ModelPhotoShoot Class Reference
This plugin is a port of the old ModelPropShop plugin from gazebo classic. It generates 5 pictures of a model: perspective, top, front, side and back. It can do it using the default position or moving the joint to random positions. It allows saving the camera and joint poses so it can be replicated in other systems. More...
#include <ModelPhotoShoot.hh>
 ModelPhotoShoot ()
 ~ModelPhotoShoot () override=default
void Configure (const ignition::gazebo::Entity &_id, const std::shared_ptr< const sdf::Element > &_sdf, ignition::gazebo::EntityComponentManager &_ecm, ignition::gazebo::EventManager &_eventMgr) override
 Configure the system. More...
  • <translation_data_file> - Location to save the camera and joint poses. [Optional]
  • <random_joints_pose> - Set to true to take pictures with the joints in random poses instead of the default ones. This option only supports single axis joints. [Optional]
  • A camera sensor must be set in the SDF file as it will be used by the plugin to take the pictures. This allows the plugin user to set the camera parameters as needed. [Required]
Example
An example configuration is installed with Gazebo. The example uses the Ogre2 rendering plugin to set the background color of the pictures. It also includes the camera sensor that will be used along with the corresponding parameters so they can be easily tunned.
ign gazebo model_photo_shoot.sdf -s -r --iterations 50
This will start gazebo, load the model take the pictures and shutdown after 50 iterations. You will find the pictures in the same location you run the command.
System that takes snapshots of an sdf model
◆ ModelPhotoShoot()
◆ ~ModelPhotoShoot()
~ModelPhotoShoot ( )
overridedefault
void Configure ( const ignition::gazebo::Entity _entity,
ignition::gazebo::EntityComponentManager _ecm,
ignition::gazebo::EventManager _eventMgr
void PreUpdate ( const ignition::gazebo::UpdateInfo _info,
