ParticleEmitter2 Class Reference
A system for running and managing particle emitters. A particle emitter is defined using the <particle_emitter> SDF element. More...
#include <ParticleEmitter2.hh>
 ParticleEmitter2 ()
 Configure the system. More...
This system will create a transport subscriber for each <particle_emitter> using the child <topic> name. If a <topic> is not specified, the following topic naming scheme will be used: /model/{model_name}/link/{link_name}/particle_emitter/{emitter_name}/cmd
Todo:
(nkoenig) Plan for ParticleEmitter and ParticleEmitter2:
  1. Deprecate ParticleEmitter in Ignition Fortress.
  2. Remove ParticleEmitter in Ignition G.
  3. Copy ParticleEmitter2 to ParticleEmitter in Ignition G.
  4. Deprecrate ParticleEmitter2 in Ignition G.
  5. Remove ParticleEmitter2 in Ignition H.
◆ ParticleEmitter2()
EntityComponentManager _ecm,
EventManager _eventMgr
void PreUpdate ( const ignition::gazebo::UpdateInfo _info,
ignition::gazebo::EntityComponentManager _ecm
