::LogPlaybackStatistics, class LogPlaybackStatisticsTag, serializers::MsgSerializer >
 A component type that contains log playback, systems::LogPlayback, information. The log playback is created from world entity upon the playback plugin being loaded. More...
using MagneticField = Component< math::Vector3d, class MagneticFieldTag >
 Stores the 3D magnetic field in teslas. More...
using Magnetometer = Component< sdf::Sensor, class MagnetometerTag, serializers::SensorSerializer >
 A component type that contains a magnetometer sensor, sdf::Magnetometer, information. More...
using Material = Component< sdf::Material, class MaterialTag, serializers::MaterialSerializer >
 This component holds an entity's material. More...
using Model = Component< NoData, class ModelTag >
 A component that identifies an entity as being a model. More...
using Name = Component< std::string, class NameTag >
 This component holds an entity's name. The component has no concept of scoped names nor does it care about uniqueness. More...
using NoData = std::add_lvalue_reference< void >
 Convenient type to be used by components that don't wrap any data. I.e. they act as tags and their presence is enough to infer something about the entity. More...
using ParentEntity = Component< Entity, class ParentEntityTag >
 This component holds an entity's parent entity. More...
using ParentLinkName = Component< std::string, class ParentLinkNameTag >
 Holds the name of the entity's parent link. More...
using Performer = Component< NoData, class PerformerTag >
 This component identifies an entity as being a performer. More...
using PerformerAffinity = Component< std::string, class PerformerAffinityTag >
 This component holds the address of the distributed secondary that this performer is associated with. More...
using PerformerLevels = Component< std::set< Entity >, class PerformerLevelsTag, serializers::PerformerLevelsSerializer >
 Holds all the levels which a performer is in. More...
using Physics = Component< sdf::Physics, class PhysicsTag, serializers::PhysicsSerializer >
 A component type that contains the physics properties of the World entity. More...
using PhysicsCmd = Component< msgs::Physics, class PhysicsCmdTag >
using PhysicsEnginePlugin = Component< std::string, class PhysicsEnginePluginTag >
 Holds the physics engine shared library. More...
using Pose = Component< gz::math::Pose3d, class PoseTag >
 A component type that contains pose, gz::math::Pose3d, information. More...
using RenderEngineGuiPlugin = Component< std::string, class RenderEngineGuiPluginTag, serializers::StringSerializer >
 Holds the render engine gui shared library. More...
using RenderEngineServerPlugin = Component< std::string, class RenderEngineServerPluginTag, serializers::StringSerializer >
 Holds the render engine server shared library. More...
using RgbdCamera = Component< sdf::Sensor, class RgbdCameraTag, serializers::SensorSerializer >
 A component type that contains a RGBD camera sensor, sdf::Camera, information. More...
using Scene = Component< sdf::Scene, class SceneTag, serializers::SceneSerializer >
 This component holds scene properties of the world. More...
using SelfCollide = Component< bool, class SelfCollideTag >
 A component used to hold a model's self collide property. More...
using Sensor = Component< NoData, class SensorTag >
 A component that identifies an entity as being a sensor. More...
using SlipComplianceCmd = Component< std::vector< double >, class SlipComplianceCmdTag >
 A component type that contains the slip compliance parameters to be set on a collision. The 0 and 1 index values correspond to the slip compliance parameters in friction direction 1 (fdir1) and friction direction 2 (fdir2) respectively. More...
using SourceFilePath = Component< std::string, class SourceFilePathTag >
 This component holds the filepath to the source from which an entity is created. For example, it can be used to store the file path of a model's SDFormat file. More...
using Static = Component< bool, class StaticTag >
 A component used to indicate that a model is static (i.e. not moveable). More...
using Temperature = Component< math::Temperature, class TemperatureTag >
 A component that stores temperature data in Kelvin. More...
using ThermalCamera = Component< sdf::Sensor, class ThermalCameraTag, serializers::SensorSerializer >
 A component type that contains a Thermal camera sensor, sdf::Sensor, information. More...
using ThreadPitch = Component< double, class ThreadPitchTag >
 A component used to store the thread pitch of a screw joint. More...
using Transparency = Component< float, class TransparencyTag >
 A component used to indicate an entity's transparency value e.g. visual entities. Value is in the range from 0 (opaque) to 1 (transparent). More...
using Visual = Component< NoData, class VisualTag >
 A component that identifies an entity as being a visual. More...
using Volume = Component< double, class VolumeTag >
 A volume component where the units are m^3. Double value indicates volume of an entity. More...
using Wind = Component< NoData, class WindTag >
 A component that identifies an entity as being a wind. More...
using WindMode = Component< bool, class WindModeTag >
 A component used to indicate whether an entity is affected by wind. More...
using World = Component< NoData, class WorldTag >
 A component that identifies an entity as being a world. More...
using WorldPoseCmd = Component< math::Pose3d, class WorldPoseCmdTag >
 A component type that contains commanded pose of an entity in the world frame represented by gz::math::Pose3d. More...
