Physics Class Reference
Base class for a System. More...
#include <ignition/gazebo/systems/Physics.hh>
| Physics () | |
| Constructor. More... | |
| ~Physics () override | |
| Destructor. More... | |
| void | Configure (const Entity &_entity, const std::shared_ptr< const sdf::Element > &_sdf, EntityComponentManager &_ecm, EventManager &_eventMgr) final |
| void | Update (const UpdateInfo &_info, EntityComponentManager &_ecm) final |
| Documentation inherited. More... | |
| System ()=default | |
<include_entity_names>: Optional. When set to false, the name of colliding entities is not populated in the contacts. Remains true by default.
Example
filename="ignition-gazebo-physics-system"
name="ignition::gazebo::systems::Physics">
<contacts>
<include_entity_names>false</include_entity_names>
</contacts>
◆ Physics()
explicit |
◆ ~Physics()
override |
◆ Configure()
finalvirtual |
◆ Update()
finalvirtual |
Implements ISystemUpdate.
