ApplyLinkWrench Class Reference
Exposes transport topics and SDF params for applying forces and torques to links in simulation. It should be attached to a world. More...
#include <ApplyLinkWrench.hh>
 ApplyLinkWrench ()
 ~ApplyLinkWrench () override=default
 Configure the system. More...
The target link is defined in each message. If a link entity is provided, that will receive a wrench. If a model is provided, its canonical link will receive it. No other entity types are supported.
Topics
  • /world/<world_name>/wrench
    • Message type: msgs::EntityWrench
    • Effect: Applies the given wrench during a single time step.
  • /world/<world_name>/wrench/persistent
    • Effect: Keeps applying the given wrench every time step. Persistent wrenches can be applied to entities that aren't in simulation yet, and will start taking effect once they do.
  • /world/<world_name>/wrench/clear
    • Effect: Clears any persistent wrenches that are being applied to the given entity.
Persistent wrenches can be defined from SDF, for example:
<persistent>
<entity_name>box</entity_name>
<entity_type>model</entity_type>
<force>-10 0 0</force>
<torque>0 0 0.1</torque>
</persistent>
◆ ApplyLinkWrench()
◆ ~ApplyLinkWrench()
~ApplyLinkWrench ( )
overridedefault