Functions
 IGN_GAZEBO_REGISTER_COMPONENT ("ign_gazebo_components.AngularAcceleration", AngularAcceleration) using WorldAngularAcceleration
 A component type that contains angular acceleration of an entity in the world frame represented by gz::math::Vector3d. More...
 IGN_GAZEBO_REGISTER_COMPONENT ("ign_gazebo_components.Collision", Collision) using CollisionElement
 A component that holds the sdf::Collision object. More...
 IGN_GAZEBO_REGISTER_COMPONENT ("ign_gazebo_components.CollisionElement", CollisionElement) using EnableContactSurfaceCustomization
 A component used to enable customization of contact surface for a collision. The customization itself is done in callback of event CollectContactSurfaceProperties from PhysicsEvents. More...
 IGN_GAZEBO_REGISTER_COMPONENT ("ign_gazebo_components.Level", Level) using DefaultLevel
 This component identifies an entity as being a default level. More...
 IGN_GAZEBO_REGISTER_COMPONENT ("ign_gazebo_components.Model", Model) using ModelSdf
 A component that holds the model's SDF DOM. More...
 IGN_GAZEBO_REGISTER_COMPONENT ("ign_gazebo_components.Sensor", Sensor) using SensorTopic
 Name of the transport topic where a sensor is publishing its data. For sensors that publish on more than one topic, this will usually be the prefix common to all topics of that sensor. More...
 IGN_GAZEBO_REGISTER_COMPONENT ("ign_gazebo_components.World", World) using WorldSdf
 A component that holds the world's SDF DOM. More...
The set of Components assigned to an Entity also act as a key. Systems process Entities based on their key. For example, a physics system may process only entities that have pose and inertia components.
Typedef Documentation
◆ Actor
using Actor = Component<sdf::Actor, class ActorTag, serializers::ActorSerializer>
◆ Actuators
◆ AirPressureSensor
using AirPressureSensor = Component<sdf::Sensor, class AirPressureSensorTag, serializers::SensorSerializer>
◆ Altimeter
using Altimeter = Component<sdf::Sensor, class AltimeterTag, serializers::SensorSerializer>
◆ AngularAcceleration
using AngularAcceleration = Component<math::Vector3d, class AngularAccelerationTag>
◆ AngularVelocity
using AngularVelocity = Component<math::Vector3d, class AngularVelocityTag>
◆ AngularVelocityCmd
using AngularVelocityCmd = Component<math::Vector3d, class AngularVelocityCmdTag>
◆ Atmosphere
using Atmosphere = Component<sdf::Atmosphere, class AtmosphereTag, serializers::AtmosphereSerializer>
◆ AxisAlignedBox
using AxisAlignedBox = Component<gz::math::AxisAlignedBox, class AxisAlignedBoxTag, serializers::AxisAlignedBoxSerializer>
◆ BatterySoC
using BatterySoC = Component<float, class BatterySoCTag>
A component that identifies an entity as being a battery. Float value indicates state of charge.
◆ Camera
using Camera = Component<sdf::Sensor, class CameraTag, serializers::SensorSerializer>
◆ CanonicalLink
using CanonicalLink = Component<NoData, class CanonicalLinkTag>
◆ CastShadows
using CastShadows = Component<bool, class CastShadowsTag>
◆ CenterOfVolume
using CenterOfVolume = Component<math::Vector3d, class CenterOfVolumeTag>
◆ ChildLinkName
using ChildLinkName = Component<std::string, class ChildLinkNameTag>
◆ Collision
using Collision = Component<NoData, class CollisionTag>
◆ ContactSensor
using ContactSensor = Component<sdf::ElementPtr, class ContactSensorTag>
◆ ContactSensorData
◆ DepthCamera
using DepthCamera = Component<sdf::Sensor, class DepthCameraTag, serializers::SensorSerializer>
◆ DetachableJoint
◆ ExternalWorldWrenchCmd
using ExternalWorldWrenchCmd = Component<msgs::Wrench, class ExternalWorldWrenchCmdTag, serializers::MsgSerializer>
◆ Geometry
using Geometry = Component<sdf::Geometry, class GeometryTag, serializers::GeometrySerializer>
◆ GpuLidar
using GpuLidar = Component<sdf::Sensor, class GpuLidarTag, serializers::SensorSerializer>
◆ Gravity
using Gravity = Component<math::Vector3d, class GravityTag>
◆ Imu
using Imu = Component<sdf::Sensor, class ImuTag, serializers::SensorSerializer>
◆ Inertial
◆ Joint
using Joint = Component<NoData, class JointTag>
◆ JointAxis
using JointAxis = Component<sdf::JointAxis, class JointAxisTag, serializers::JointAxisSerializer>
◆ JointEffortLimitsCmd
Note
It is expected that the physics plugin reads this component and sets the limit to the dynamics engine. After setting it, the data of this component will be cleared (i.e. the vector will have length zero).
