WindEffects Class Reference
A system that simulates a simple wind model. The wind is described as a uniform worldwide model. So it is independent from model position for simple computations. Its components are computed separately: More...
#include <WindEffects.hh>
| WindEffects () | |
| Constructor. More... | |
| ~WindEffects () final | |
| Destructor. More... | |
| void | Configure (const Entity &_entity, const std::shared_ptr< const sdf::Element > &_sdf, EntityComponentManager &_ecm, EventManager &_eventMgr) final |
| void | PreUpdate (const UpdateInfo &_info, EntityComponentManager &_ecm) final |
| System ()=default | |
- Horizontal amplitude: Low pass filtering on user input (complementary gain)
- small local fluctuations
- noise on value (noise amplitude is a factor of wind magnitude)
- Horizontal direction: Low pass filtering on user input (complementary gain)
- noise on value
- Vertical amplitude: Low pass filtering on user input (complementary gain)
- noise on value
The following parameters are used by the system:
<horizontal><magnitude><time_for_rise>: Analogous to the time constant of the low pass filter.<horizontal><magnitude><sin><amplitude_percent>: Fraction of the filtered wind velocity magnitude that is set to be the amplitude of the sinusoid.<horizontal><magnitude><sin><period>: Period of the sinusoid that is added to the wind velocity magnitude.<horizontal><magnitude><noise>: Parameters for the noise that is added to the wind velocity magnitude.<horizontal><direction><time_for_rise>: Analogous to the time constant of the low pass filter.<horizontal><direction><sin><amplitude>: Amplitude of the sinusoidal that is added on the direction of the wind velocity.<horizontal><direction><sin><period>: Period of the sinusoid that is added to the wind velocity direction.<horizontal><direction><noise>: Parameters for the noise that is added to the wind velocity direction.<vertical><time_for_rise>: Analogous to the time constant of the low pass filter for the vertical wind velocity magnitude.<vertical><noise>: Parameters for the noise that is added to the vertical wind velocity magnitude.
◆ WindEffects()
| WindEffects | ( | ) |
◆ ~WindEffects()
final |
◆ Configure()
finalvirtual |
◆ PreUpdate()
finalvirtual |
