ignition::gazebo::gui Namespace Reference
 events
class  Plot3D
Functions
IGNITION_GAZEBO_GUI_VISIBLE std::unique_ptr< gz::gui::Application > createGui (int &_argc, char **_argv, const char *_guiConfig, const char *_defaultGuiConfig, bool _loadPluginsFromSdf, const char *_sdfFile, int _waitGui)
 Create a Gazebo GUI application. More...
IGNITION_GAZEBO_GUI_VISIBLE std::unique_ptr< gz::gui::Application > createGui (int &_argc, char **_argv, const char *_guiConfig, const char *_defaultGuiConfig=nullptr, bool _loadPluginsFromSdf=true)
IGNITION_GAZEBO_GUI_VISIBLE int runGui (int &_argc, char **_argv, const char *_guiConfig)
 Run GUI application. More...
IGNITION_GAZEBO_GUI_VISIBLE int runGui (int &_argc, char **_argv, const char *_guiConfig, const char *_sdfFile, int _waitGui)
Function Documentation
◆ createGui() [1/2]
IGNITION_GAZEBO_GUI_VISIBLE std::unique_ptr<gz::gui::Application> ignition::gazebo::gui::createGui ( int &  _argc,
char **  _argv,
const char *  _guiConfig,
const char *  _defaultGuiConfig,
const char *  _sdfFile,
int  _waitGui
[in]_argcNumber of command line arguments (Used when running without ign-tools. Set to 1 if using ign-tools). Note: The object referenced by this variable must continue to exist for the lifetime of the application.
[in]_argvCommand line arguments (Used when running without ign-tools. Set to the name of the application if using ign-tools)
[in]_guiConfigThe GUI configuration file. If nullptr, the default configuration from IGN_HOMEDIR/.ignition/gazebo/gui.config will be used.
[in]_defaultGuiConfigThe default GUI configuration file. If no plugins were added from a world file or from _guiConfig, this configuration file will be loaded. If this argument is a nullptr or if the file does not exist, the default configuration from IGN_HOMEDIR/.ignition/gazebo/gui.config will be used.
[in]_loadPluginsFromSdfIf true, plugins specified in the world SDFormat file will get loaded.
[in]_sdfFileSDF world file, or nullptr if not set.
[in]_waitGuiTrue if the server is waiting for the GUI to decide on a starting world.
◆ createGui() [2/2]
char **  _argv,
const char *  _defaultGuiConfig = nullptr,
bool  _loadPluginsFromSdf = true
◆ runGui() [1/2]
IGNITION_GAZEBO_GUI_VISIBLE int ignition::gazebo::gui::runGui ( int &  _argc,
char **  _argv,
◆ runGui() [2/2]
char **  _argv,
int  _waitGui
[in]_sdfFileThe world file path passed as a command line argument. If set, QuickStart Dialog will not be shown.
[in]_waitGuiFlag indicating whether the server waits until it receives a world path from GUI.