◆ JointForce
using JointForce = Component<std::vector<double>, class JointForceTag, serializers::VectorDoubleSerializer>
◆ JointForceCmd
using JointForceCmd = Component<std::vector<double>, class JointForceCmdTag>
◆ JointPosition
using JointPosition = Component<std::vector<double>, class JointPositionTag, serializers::VectorDoubleSerializer>
◆ JointPositionLimitsCmd
Note
◆ JointPositionReset
using JointPositionReset = Component<std::vector<double>, class JointPositionResetTag, serializers::VectorDoubleSerializer>
◆ JointType
using JointType = Component<sdf::JointType, class JointTypeTag, serializers::JointTypeSerializer>
◆ JointVelocity
using JointVelocity = Component<std::vector<double>, class JointVelocityTag, serializers::VectorDoubleSerializer>
◆ JointVelocityCmd
using JointVelocityCmd = Component<std::vector<double>, class JointVelocityCmdTag, serializers::VectorDoubleSerializer>
◆ JointVelocityLimitsCmd
Note
◆ JointVelocityReset
using JointVelocityReset = Component<std::vector<double>, class JointVelocityResetTag, serializers::VectorDoubleSerializer>
◆ LaserRetro
using LaserRetro = Component<double, class LaserRetroTag>
◆ Level
using Level = Component<NoData, class LevelTag>
◆ LevelBuffer
using LevelBuffer = Component<double, class LevelBufferTag>
◆ LevelEntityNames
◆ Lidar
using Lidar = Component<sdf::Sensor, class LidarTag, serializers::SensorSerializer>
◆ Light
using Light = Component<sdf::Light, class LightTag, serializers::LightSerializer>
◆ LinearAcceleration
using LinearAcceleration = Component<math::Vector3d, class LinearAccelerationTag>
◆ LinearVelocity
using LinearVelocity = Component<math::Vector3d, class LinearVelocityTag>
◆ LinearVelocityCmd
using LinearVelocityCmd = Component< math::Vector3d, class LinearVelocityCmdTag>
entity represented by gz::math::Vector3d, expressed in the entity's frame.
◆ LinearVelocitySeed
using LinearVelocitySeed = Component<math::Vector3d, class LinearVelocitySeedTag>
◆ Link
using Link = Component<NoData, class LinkTag>
◆ LogicalAudioSource
◆ LogicalAudioSourcePlayInfo
◆ LogicalCamera
using LogicalCamera = Component<sdf::ElementPtr, class LogicalCameraTag>
◆ LogicalMicrophone
◆ LogPlaybackStatistics
using LogPlaybackStatistics = Component<gz::msgs::LogPlaybackStatistics, class LogPlaybackStatisticsTag, serializers::MsgSerializer>
◆ MagneticField
using MagneticField = Component<math::Vector3d, class MagneticFieldTag>
◆ Magnetometer
using Magnetometer = Component<sdf::Sensor, class MagnetometerTag, serializers::SensorSerializer>
◆ Material
using Material = Component<sdf::Material, class MaterialTag, serializers::MaterialSerializer>
◆ Model
using Model = Component<NoData, class ModelTag>
◆ Name
using Name = Component<std::string, class NameTag>
◆ NoData
◆ ParentEntity
using ParentEntity = Component<Entity, class ParentEntityTag>
Note that the EntityComponentManager also keeps the parent-child relationship stored in a graph, and that information should be kept in sync with the parent entity components. Therefore, it is recommended that the ParentEntity component is never edited by hand, and instead, entities should be created using the sim::SdfEntityCreator class.
