This class provides wrappers around entities and components which are more convenient and straight-forward to use than dealing with the EntityComponentManager directly. All the functions provided here are meant to be used with a link entity. More...
#include <ignition/gazebo/Link.hh>
 Link (const Link &_link)
 Copy constructor. More...
 Link (gz::sim::Entity _entity=kNullEntity)
 Link (Link &&_link) noexcept
 Move constructor. More...
 ~Link ()
void AddWorldForce (EntityComponentManager &_ecm, const math::Vector3d &_force) const
 Add a force expressed in world coordinates and applied at the center of mass of the link. More...
void AddWorldForce (EntityComponentManager &_ecm, const math::Vector3d &_force, const math::Vector3d &_position) const
 Add a force expressed in world coordinates and applied at an offset from the center of mass of the link. More...
void AddWorldWrench (EntityComponentManager &_ecm, const math::Vector3d &_force, const math::Vector3d &_torque) const
 Add a wrench expressed in world coordinates and applied to the link at the link's origin. This wrench is applied for one simulation step. More...
gz::sim::Entity CollisionByName (const EntityComponentManager &_ecm, const std::string &_name) const
 Get the ID of a collision entity which is an immediate child of this link. More...
uint64_t CollisionCount (const EntityComponentManager &_ecm) const
 Get the number of collisions which are immediate children of this link. More...
std::vector< gz::sim::EntityCollisions (const EntityComponentManager &_ecm) const
 Get all collisions which are immediate children of this link. More...
void EnableAccelerationChecks (EntityComponentManager &_ecm, bool _enable=true) const
 By default, Gazebo will not report accelerations for a link, so functions like WorldLinearAcceleration will return nullopt. This function can be used to enable all acceleration checks. More...
void EnableVelocityChecks (EntityComponentManager &_ecm, bool _enable=true) const
 By default, Gazebo will not report velocities for a link, so functions like WorldLinearVelocity will return nullopt. This function can be used to enable all velocity checks. More...
gz::sim::Entity Entity () const
 Get the entity which this Link is related to. More...
bool IsCanonical (const EntityComponentManager &_ecm) const
 Check if this is the canonical link. More...
std::optional< std::stringName (const EntityComponentManager &_ecm) const
 Get the link's unscoped name. More...
Linkoperator= (const Link &_link)
 Copy assignment operator. More...
Linkoperator= (Link &&_link) noexcept
 Move assignment operator. More...
std::optional< ModelParentModel (const EntityComponentManager &_ecm) const
 Get the parent model. More...
void ResetEntity (gz::sim::Entity _newEntity)
 Reset Entity to a new one. More...
void SetAngularVelocity (EntityComponentManager &_ecm, const math::Vector3d &_vel) const
 Set the angular velocity on this link. If this is set, wrenches on this link will be ignored for the current time step. More...
void SetLinearVelocity (EntityComponentManager &_ecm, const math::Vector3d &_vel) const
 Set the linear velocity on this link. If this is set, wrenches on this link will be ignored for the current time step. More...
 Check whether this link correctly refers to an entity that has a components::Link. More...
gz::sim::Entity VisualByName (const EntityComponentManager &_ecm, const std::string &_name) const
 Get the ID of a visual entity which is an immediate child of this link. More...
uint64_t VisualCount (const EntityComponentManager &_ecm) const
 Get the number of visuals which are immediate children of this link. More...
std::vector< gz::sim::EntityVisuals (const EntityComponentManager &_ecm) const
 Get all visuals which are immediate children of this link. More...
bool WindMode (const EntityComponentManager &_ecm) const
 Get whether this link has wind enabled. More...
std::optional< math::Vector3d > WorldAngularAcceleration (const EntityComponentManager &_ecm) const
 Get the angular acceleration of the body in the world frame. More...
std::optional< math::Vector3d > WorldAngularVelocity (const EntityComponentManager &_ecm) const
 Get the angular velocity of the link in the world frame. More...
std::optional< math::Pose3d > WorldInertialPose (const EntityComponentManager &_ecm) const
 Get the world pose of the link inertia. More...
std::optional< math::Matrix3d > WorldInertiaMatrix (const EntityComponentManager &_ecm) const
 Get the inertia matrix in the world frame. More...
std::optional< double > WorldKineticEnergy (const EntityComponentManager &_ecm) const
 Get the rotational and translational kinetic energy of the link with respect to the world frame. More...
std::optional< math::Vector3d > WorldLinearAcceleration (const EntityComponentManager &_ecm) const
 Get the linear acceleration of the body in the world frame. More...
std::optional< math::Vector3d > WorldLinearVelocity (const EntityComponentManager &_ecm) const
 Get the linear velocity at the origin of of the link frame expressed in the world frame, using an offset expressed in a body-fixed frame. If no offset is given, the velocity at the origin of the Link frame will be returned. More...
std::optional< math::Vector3d > WorldLinearVelocity (const EntityComponentManager &_ecm, const math::Vector3d &_offset) const
 Get the linear velocity of a point on the body in the world frame, using an offset expressed in a body-fixed frame. More...
std::optional< math::Pose3d > WorldPose (const EntityComponentManager &_ecm) const
 Get the pose of the link frame in the world coordinate frame. More...
For example, given a link's entity, to find the value of its name component, one could use the entity-component manager (ecm) directly as follows:
Link link(entity); std::string name = link.Name(ecm);
◆ Link() [1/3]
Link ( gz::sim::Entity  _entity = kNullEntity)
[in]_entityLink entity
◆ Link() [2/3]
Link ( const Link _link)
Copy constructor.
[in]_linkLink to copy.
◆ Link() [3/3]
Link ( Link &&  _link)
noexcept
Move constructor.
