gz/sim/components/Factory.hh
16 */
17 #ifndef GZ_GAZEBO_COMPONENTS_FACTORY_HH_
18 #define GZ_GAZEBO_COMPONENTS_FACTORY_HH_
20 #include <cstdint>
21 #include <cstring>
22 #include <map>
23 #include <memory>
24 #include <string>
25 #include <vector>
26
27 #include <gz/common/SingletonT.hh>
28 #include <gz/common/Util.hh>
30 #include <gz/sim/detail/ComponentStorageBase.hh>
31 #include <gz/sim/config.hh>
32 #include <gz/sim/Export.hh>
33 #include <gz/sim/Types.hh>
34
35 namespace ignition
36 {
37 namespace gazebo
38 {
39 // Inline bracket to help doxygen filtering.
40 inline namespace IGNITION_GAZEBO_VERSION_NAMESPACE {
41 namespace components
42 {
44  class IGNITION_GAZEBO_VISIBLE ComponentDescriptorBase
45  {
47  public: virtual ~ComponentDescriptorBase() = default;
48
51  public: virtual std::unique_ptr<BaseComponent> Create() const = 0;
52  };
53
56  template <typename ComponentTypeT>
57  class IGNITION_GAZEBO_VISIBLE ComponentDescriptor
59  {
62  public: std::unique_ptr<BaseComponent> Create() const override
63  {
64  return std::make_unique<ComponentTypeT>();
65  }
66  };
67
69  class IGNITION_GAZEBO_VISIBLE StorageDescriptorBase
70  {
72  public: virtual ~StorageDescriptorBase() = default;
73
76  public: virtual std::unique_ptr<ComponentStorageBase> Create() const = 0;
77  };
78
81  template <typename ComponentTypeT>
82  class IGNITION_GAZEBO_VISIBLE StorageDescriptor
83  : public StorageDescriptorBase
84  {
89  {
90  return std::make_unique<ComponentStorage<ComponentTypeT>>();
91  }
92  };
93
95  class IGNITION_GAZEBO_VISIBLE Factory
96  : public gz::common::SingletonT<Factory>
97  {
106  public: template<typename ComponentTypeT>
107  void Register(const std::string &_type, ComponentDescriptorBase *_compDesc,
108  StorageDescriptorBase *_storageDesc)
109  {
110  // Every time a plugin which uses a component type is loaded, it attempts
111  // to register it again, so we skip it.
112  if (ComponentTypeT::typeId != 0)
113  {
114  return;
115  }
116
117  auto typeHash = gz::common::hash64(_type);
118
119  // Initialize static member variable - we need to set these
120  // static members for every shared lib that uses the component, but we
121  // only add them to the maps below once.
122  ComponentTypeT::typeId = typeHash;
123  ComponentTypeT::typeName = _type;
124
125  // Check if component has already been registered by another library
126  auto runtimeName = typeid(ComponentTypeT).name();
127  auto runtimeNameIt = this->runtimeNamesById.find(typeHash);
128  if (runtimeNameIt != this->runtimeNamesById.end())
129  {
130  // Warn user if type was previously registered with a different name.
131  // We're leaving the ID set in case this is a false difference across
132  // libraries.
133  if (runtimeNameIt->second != runtimeName)
134  {
135  std::cerr
136  << "Registered components of different types with same name: type ["
137  << runtimeNameIt->second << "] and type [" << runtimeName
138  << "] with name [" << _type << "]. Second type will not work."
139  << std::endl;
140  }
141  return;
142  }
143
144  // This happens at static initialization time, so we can't use common
145  // console
146  std::string debugEnv;
147  gz::common::env("IGN_DEBUG_COMPONENT_FACTORY", debugEnv);
148  if (debugEnv == "true")
149  {
150  std::cout << "Registering [" << ComponentTypeT::typeName << "]"
151  << std::endl;
152  }
153
154  // Keep track of all types
155  this->compsById[ComponentTypeT::typeId] = _compDesc;
156  this->storagesById[ComponentTypeT::typeId] = _storageDesc;
157  namesById[ComponentTypeT::typeId] = ComponentTypeT::typeName;
158  runtimeNamesById[ComponentTypeT::typeId] = runtimeName;
159  }
160
164  public: template<typename ComponentTypeT>
165  void Unregister()
166  {
167  this->Unregister(ComponentTypeT::typeId);
168
169  ComponentTypeT::typeId = 0;
170  }
171
178  public: void Unregister(ComponentTypeId _typeId)
179  {
180  // Not registered
181  if (_typeId == 0)
182  {
183  return;
184  }
185
186  {
187  auto it = this->compsById.find(_typeId);
188  if (it != this->compsById.end())
189  {
190  delete it->second;
191  this->compsById.erase(it);
192  }
193  }
194
195  {
196  auto it = this->storagesById.find(_typeId);
197  if (it != this->storagesById.end())
198  {
199  delete it->second;
200  this->storagesById.erase(it);
201  }
202  }
203
204  {
205  auto it = namesById.find(_typeId);
206  if (it != namesById.end())
207  {
208  namesById.erase(it);
209  }
210  }
211
212  {
213  auto it = runtimeNamesById.find(_typeId);
214  if (it != runtimeNamesById.end())
215  {
216  runtimeNamesById.erase(it);
217  }
218  }
219  }
220
225  public: template<typename ComponentTypeT>
227  {
228  return std::unique_ptr<ComponentTypeT>(static_cast<ComponentTypeT *>(
229  this->New(ComponentTypeT::typeId).release()));
230  }
231
237  const ComponentTypeId &_type)
238  {
239  // Create a new component if a FactoryFn has been assigned to this type.