◆ ParentLinkName
using ParentLinkName = Component<std::string, class ParentLinkNameTag>
◆ Performer
using Performer = Component<NoData, class PerformerTag>
◆ PerformerAffinity
using PerformerAffinity = Component<std::string, class PerformerAffinityTag>
◆ PerformerLevels
◆ Physics
using Physics = Component<sdf::Physics, class PhysicsTag, serializers::PhysicsSerializer>
◆ PhysicsCmd
using PhysicsCmd = Component<msgs::Physics, class PhysicsCmdTag>
◆ PhysicsEnginePlugin
using PhysicsEnginePlugin = Component<std::string, class PhysicsEnginePluginTag>
◆ Pose
using Pose = Component<gz::math::Pose3d, class PoseTag>
◆ RenderEngineGuiPlugin
using RenderEngineGuiPlugin = Component<std::string, class RenderEngineGuiPluginTag, serializers::StringSerializer>
◆ RenderEngineServerPlugin
using RenderEngineServerPlugin = Component<std::string, class RenderEngineServerPluginTag, serializers::StringSerializer>
◆ RgbdCamera
using RgbdCamera = Component<sdf::Sensor, class RgbdCameraTag, serializers::SensorSerializer>
◆ Scene
using Scene = Component<sdf::Scene, class SceneTag, serializers::SceneSerializer>
◆ SelfCollide
using SelfCollide = Component<bool, class SelfCollideTag>
◆ Sensor
using Sensor = Component<NoData, class SensorTag>
◆ SlipComplianceCmd
using SlipComplianceCmd = Component<std::vector<double>, class SlipComplianceCmdTag>
◆ SourceFilePath
using SourceFilePath = Component<std::string, class SourceFilePathTag>
◆ Static
using Static = Component<bool, class StaticTag>
◆ Temperature
using Temperature = Component<math::Temperature, class TemperatureTag>
◆ ThermalCamera
using ThermalCamera = Component<sdf::Sensor, class ThermalCameraTag, serializers::SensorSerializer>
◆ ThreadPitch
using ThreadPitch = Component<double, class ThreadPitchTag>
◆ Transparency
using Transparency = Component<float, class TransparencyTag>
◆ Visual
using Visual = Component<NoData, class VisualTag>
◆ Volume
using Volume = Component<double, class VolumeTag>
◆ Wind
using Wind = Component<NoData, class WindTag>
◆ WindMode
using WindMode = Component<bool, class WindModeTag>
◆ World
using World = Component<NoData, class WorldTag>
◆ WorldPoseCmd
using WorldPoseCmd = Component<math::Pose3d, class WorldPoseCmdTag>
Function Documentation
◆ IGN_GAZEBO_REGISTER_COMPONENT() [1/7]
IGN_GAZEBO_REGISTER_COMPONENT ( "ign_gazebo_components.AngularAcceleration"  ,
AngularAcceleration
Initial value:
Component<math::Vector3d, class WorldAngularVelocityTag>
A component type that contains pose, gz::math::Pose3d, information in world frame.
A component type that contains linear velocity seed of an entity in the world frame represented by gz::math::Vector3d. This seed can used to generate linear velocities by applying transformations and adding noise.
A component type that contains the commanded linear velocity of an entity represented by gz::math::Vector3d, expressed in the world frame.
A component type that contains linear velocity of an entity in the world frame represented by gz::math::Vector3d.
A component type that contains linear acceleration of an entity in the world frame represented by gz::math::Vector3d.
A component that contains the second joint axis for joints with two axes. This is a simple wrapper around sdf::JointAxis.
A component type that contains the commanded angular velocity of an entity in the world frame represented by gz::math::Vector3d.
A component type that contains angular velocity of an entity in the world frame represented by gz::math::Vector3d.
◆ IGN_GAZEBO_REGISTER_COMPONENT() [2/7]
ignition::gazebo::components::IGN_GAZEBO_REGISTER_COMPONENT ( "ign_gazebo_components.Collision"  ,
Collision
◆ IGN_GAZEBO_REGISTER_COMPONENT() [3/7]
ignition::gazebo::components::IGN_GAZEBO_REGISTER_COMPONENT ( "ign_gazebo_components.CollisionElement"  ,
CollisionElement
◆ IGN_GAZEBO_REGISTER_COMPONENT() [4/7]
ignition::gazebo::components::IGN_GAZEBO_REGISTER_COMPONENT ( "ign_gazebo_components.Level"  ,
Level
◆ IGN_GAZEBO_REGISTER_COMPONENT() [5/7]
ignition::gazebo::components::IGN_GAZEBO_REGISTER_COMPONENT ( "ign_gazebo_components.Model"  ,
Model
◆ IGN_GAZEBO_REGISTER_COMPONENT() [6/7]
ignition::gazebo::components::IGN_GAZEBO_REGISTER_COMPONENT ( "ign_gazebo_components.Sensor"  ,
Sensor
◆ IGN_GAZEBO_REGISTER_COMPONENT() [7/7]
ignition::gazebo::components::IGN_GAZEBO_REGISTER_COMPONENT ( "ign_gazebo_components.World"  ,
World
