gz/sim/components/Factory.hh File Reference
#include <cstdint>
#include <cstring>
#include <map>
#include <memory>
#include <string>
#include <vector>
#include <gz/common/SingletonT.hh>
#include <gz/common/Util.hh>
#include <gz/sim/detail/ComponentStorageBase.hh>
#include <gz/sim/config.hh>
#include <gz/sim/Export.hh>
#include <gz/sim/Types.hh>
class  ComponentDescriptor< ComponentTypeT >
 A class for an object responsible for creating components. More...
class  ComponentDescriptorBase
 A base class for an object responsible for creating components. More...
class  Factory
 A factory that generates a component based on a string type. More...
class  StorageDescriptor< ComponentTypeT >
 A class for an object responsible for creating storages. More...
class  StorageDescriptorBase
 A base class for an object responsible for creating storages. More...
 ignition
 ignition::gazebo
 ignition::gazebo::components
Macros
#define IGN_GAZEBO_REGISTER_COMPONENT(_compType, _classname)
 Static component registration macro. More...
Macro Definition Documentation
◆ IGN_GAZEBO_REGISTER_COMPONENT
#define IGN_GAZEBO_REGISTER_COMPONENT (   _compType,
  _classname
Value:
class IgnGazeboComponents##_classname \
public: IgnGazeboComponents##_classname() \
if (_classname::typeId != 0) \
return; \
using namespace ignition;\
using Desc = gz::sim::components::ComponentDescriptor<_classname>; \
using StorageDesc = gz::sim::components::StorageDescriptor<_classname>; \
gz::sim::components::Factory::Instance()->Register<_classname>(\
_compType, new Desc(), new StorageDesc());\
static IgnGazeboComponents##_classname\
IgnitionGazeboComponentsInitializer##_classname;
Use this macro to register components.
Each time a plugin which uses a component is loaded, it tries to register the component again, so we prevent that.
[in]_compTypeComponent type name.
[in]_classnameClass name for component.