[in]_linkLink to move.
◆ ~Link()
~Link ( )
◆ AddWorldForce() [1/2]
void AddWorldForce ( EntityComponentManager _ecm,
const math::Vector3d &  _force
) const
[in]_ecmMutable Entity-component manager.
[in]_forceForce to be applied expressed in world coordinates
◆ AddWorldForce() [2/2]
const math::Vector3d &  _force,
const math::Vector3d &  _position
) const
[in]_positionThe point of application of the force expressed in the link-fixed frame.
◆ AddWorldWrench()
void AddWorldWrench ( EntityComponentManager _ecm,
const math::Vector3d &  _torque
) const
[in]_torqueTorque to be applied expressed in world coordinates
◆ CollisionByName()
gz::sim::Entity CollisionByName ( const EntityComponentManager _ecm,
const std::string _name
) const
[in]_nameCollision name.
Collision entity.
◆ CollisionCount()
uint64_t CollisionCount ( const EntityComponentManager _ecm) const
Number of collisions in this link.
◆ Collisions()
std::vector<gz::sim::Entity> Collisions ( const EntityComponentManager _ecm) const
All collisions in this link.
◆ EnableAccelerationChecks()
void EnableAccelerationChecks ( EntityComponentManager _ecm,
bool  _enable = true
) const
[in]_ecmMutable reference to the ECM.
[in]_enableTrue to enable checks, false to disable. Defaults to true.
◆ EnableVelocityChecks()
void EnableVelocityChecks ( EntityComponentManager _ecm,
bool  _enable = true
) const
◆ Entity()
Link entity.
◆ IsCanonical()
bool IsCanonical ( const EntityComponentManager _ecm) const
True if it is the canonical link.
◆ Name()
std::optional<std::string> Name ( const EntityComponentManager _ecm) const
Link's name or nullopt if the entity does not have a components::Name component
◆ operator=() [1/2]
Link& operator= ( const Link _link)
Reference to this.
◆ operator=() [2/2]
Link& operator= ( Link &&  _link)
noexcept
[in]_linkLink component to move.
Reference to this.
◆ ParentModel()
std::optional<Model> ParentModel ( const EntityComponentManager _ecm) const
Parent Model or nullopt if the entity does not have a components::ParentEntity component.
◆ ResetEntity()
void ResetEntity ( gz::sim::Entity  _newEntity)
[in]_newEntityNew link entity.
◆ SetAngularVelocity()
void SetAngularVelocity ( EntityComponentManager _ecm,
const math::Vector3d &  _vel
) const
[in]_ecmEntity Component manager.
[in]_velAngular velocity to set in Link's Frame.
◆ SetLinearVelocity()
void SetLinearVelocity ( EntityComponentManager _ecm,
) const
[in]_velLinear velocity to set in Link's Frame.
◆ Valid()
bool Valid ( const EntityComponentManager _ecm) const
True if it's a valid link in the manager.
◆ VisualByName()
gz::sim::Entity VisualByName ( const EntityComponentManager _ecm,
) const
[in]_nameVisual name.
Visual entity.
◆ VisualCount()
uint64_t VisualCount ( const EntityComponentManager _ecm) const
Number of visuals in this link.
◆ Visuals()
std::vector<gz::sim::Entity> Visuals ( const EntityComponentManager _ecm) const
All visuals in this link.
◆ WindMode()
bool WindMode ( const EntityComponentManager _ecm) const
True if wind mode is on.
◆ WorldAngularAcceleration()
std::optional<math::Vector3d> WorldAngularAcceleration ( const EntityComponentManager _ecm) const
Angular acceleration of the body in the world frame or nullopt if acceleration checks aren't enabled.
◆ WorldAngularVelocity()
std::optional<math::Vector3d> WorldAngularVelocity ( const EntityComponentManager _ecm) const
Angular velocity of the link or nullopt if velocity checks aren't enabled.
◆ WorldInertialPose()
std::optional<math::Pose3d> WorldInertialPose ( const EntityComponentManager _ecm) const
Inertial pose in world frame or nullopt if the link does not have the components components::WorldPose and components::Inertial.
◆ WorldInertiaMatrix()
std::optional<math::Matrix3d> WorldInertiaMatrix ( const EntityComponentManager _ecm) const
Inertia matrix in world frame, returns nullopt if link does not have components components::Inertial and components::WorldPose.
◆ WorldKineticEnergy()
std::optional<double> WorldKineticEnergy ( const EntityComponentManager _ecm) const
Kinetic energy in world frame, returns nullopt if link does not have components components::Inertial, components::WorldAngularVelocity, components::WorldLinearVelocity, and components::WorldPose.
◆ WorldLinearAcceleration()
std::optional<math::Vector3d> WorldLinearAcceleration ( const EntityComponentManager _ecm) const
Linear acceleration of the body in the world frame or nullopt if acceleration checks aren't enabled.
◆ WorldLinearVelocity() [1/2]
std::optional<math::Vector3d> WorldLinearVelocity ( const EntityComponentManager _ecm) const
Linear velocity of the link or nullopt if the velocity checks aren't enabled.
◆ WorldLinearVelocity() [2/2]
std::optional<math::Vector3d> WorldLinearVelocity ( const EntityComponentManager _ecm,
const math::Vector3d &  _offset
) const
[in]_offsetOffset of the point from the origin of the Link frame, expressed in the body-fixed frame.
Linear velocity of the point on the body or nullopt if velocity checks aren't enabled.
◆ WorldPose()
std::optional<math::Pose3d> WorldPose ( const EntityComponentManager _ecm) const
Absolute Pose of the link or nullopt if the entity does not have a components::WorldPose component.
