PosePublisher Class Reference
Pose publisher system. Attach to an entity to publish the transform of its child entities in the form of gz::msgs::Pose messages, or a single gz::msgs::Pose_V message if "use_pose_vector_msg" is true. More...
#include <PosePublisher.hh>
 PosePublisher ()
 ~PosePublisher () override=default
 Configure the system. More...
The following parameters are used by the system:
publish_link_pose : Set to true to publish link pose publish_visual_pose : Set to true to publish visual pose publish_collision_pose : Set to true to publish collision pose publish_sensor_pose : Set to true to publish sensor pose publish_model_pose : Set to true to publish model pose. publish_nested_model_pose : Set to true to publish nested model pose. The pose of the model that contains this system is also published unless publish_model_pose is set to false use_pose_vector_msg : Set to true to publish an gz::msgs::Pose_V message instead of mulitple gz::msgs::Pose messages. update_frequency : Frequency of pose publications in Hz. A negative frequency publishes as fast as possible (i.e, at the rate of the simulation step) static_publisher : Set to true to publish static poses on a "<scoped_entity_name>/pose_static" topic. This will cause only dynamic poses to be published on the "<scoped_entity_name>/pose" topic. static_update_frequency : Frequency of static pose publications in Hz. A negative frequency publishes as fast as possible (i.e, at the rate of the simulation step).
◆ PosePublisher()
◆ ~PosePublisher()
~PosePublisher ( )
overridedefault
◆ PostUpdate()
