AckermannSteering Class Reference
Ackermann steering controller which can be attached to a model with any number of left and right wheels. More...
#include <AckermannSteering.hh>
 AckermannSteering ()
 ~AckermannSteering () override=default
 Configure the system. More...
void PreUpdate (const gz::sim::UpdateInfo &_info, gz::sim::EntityComponentManager &_ecm) override
<left_joint>: Name of a joint that controls a left wheel. This element can appear multiple times, and must appear at least once.
<right_joint>: Name of a joint that controls a right wheel. This element can appear multiple times, and must appear at least once.
<left_steering_joint>: Name of a joint that controls steering for left wheel. This element must appear once. Vehicles that steer rear wheels are not currently correctly supported.
<right_steering_joint>: Name of a joint that controls steering for right wheel. This element must appear once.
<wheel_separation>: Distance between wheels, in meters. This element is optional, although it is recommended to be included with an appropriate value. The default value is 1.0m.
<kingpin_width>: Distance between wheel kingpins, in meters. This element is optional, although it is recommended to be included with an appropriate value. The default value is 0.8m. Generally a bit smaller than the wheel_separation.
<wheel_base>: Distance between front and rear wheels, in meters. This element is optional, although it is recommended to be included with an appropriate value. The default value is 1.0m.
<steering_limit>: Value to limit steering to. Can be calculated by measuring the turning radius and wheel_base of the real vehicle. steering_limit = asin(wheel_base / turning_radius) The default value is 0.5 radians.
<wheel_radius>: Wheel radius in meters. This element is optional, although it is recommended to be included with an appropriate value. The default value is 0.2m.
<odom_publish_frequency>: Odometry publication frequency. This element is optional, and the default value is 50Hz.
<min_velocity>: Minimum velocity [m/s], usually <= 0. <max_velocity>: Maximum velocity [m/s], usually >= 0. <min_acceleration>: Minimum acceleration [m/s^2], usually <= 0. <max_acceleration>: Maximum acceleration [m/s^2], usually >= 0. <min_jerk Minimum>: jerk [m/s^3], usually <= 0. <max_jerk Maximum>: jerk [m/s^3], usually >= 0.
<topic>: Custom topic that this system will subscribe to in order to receive command velocity messages. This element if optional, and the default value is /model/{name_of_model}/cmd_vel.
<odom_topic>: Custom topic on which this system will publish odometry messages. This element if optional, and the default value is /model/{name_of_model}/odometry.
<tf_topic>: Custom topic on which this system will publish the transform from frame_id to child_frame_id. This element is optional, and the default value is /model/{name_of_model}/tf.
<frame_id>: Custom frame_id field that this system will use as the origin of the odometry transform in both the <tf_topic> ignition.msgs.Pose_V message and the <odom_topic> ignition.msgs.Odometry message. This element if optional, and the default value is {name_of_model}/odom.
<child_frame_id>: Custom child_frame_id that this system will use as the target of the odometry transform in both the <tf_topic> ignition.msgs.Pose_V message and the <odom_topic> ignition.msgs.Odometry message. This element if optional, and the default value is {name_of_model}/{name_of_link}.
A robot with rear drive and front steering would have one each of left_joint, right_joint, left_steering_joint and right_steering_joint
References: https://github.com/gazebosim/gz-sim/tree/main/src/systems/ackermann_steering https://www.auto.tuwien.ac.at/bib/pdf_TR/TR0183.pdf https://github.com/froohoo/ackermansteer/blob/master/ackermansteer/
◆ AckermannSteering()
◆ ~AckermannSteering()
~AckermannSteering ( )
overridedefault
◆ PostUpdate()
void PreUpdate ( const gz::sim::UpdateInfo &  _info,
gz::sim::EntityComponentManager &  _ecm
