Physics data plotting handler that keeps track of the registered components, update them and update the plot. More...
#include <Plotting.hh>
Public Slots
std::string ComponentName (const uint64_t &_typeId)
 Get Component Name based on its type Id. More...
void RegisterChartToComponent (uint64_t _entity, uint64_t _typeId, std::string _type, std::string _attribute, int _chart)
 Add a chart to a specefic component attribute. More...
void UnRegisterChartFromComponent (uint64_t _entity, uint64_t _typeId, std::string _attribute, int _chart)
 Remove a chart from a specefic component attribute. More...
 Plotting ()
 ~Plotting ()
void LoadConfig (const tinyxml2::XMLElement *) override
void SetData (std::string _Id, const double &_value)
 Set the Component data of given id to the given number. More...
void SetData (std::string _Id, const ignition::math::Pose3d &_pose)
 Set the Component data of given id to the given pose. More...
void SetData (std::string _Id, const ignition::math::Vector3d &_vector)
 Set the Component data of given id to the given vector. More...
void SetData (std::string _Id, const math::SphericalCoordinates &_sc)
 Set the Component data of given id to the given spherical coordinates. More...
void SetData (std::string _Id, const msgs::Light &_light)
 Set the Component data of given id to the given light. More...
void SetData (std::string _Id, const sdf::Physics &_physics)
 Set the Component data of given id to the given physics properties. More...
void Update (const ignition::gazebo::UpdateInfo &_info, ignition::gazebo::EntityComponentManager &_ecm) override
 Update callback called every time the system is stepped. This is called at an Ignition transport thread, so any interaction with Qt should be done through signals and slots. More...
◆ Plotting()
Plotting ( )
◆ ~Plotting()
~Plotting ( )
◆ ComponentName
std::string ComponentName ( const uint64_t &  _typeId)
slot
[in]_typeIdtype Id of the component
Component name
◆ LoadConfig()
void LoadConfig ( const tinyxml2::XMLElement *  )
◆ RegisterChartToComponent
void RegisterChartToComponent ( uint64_t  _entity,
uint64_t  _typeId,
std::string  _type,
int  _chart
slot
[in]_entityentity id in the simulation
[in]_typeIdtype identifier unique to each component type
[in]_typeComponent Datatype ("Pose3d","Vector3d","double")
[in]_attributecomponent attribute to add the chart to it ex: x attribute in Pose3d Component will be "x"
[in]_chartchart ID to be registered
◆ SetData() [1/6]
void SetData ( std::string  _Id,
const double &  _value
[in]_IdComponent Key of the components map
[in]_valuedouble Data to be set to the component valid for types (double, float, int, bool)
◆ SetData() [2/6]
const ignition::math::Pose3d &  _pose
[in]_posePosition Data to be set to the component
◆ SetData() [3/6]
const ignition::math::Vector3d &  _vector
[in]_vectorVector Data to be set to the component
◆ SetData() [4/6]
const math::SphericalCoordinates &  _sc
[in]_scData to be set to the component
◆ SetData() [5/6]
const msgs::Light &  _light
[in]_lightVector Data to be set to the component
◆ SetData() [6/6]
const sdf::Physics &  _physics
[in]_valuephysics Data to be set to the component
◆ UnRegisterChartFromComponent
void UnRegisterChartFromComponent ( uint64_t  _entity,
uint64_t  _typeId,
int  _chart
slot
[in]_attributecomponent attribute to remove the chart from it ex: x attribute in Pose3d Component will be "x"
[in]_chartchart ID to be unregistered
void Update ( const ignition::gazebo::UpdateInfo _info,
ignition::gazebo::EntityComponentManager _ecm
Reimplemented from GuiSystem.
