Interface for a system that implements optional configuration. More...
#include <System.hh>
| virtual void | Configure (const Entity &_entity, const std::shared_ptr< const sdf::Element > &_sdf, EntityComponentManager &_ecm, EventManager &_eventMgr)=0 |
Configure is called after the system is instantiated and all entities and components are loaded from the corresponding SDF world, and before simulation begins exectution.
◆ Configure()
pure virtual |
Implemented in ModelPhotoShoot, Hydrodynamics, BuoyancyEnginePlugin, Sensors, LogRecord, LogPlayback, Thermal, ThermalSensor, Label, WheelSlip, VelocityControl, UserCommands, TriggeredPublisher, TrajectoryFollower, TrackedVehicle, TrackController, TouchPlugin, PosePublisher, ParticleEmitter2, ParticleEmitter, OpticalTactilePlugin, OdometryPublisher, MulticopterMotorModel, MulticopterVelocityControl, MecanumDrive, LogicalAudioSensorPlugin, LiftDrag, JointTrajectoryController, JointPositionController, JointController, Elevator, DiffDrive, CommsEndpoint, Buoyancy, Breadcrumbs, ApplyLinkWrench, ApplyJointForce, AckermannSteering, ICommsModel, WindEffects, ShaderParam, SceneBroadcaster, Physics, PerformerDetector, LogVideoRecorder, KineticEnergyMonitor, FollowActor, DetachableJoint, CameraVideoRecorder, LinearBatteryPlugin, Thruster, and JointStatePublisher.
