src/systems/logical_audio_sensor_plugin/LogicalAudio.hh
17 #ifndef GZ_GAZEBO_SYSTEMS_LOGICAL_AUDIO_SENSOR_PLUGIN_LOGICALAUDIO_HH_
18 #define GZ_GAZEBO_SYSTEMS_LOGICAL_AUDIO_SENSOR_PLUGIN_LOGICALAUDIO_HH_
20 #include <string>
21
24 #include <gz/math/Pose3.hh>
25
26 namespace ignition
27 {
28 namespace gazebo
29 {
32 namespace logical_audio
33 {
44  bool detect(double _volumeLevel, double _volumeDetectionThreshold);
45
64  double computeVolume(bool _playing,
65  AttenuationFunction _attenuationFunc,
66  AttenuationShape _attenuationShape,
67  double _sourceEmissionVolume,
68  double _innerRadius,
69  double _falloffDistance,
70  const gz::math::Pose3d &_sourcePose,
71  const gz::math::Pose3d &_targetPose);
72
86  void setAttenuationFunction(AttenuationFunction &_attenuationFunc,
87  std::string _str);
88
101  void setAttenuationShape(AttenuationShape &_attenuationShape,
102  std::string _str);
103
113  void validateInnerRadiusAndFalloffDistance(double &_innerRadius,
114  double &_falloffDistance);
115
120  void validateVolumeLevel(double &_volumeLevel);
121 }
122 }
123 }
124 }
125
126 #endif
STL class.
void setAttenuationFunction(AttenuationFunction &_attenuationFunc, std::string _str)
Set the attenuation function that matches the defined string. The string is not case sensitive,...
void setAttenuationShape(AttenuationShape &_attenuationShape, std::string _str)
Set the attenuation shape that matches the defined string. The string is not case sensitive,...
AttenuationShape
Audio source attenuation shapes. AttenuationShape::Undefined is used to indicate that an attenuation ...
Definition: include/gz/sim/components/LogicalAudio.hh:46
AttenuationFunction
Audio source attenuation functions. AttenuationFunction::Undefined is used to indicate that an attenu...
Definition: include/gz/sim/components/LogicalAudio.hh:41
Determines if an audio device can detect volume at a certain level.
Validate a source's emission volume level.
void validateInnerRadiusAndFalloffDistance(double &_innerRadius, double &_falloffDistance)
Validate the inner radius and falloff distance for an audio source.
double computeVolume(bool _playing, AttenuationFunction _attenuationFunc, AttenuationShape _attenuationShape, double _sourceEmissionVolume, double _innerRadius, double _falloffDistance, const gz::math::Pose3d &_sourcePose, const gz::math::Pose3d &_targetPose)
Computes the volume level of an audio source at a certain location.
