UserCommands Class Reference
This system provides an Ignition Transport interface to execute commands while simulation is running. More...
#include <UserCommands.hh>
 UserCommands ()
 ~UserCommands () final
 Configure the system. More...
 All received commands are queued in order of reception and executed in order during PreUpdate. More...
Todo:
(louise) In the future, an interface undo/redo commands will also be provided.
Spawn entity
  • Service: /world/<world name>/create
  • **Request type*: ignition.msgs.EntityFactory
  • **Response type*: ignition.msgs.Boolean
Spawn multiple entities
This service can spawn multiple entities in the same iteration, thereby eliminating simulation steps between entity spawn times.
  • Service: /world/<world name>/create_multiple
  • **Request type*: ignition.msgs.EntityFactory_V
Set entity pose
This service set the pose of entities
  • Service: /world/<world name>/set_pose
  • **Request type*: ignition.msgs.Pose
Set multiple entity poses
This service set the pose of multiple entities
  • Service: /world/<world name>/set_pose_vector
  • **Request type*: ignition.msgs.Pose_V
Try some examples described on examples/worlds/empty.sdf
◆ UserCommands()
UserCommands ( )
◆ ~UserCommands()
~UserCommands ( )
final
EntityComponentManager _ecm,
EventManager _eventMgr
void PreUpdate ( const UpdateInfo _info,
finalvirtual
[in]_infoContains information about the current simulation iteration.
[in]_ecmThe entity component manager.
