A factory that generates a component based on a string type. More...
#include <Factory.hh>
bool HasType (ComponentTypeId _typeId)
 Check if a component type has been registered. return True if registered. More...
std::string Name (ComponentTypeId _typeId) const
 Get a component's type name given its type ID. return Unique component name. More...
template<typename ComponentTypeT >
std::unique_ptr< ComponentTypeT > New ()
 Create a new instance of a component. More...
std::unique_ptr< components::BaseComponent > New (const ComponentTypeId &_type)
std::unique_ptr< ComponentStorageBase > NewStorage (const ComponentTypeId &_typeId)
 Create a new instance of a component storage. More...
void Register (const std::string &_type, ComponentDescriptorBase *_compDesc, StorageDescriptorBase *_storageDesc)
 Register a component so that the factory can create instances of the component and its storage based on an ID. More...
std::vector< ComponentTypeId > TypeIds () const
 Get all the registered component types by ID. return Vector of component IDs. More...
void Unregister ()
 Unregister a component so that the factory can't create instances of the component or its storage anymore. More...
void Unregister (ComponentTypeId _typeId)
Static Public Attributes
static std::map< ComponentTypeId, std::string > namesById
 A list of IDs and their equivalent names. More...
static std::map< ComponentTypeId, std::string > runtimeNamesById
 Keep track of the runtime names for types and warn the user if they try to register different types with the same typeName. More...
◆ HasType()
bool HasType ( ComponentTypeId  _typeId)
inline
◆ Name()
std::string Name ( ComponentTypeId  _typeId) const
inline
References map< K, T >::at(), string::end(), map< K, T >::find(), and Factory::namesById.
◆ New() [1/2]
std::unique_ptr<ComponentTypeT> New ( )
inline
Pointer to a component. Null if the component type could not be handled.
Template Parameters
ComponentTypeTcomponent type requested
◆ New() [2/2]
[in]_typeComponent id to create.
◆ NewStorage()
std::unique_ptr<ComponentStorageBase> NewStorage ( const ComponentTypeId &  _typeId)
inline
[in]_typeIdType of component which the storage will hold.
Pointer to a storage. Null if the component type could not be handled.
◆ Register()
void Register ( const std::string &  _type,
ComponentDescriptorBase *  _compDesc,
StorageDescriptorBase *  _storageDesc
inline
[in]_typeType of component to register.
[in]_compDescObject to manage the creation of ComponentTypeT objects.
[in]_storageDescObject to manage the creation of storages for objects of type ComponentTypeT.
Template Parameters
ComponentTypeTType of component to register.
References map< K, T >::end(), std::endl(), map< K, T >::find(), Factory::namesById, and Factory::runtimeNamesById.
◆ TypeIds()
std::vector<ComponentTypeId> TypeIds ( ) const
inline
References vector< T >::push_back().
◆ Unregister() [1/2]
void Unregister ( )
inline
Template Parameters
ComponentTypeTType of component to unregister.
◆ Unregister() [2/2]
void Unregister ( ComponentTypeId  _typeId)
inline
This function will not reset the typeId static variable within the component type itself. Prefer using the templated Unregister function when possible.
[in]_typeIdType of component to unregister.
References map< K, T >::end(), map< K, T >::erase(), map< K, T >::find(), Factory::namesById, and Factory::runtimeNamesById.
◆ namesById
std::map<ComponentTypeId, std::string> namesById
inlinestatic
Make it non-static on version 2.0.
Referenced by Factory::Name(), Factory::Register(), and Factory::Unregister().
◆ runtimeNamesById
std::map<ComponentTypeId, std::string> runtimeNamesById
inlinestatic
Referenced by Factory::Register(), and Factory::Unregister().
