A label plugin that annotates models by setting the label for the parent entity's visuals. The plugin can be attached to models, visuals, or actors. More...
#include <Label.hh>
 Label ()
 ~Label () override
void Configure (const Entity &_entity, const std::shared_ptr< const sdf::Element > &_sdf, EntityComponentManager &_ecm, gazebo::EventManager &_eventMgr) final
 Configure the system. More...
Ex: "<label>1</label>" means the visual has a label of 1 Label value must be in [0-255] range
◆ Label()
Label ( )
◆ ~Label()
~Label ( )
gazebo::EventManager &  _eventMgr
finalvirtual
