Rotor Struct Reference
A struct that holds various properties of a rotor. More...
#include <Parameters.hh>
Public Attributes
double angle
 The angle formed on the xy plane by the vector going from the the center of mass to the rotor. The angle is measured from the +x axis of the body frame. More...
double armLength
 The length of the vector going from the center of mass to the rotor. More...
int direction
 Direction of rotation of the rotor. +1 is counterclockwise and -1 is clockwise. More...
double forceConstant
 A constant that multiplies with the square of the rotor's velocity to compute its thrust. More...
double momentConstant
 A constant the multiplies with the rotor's thrust to compute its moment. More...
◆ angle
double angle
◆ armLength
double armLength
◆ direction
int direction
◆ forceConstant
◆ momentConstant
