Breadcrumbs.hh
17 #ifndef GZ_GAZEBO_SYSTEMS_BREADCRUMBS_HH_
18 #define GZ_GAZEBO_SYSTEMS_BREADCRUMBS_HH_
20 #include <memory>
21 #include <optional>
22 #include <set>
23 #include <string>
24 #include <unordered_map>
25 #include <vector>
26
27 #include <sdf/Element.hh>
28 #include <sdf/Geometry.hh>
29 #include <sdf/Root.hh>
30
31 #include <gz/transport/Node.hh>
32 #include <gz/math/Pose3.hh>
33
34 #include "gz/sim/Model.hh"
36 #include "gz/sim/System.hh"
37
38 namespace ignition
39 {
40 namespace gazebo
41 {
42 // Inline bracket to help doxygen filtering.
43 inline namespace IGNITION_GAZEBO_VERSION_NAMESPACE {
44 namespace systems
45 {
89  : public System,
90  public ISystemConfigure,
91  public ISystemPreUpdate
92  {
94  public: Breadcrumbs() = default;
95
96  // Documentation inherited
97  public: void Configure(const Entity &_entity,
100  EventManager &_eventMgr) override;
101
102  // Documentation inherited
103  public: void PreUpdate(
104  const gz::sim::UpdateInfo &_info,
105  gz::sim::EntityComponentManager &_ecm) override;
106
108  private: void OnDeploy(const msgs::Empty &_msg);
109
114  public: bool MakeStatic(Entity _entity, EntityComponentManager &_ecm);
115
117  private: bool initialized{false};
118
120  private: transport::Node node;
121
123  private: Model model{kNullEntity};
124
126  private: Entity worldEntity{kNullEntity};
127
129  public: std::unique_ptr<SdfEntityCreator> creator{nullptr};
130
132  private: int maxDeployments{-1};
133
135  private: int numDeployments{0};
136
138  private: sdf::Root modelRoot;
139
141  private: bool isPerformer{false};
142
145  private: bool allowRenaming{false};
146
148  private: std::optional<sdf::Geometry> performerGeometry;
149
151  private: std::vector<bool> pendingCmds;
152
154  private: std::set<Entity> pendingGeometryUpdate;
155
157  private: std::mutex pendingCmdsMutex;
158
160  private: std::chrono::steady_clock::duration disablePhysicsTime =
161  std::chrono::steady_clock::duration::zero();
162
165  autoStaticEntities;
166
168  private: sdf::Model staticModelToSpawn;
169
171  public: transport::Node::Publisher remainingPub;
172
174  public: bool topicStatistics{false};
175
178  };
179  }
180 }
181 }
182 }
183
184 #endif
Definition: gz/sim/EventManager.hh:55
Interface for a system that implements optional configuration.
Definition: gz/sim/System.hh:90
Interface for a system that uses the PreUpdate phase.
Definition: gz/sim/System.hh:121
This class provides wrappers around entities and components which are more convenient and straight-fo...
Definition: gz/sim/Model.hh:60
Base class for a System.
Definition: gz/sim/System.hh:76
A system for creating Breadcrumbs in the form of models that can get deployed/spawned at the location...
Definition: Breadcrumbs.hh:92
void PreUpdate(const gz::sim::UpdateInfo &_info, gz::sim::EntityComponentManager &_ecm) override
void Configure(const Entity &_entity, const std::shared_ptr< const sdf::Element > &_sdf, EntityComponentManager &_ecm, EventManager &_eventMgr) override
Configure the system.
std::string topic
Name of the deploy topic.
Definition: Breadcrumbs.hh:177
Publishes remaining deployments.
Definition: Breadcrumbs.hh:171
Make an entity static.
Component< NoData, class ModelTag > Model
A component that identifies an entity as being a model.
Definition: gz/sim/components/Model.hh:125
const Entity kNullEntity
Indicates a non-existant or invalid Entity.
Definition: gz/sim/Entity.hh:61
Entity worldEntity(const Entity &_entity, const EntityComponentManager &_ecm)
Get the world to which the given entity belongs.
uint64_t Entity
Definition: include/gz/sim/Types.hh:39
