Hydrodynamics Class Reference
Hydrodynamic damping and current forces for underwater vehicles. More...
#include <Hydrodynamics.hh>
 Hydrodynamics ()
 ~Hydrodynamics () override
void Configure (const ignition::gazebo::Entity &_entity, const std::shared_ptr< const sdf::Element > &_sdf, ignition::gazebo::EntityComponentManager &_ecm, ignition::gazebo::EventManager &) override
Computes linear and quadratic damping (drag) forces in the body frame per Fossen's 6-DOF marine craft model [1][2]. Should be used together with the Buoyancy plugin. The relevant terms from Fossen's equation of motion are:
D(v_r) * v_r
where v_r = v - v_current is the velocity relative to the fluid in the body frame.
Based on Brian Bingham's plugin for VRX.
Added Mass and Coriolis
Added mass and Coriolis forces are also computed by this plugin via the <xDotU>, <yDotV>, etc. parameters using explicit integration. Note that this formulation is only conditionally stable.
SNAME Naming Convention
Damping parameters follow the SNAME (Society of Naval Architects and Marine Engineers) 1950 convention. The first lowercase letter denotes the force/moment axis, and the remaining uppercase letters denote the velocity components:
| Axis | x (surge) | y (sway) | z (heave) | k (roll) | m (pitch) | n (yaw) | |---—|--------—|-------—|--------—|-------—|--------—| |------—| | Velocity | U | V | W | P | Q | R |
For example, <yVabsV> is the quadratic drag on the sway axis due to |V|*V, and <nR> is the linear yaw damping due to yaw rate R.
Required
  • <link_name> - Link to apply hydrodynamic forces to. [string]
Damping (Drag)
Diagonal terms:
  • <xU> - Linear damping, surge [kg/s]
  • <yV> - Linear damping, sway [kg/s]
  • <zW> - Linear damping, heave [kg/s]
  • <kP> - Linear damping, roll [kgm^2/s]
  • <mQ> - Linear damping, pitch [kgm^2/s]
  • <nR> - Linear damping, yaw [kgm^2/s]
  • <xUabsU> - Quadratic abs damping, surge [kg/m]
  • <yVabsV> - Quadratic abs damping, sway [kg/m]
  • <zWabsW> - Quadratic abs damping, heave [kg/m]
  • <kPabsP> - Quadratic abs damping, roll [kgm^2/rad^2]
  • <mQabsQ> - Quadratic abs damping, pitch [kgm^2/rad^2]
  • <nRabsR> - Quadratic abs damping, yaw [kgm^2/rad^2]
Cross terms and off-diagonal entries follow the same pattern:
  • Linear: <{x|y|z|k|m|n}{U|V|W|P|Q|R}> e.g. <xR>
  • Quadratic abs (recommended): <{x|y|z|k|m|n}{U|V|W|P|Q|R}abs{U|V|W|P|Q|R}> e.g. <xRabsQ>
  • Quadratic (may cause oscillations): <{x|y|z|k|m|n}{U|V|W|P|Q|R}{U|V|W|P|Q|R}> e.g. <xRQ>
All damping coefficients default to 0.
Added Mass
Fossen sign convention (values should be negative):
  • <xDotU> - Added mass, surge [kg]
  • <yDotV> - Added mass, sway [kg]
  • <zDotW> - Added mass, heave [kg]
  • <kDotP> - Added mass, roll [kgm^2]
  • <mDotQ> - Added mass, pitch [kgm^2]
  • <nDotR> - Added mass, yaw [kgm^2]
  • Cross terms: <{x|y|z|k|m|n}Dot{U|V|W|P|Q|R}> e.g. <xDotR>
Ocean Current
  • <default_current> - Constant current velocity in world frame. [gz::math::Vector3d, default: 0 0 0, m/s]
  • <namespace> - If set, the plugin subscribes to /model/<namespace>/ocean_current instead of /ocean_current. Useful for per-vehicle currents in multi-robot scenarios. [string, optional]
Currents can also be loaded from data files via the EnvironmentPreload system. If any lookup_current_* tag is present, topic-based currents are ignored:
  • <lookup_current_x> - CSV column for x current [string]
  • <lookup_current_y> - CSV column for y current [string]
  • <lookup_current_z> - CSV column for z current [string]
Feature Flags
  • <disable_coriolis> - Disable Coriolis force. [bool, default: false]
  • <disable_added_mass> - Disable added mass. [bool, default: false]
Example
Typical configuration for an AUV (MBARI Tethys LRAUV):
<plugin filename="ignition-gazebo-hydrodynamics-system"
name="ignition::gazebo::systems::Hydrodynamics">
<link_name>base_link</link_name>
<xDotU>-4.876161</xDotU>
<yDotV>-126.324739</yDotV>
<zDotW>-126.324739</zDotW>
<kDotP>0</kDotP>
<mDotQ>-33.46</mDotQ>
<nDotR>-33.46</nDotR>
<xUabsU>-6.2282</xUabsU>
<yVabsV>-601.27</yVabsV>
<zWabsW>-601.27</zWabsW>
<kPabsP>-0.1916</kPabsP>
<mQabsQ>-632.698957</mQabsQ>
<nRabsR>-632.698957</nRabsR>
A complete working example is available in examples/worlds/auv_controls.sdf. Run it with:
ign gazebo auv_controls.sdf
To control the rudder of the craft run the following
ign topic -t /model/tethys/joint/vertical_fins_joint/0/cmd_pos
-m ignition.msgs.Double -p 'data: -0.17'
Definition: gz/sim/comms/Broker.hh:31
To apply a thrust you may run the following command
ign topic -t /model/tethys/joint/propeller_joint/cmd_pos
-m ignition.msgs.Double -p 'data: -31'
The vehicle should move in a circle.
Ocean Currents
When underwater, vehicles are often subject to ocean currents. The hydrodynamics plugin allows simulation of such currents. We can add a current simply by publishing the following:
ign topic -t /ocean_current -m ignition.msgs.Vector3d -p 'x: 1, y:0, z:0'
You should observe your vehicle slowly drift to the side.
References
[1] Fossen, T. I. "Guidance and Control of Ocean Vehicles." Wiley, 1994. [2] Fossen, T. I. "Handbook of Marine Craft Hydrodynamics and Motion Control." Wiley, 2011.
◆ Hydrodynamics()
◆ ~Hydrodynamics()
~Hydrodynamics ( )
void Configure ( const ignition::gazebo::Entity &  _entity,
ignition::gazebo::EntityComponentManager &  _ecm,
void PreUpdate ( const ignition::gazebo::UpdateInfo &  _info,
