TouchPlugin Class Reference
Plugin which checks if a model has touched some specific target for a given time continuously and exclusively. After the touch is completed, the plugin is disabled. It can be re-enabled through an Ignition transport service. More...
#include <TouchPlugin.hh>
 TouchPlugin ()
 ~TouchPlugin () override=default
 Configure the system. More...
void PostUpdate (const gz::sim::UpdateInfo &_info, const gz::sim::EntityComponentManager &_ecm) override
It requires that contact sensors be placed in at least one link on the model on which this plugin is attached.
  • <target> Scoped name of the desired collision entity that is checked to see if it's touching this model. This can be a substring of the desired collision name so we match more than one collision. For example, using the name of a model will match all its collisions.
  • <time> Target time in seconds to maintain contact.
  • <namespace> Namespace for transport topics/services:
    • /<namespace>/enable : Service used to enable and disable the plugin.
    • /<namespace>/touched : Topic where a message is published once the touch event occurs.
  • <enabled> Set this to true so the plugin works from the start and doesn't need to be enabled.
◆ TouchPlugin()
◆ ~TouchPlugin()
~TouchPlugin ( )
overridedefault
◆ PostUpdate()
void PostUpdate ( const gz::sim::UpdateInfo &  _info,
const gz::sim::EntityComponentManager &  _ecm
finalvirtual
