Sensors Class Reference
A system that manages sensors. More...
#include <ignition/gazebo/systems/Sensors.hh>
| Sensors () | |
| Constructor. More... | |
| ~Sensors () override | |
| Destructor. More... | |
| void | Configure (const Entity &_id, const std::shared_ptr< const sdf::Element > &_sdf, EntityComponentManager &_ecm, EventManager &_eventMgr) final |
| void | PostUpdate (const UpdateInfo &_info, const EntityComponentManager &_ecm) final |
| void | Update (const UpdateInfo &_info, EntityComponentManager &_ecm) final |
| System ()=default | |
<render_engine>: Name of the render engine, such as "ogre" or "ogre2".<background_color>: Color used for the scene's background. This will override the background color specified in a world's SDF <scene> element. This background color is used by sensors, not the GUI.<ambient_light>: Color used for the scene's ambient light. This will override the ambient value specified in a world's SDF <scene> element. This ambient light is used by sensors, not the GUI.<disable_on_drained_battery>: Disable sensors if the model's battery plugin charge reaches zero. Sensors that are in nested models are also affected.
\TODO(louise) Have one system for all sensors, or one per sensor / sensor type?
◆ Sensors()
explicit |
◆ ~Sensors()
override |
◆ Configure()
finalvirtual |
◆ PostUpdate()
finalvirtual |
◆ Update()
finalvirtual |
Implements ISystemUpdate.