241  auto it = this->compsById.find(_type);
242  if (it != this->compsById.end() && nullptr != it->second)
243  comp = it->second->Create();
244
245  return comp;
246  }
247
253  const ComponentTypeId &_typeId)
254  {
256  auto it = this->storagesById.find(_typeId);
257  if (it != this->storagesById.end() && nullptr != it->second)
258  storage = it->second->Create();
259
260  return storage;
261  }
262
266  {
268
269  // Return the list of all known component types.
270  for (const auto &comp : this->compsById)
271  types.push_back(comp.first);
272
273  return types;
274  }
275
278  public: bool HasType(ComponentTypeId _typeId)
279  {
280  return this->compsById.find(_typeId) != this->compsById.end();
281  }
282
285  public: std::string Name(ComponentTypeId _typeId) const
286  {
287  if (this->namesById.find(_typeId) != this->namesById.end())
288  return namesById.at(_typeId);
289
290  return "";
291  }
292
307
311
315
319  public: inline static std::map<ComponentTypeId, std::string>
321  };
322
331  #define IGN_GAZEBO_REGISTER_COMPONENT(_compType, _classname) \
332  class IGNITION_GAZEBO_VISIBLE IgnGazeboComponents##_classname \
333  { \
334  public: IgnGazeboComponents##_classname() \
335  { \
336  if (_classname::typeId != 0) \
337  return; \
338  using namespace ignition;\
339  using Desc = gz::sim::components::ComponentDescriptor<_classname>; \
340  using StorageDesc = gz::sim::components::StorageDescriptor<_classname>; \
341  gz::sim::components::Factory::Instance()->Register<_classname>(\
342  _compType, new Desc(), new StorageDesc());\
343  } \
344  }; \
345  static IgnGazeboComponents##_classname\
346  IgnitionGazeboComponentsInitializer##_classname;
347 }
348 }
349 }
350 }
351
352 #endif
virtual ~ComponentDescriptorBase()=default
static std::map< ComponentTypeId, std::string > runtimeNamesById
Keep track of the runtime names for types and warn the user if they try to register different types w...
Definition: gz/sim/components/Factory.hh:320
STL class.
std::unique_ptr< ComponentTypeT > New()
Create a new instance of a component.
Definition: gz/sim/components/Factory.hh:226
static std::map< ComponentTypeId, std::string > namesById
A list of IDs and their equivalent names.
Definition: gz/sim/components/Factory.hh:314
void Unregister()
Unregister a component so that the factory can't create instances of the component or its storage any...
Definition: gz/sim/components/Factory.hh:165
Get a component's type name given its type ID. return Unique component name.
Definition: gz/sim/components/Factory.hh:285
STL class.
T find(T... args)
Definition: gz/sim/components/Factory.hh:178
virtual std::unique_ptr< BaseComponent > Create() const =0
Create an instance of a Component.
std::unique_ptr< ComponentStorageBase > Create() const override
Create an instance of a storage that holds ComponentTypeT components.
Definition: gz/sim/components/Factory.hh:88
A factory that generates a component based on a string type.
Definition: gz/sim/components/Factory.hh:95
T push_back(T... args)
A base class for an object responsible for creating components.
Definition: gz/sim/components/Factory.hh:44
T at(T... args)
void Register(const std::string &_type, ComponentDescriptorBase *_compDesc, StorageDescriptorBase *_storageDesc)
Register a component so that the factory can create instances of the component and its storage based ...
Definition: gz/sim/components/Factory.hh:107
A class for an object responsible for creating components.
Definition: gz/sim/components/Factory.hh:57
T erase(T... args)
std::unique_ptr< BaseComponent > Create() const override
Create an instance of a ComponentTypeT Component.
Definition: gz/sim/components/Factory.hh:62
STL class.
std::unique_ptr< components::BaseComponent > New(const ComponentTypeId &_type)
Definition: gz/sim/components/Factory.hh:236
virtual ~StorageDescriptorBase()=default
T endl(T... args)
Check if a component type has been registered. return True if registered.
Definition: gz/sim/components/Factory.hh:278
std::unique_ptr< ComponentStorageBase > NewStorage(const ComponentTypeId &_typeId)
Create a new instance of a component storage.
Definition: gz/sim/components/Factory.hh:252
std::vector< ComponentTypeId > TypeIds() const
Get all the registered component types by ID. return Vector of component IDs.
Definition: gz/sim/components/Factory.hh:265
T end(T... args)
A base class for an object responsible for creating storages.
Definition: gz/sim/components/Factory.hh:69
uint64_t ComponentTypeId
A unique identifier for a component type. A component type must be derived from components::BaseCompo...
Definition: include/gz/sim/Types.hh:87
STL class.
virtual std::unique_ptr< ComponentStorageBase > Create() const =0
Create an instance of a storage.
A class for an object responsible for creating storages.
Definition: gz/sim/components/Factory.hh:82
