OdometryPublisher Class Reference
Odometry Publisher which can be attached to any entity in order to periodically publish 2D or 3D odometry data in the form of ignition::msgs::Odometry messages. More...
#include <OdometryPublisher.hh>
| OdometryPublisher () | |
| Constructor. More... | |
| ~OdometryPublisher () override=default | |
| Destructor. More... | |
| void | Configure (const Entity &_entity, const std::shared_ptr< const sdf::Element > &_sdf, EntityComponentManager &_ecm, EventManager &_eventMgr) override |
| void | PostUpdate (const UpdateInfo &_info, const EntityComponentManager &_ecm) override |
| void | PreUpdate (const ignition::gazebo::UpdateInfo &_info, ignition::gazebo::EntityComponentManager &_ecm) override |
| System ()=default | |
<odom_frame>: Name of the world-fixed coordinate frame for the is{name_of_model}/odom.<robot_base_frame>: Name of the coordinate frame rigidly attached to the mobile robot base. This element is optional, and the default value is{name_of_model}/base_footprint.<odom_publish_frequency>: Odometry publication frequency. This element is optional, and the default value is 50Hz.<odom_topic>: Custom topic on which this system will publish odometry messages. This element is optional, and the default value is/model/{name_of_model}/odometry.<odom_covariance_topic>: Custom topic on which this system will publish odometry with covariance messages. This element is optional, and the default value is/model/{name_of_model}/odometry_with_covariance.<tf_topic>: Custom topic on which this system will publish the transform fromodom_frametorobot_base_frame. This element is optional, and the default value is/model/{name_of_model}/pose.<dimensions>: Number of dimensions to represent odometry. Only 2 and 3 dimensional spaces are supported. This element is optional, and the default value is 2.<xyz_offset>: Position offset relative to the body fixed frame, the default value is 0 0 0. This offset will be added to the odometry message.<rpy_offset>: Rotation offset relative to the body fixed frame, the default value is 0 0 0. This offset will be added to the odometry message.<gaussian_noise>: Standard deviation of the Gaussian noise to be added to pose and twist messages. This element is optional, and the default value is 0.
◆ OdometryPublisher()
◆ ~OdometryPublisher()
overridedefault |
◆ Configure()
overridevirtual |
◆ PostUpdate()
overridevirtual |
◆ PreUpdate()
overridevirtual |
