This class provides a simple mechanical bladder which is used to control the buoyancy of an underwater glider. It uses Archimedes' principle to apply an upward force based on the volume of the bladder. It listens to the topic buoyancy_engine or /model/{namespace}/buoyancy_engine topic for the volume of the bladder in cubicmeters.
More...
#include <BuoyancyEngine.hh>
| BuoyancyEnginePlugin () | |
| Constructor. More... | |
| void | Configure (const ignition::gazebo::Entity &_entity, const std::shared_ptr< const sdf::Element > &_sdf, ignition::gazebo::EntityComponentManager &_ecm, ignition::gazebo::EventManager &) |
| void | PreUpdate (const ignition::gazebo::UpdateInfo &_info, ignition::gazebo::EntityComponentManager &_ecm) |
| System ()=default | |
| Destructor. More... | |
<link_name> - The link which the plugin is attached to [required, string] <namespace> - The namespace for the topic. If empty the plugin will listen on buoyancy_engine otherwise it listens on /model/{namespace}/buoyancy_engine [optional, string] <min_volume> - Minimum volume of the engine [optional, float, default=0.00003m^3] <neutral_volume> - At this volume the engine has neutral buoyancy. Used to estimate the weight of the engine [optional, float, default=0.0003m^3] <default_volume> - The volume which the engine starts at [optional, float, default=0.0003m^3] <max_volume> - Maximum volume of the engine [optional, float, default=0.00099m^3] <max_inflation_rate> - Maximum inflation rate for bladder [optional, float, default=0.000003m^3/s] <fluid_density> - The fluid density of the liquid its suspended in kgm^-3. [optional, float, default=1000kgm^-3] <surface> - The Z height in metres at which the surface of the water is. If not defined then there is no surface [optional, float]
Topics
- Subscribes to a ignition::msgs::Double on
buoyancy_engineor/model/{namespace}/buoyancy_engine. This is the set point for the engine. - Publishes a ignition::msgs::Double on
buoyancy_engineor/model/{namespace}/buoyancy_engine/current_volumeon the current volume
Examples
To get started run:
Enter the following in a separate terminal:
To see the box float up.
To see the box go down.
To see the current volume enter:
◆ BuoyancyEnginePlugin()
◆ Configure()
virtual |
◆ PreUpdate()
virtual |
