VelocityControl Class Reference
Linear and angular velocity controller which is directly set on a model. More...
#include <VelocityControl.hh>
 VelocityControl ()
 ~VelocityControl () override=default
 Configure the system. More...
void PreUpdate (const gz::sim::UpdateInfo &, gz::sim::EntityComponentManager &_ecm) override
  • <topic>: Topic to receive commands in. Defaults to /model/<model_name>/cmd_vel.
  • <initial_linear>: Linear velocity to start with.
  • <initial_angular>: Linear velocity to start with.
◆ VelocityControl()
◆ ~VelocityControl()
~VelocityControl ( )
overridedefault
◆ PostUpdate()
void PreUpdate ( const gz::sim::UpdateInfo &  ,
gz::sim::EntityComponentManager &  _ecm
