A QQUickItem that manages the render window. More...
#include <Scene3D.hh>
Public Slots
void OnContextMenuRequested (QString _entity)
 Qt callback when context menu request is received. More...
void Ready ()
 Slot called when thread is ready to be started. More...
void SetFollowTarget (const std::string &_target, bool _waitForTarget=false)
 Move the user camera to follow the specified target. More...
Signals
void openContextMenu (QString _entity)
 Signal fired to open context menu Note that the function name needs to start with lowercase in order for the connection to work on the QML side. More...
 RenderWindowItem (QQuickItem *_parent=nullptr)
 ~RenderWindowItem () override
math::Pose3d CameraPose () const
 Get the user camera pose. More...
void DeselectAllEntities (bool _sendEvent)
 Deselect all the currently selected entities within the RenderUtil class. More...
void HandleKeyPress (QKeyEvent *_e)
 Handle key press event for snapping. More...
void HandleKeyRelease (QKeyEvent *_e)
 Handle key release event for snapping. More...
void OnHovered (const gz::math::Vector2i &_hoverPos)
 Called when the mouse hovers to a new position. More...
bool RendererInitialized () const
 Get whether the renderer is initialized. The renderer is initialized when the context is created and the render thread is started. More...
class RenderUtil * RenderUtil () const
 Set the renderer. More...
math::Vector3d ScreenToScene (const math::Vector2i &_screenPos)
 Retrieve the first point on a surface in the 3D scene hit by a ray cast from the given 2D screen coordinates. More...
void SetCameraPose (const math::Pose3d &_pose)
 Set the initial user camera pose. More...
void SetDropdownMenuEnabled (bool _enableDropdownMenu)
 Set if the dropdown menu is enabled or disabled. More...
void SetErrorCb (std::function< void(const QString &)> _cb)
 Set a callback to be called in case there are errors. More...
void SetFollowOffset (const math::Vector3d &_offset)
 Set the camera follow offset position. More...
void SetFollowPGain (double _gain)
 Set the p gain for the camera follow movement. More...
void SetFollowWorldFrame (bool _worldFrame)
 True to set the camera to follow the target in world frame, false to follow in target's local frame. More...
void SetInitCameraPose (const math::Pose3d &_pose)
void SetModel (const std::string &_model)
 Set the model to hover. More...
void SetModelPath (const std::string &_filePath)
 Set the path of the model to hover. More...
void SetMoveTo (const std::string &_target)
 Move the user camera to move to the specified target. More...
void SetMoveToPose (const math::Pose3d &_pose)
 Set the pose of the camera. More...
void SetRecordVideo (bool _record, const std::string &_format, const std::string &_savePath)
 Set whether to record video. More...
void SetRecordVideoBitrate (unsigned int _bitrate)
 Set video recorder bitrate in bps. More...
void SetRecordVideoLockstep (bool _lockstep)
 Set whether to record video in lockstep mode. More...
void SetRecordVideoUseSimTime (bool _useSimTime)
 Set whether to record video using sim time as timestamp. More...
void SetRPYSnap (const math::Vector3d &_rpy)
 Set the RPY snap values from the user input. More...
void SetScaleSnap (const math::Vector3d &_scale)
 Set the scale snap values from the user input. More...
void SetTransformMode (const std::string &_mode)
 Set the transform mode. More...
void SetViewAngle (const math::Vector3d &_direction)
 Set the viewing angle of the camera. More...
void SetViewCollisionsTarget (const std::string &_target)
 View collisions of the specified target. More...
void SetViewCOMTarget (const std::string &_target)
 View center of mass of the specified target. More...
void SetViewController (const std::string &_viewController)
 Set camera view controller. More...
void SetViewInertiaTarget (const std::string &_target)
 View inertia of the specified target. More...
void SetViewJointsTarget (const std::string &_target)
 View joints of the specified target. More...
void SetViewTransparentTarget (const std::string &_target)
 View the specified target as transparent. More...
void SetViewWireframesTarget (const std::string &_target)
 View wireframes of the specified target. More...
void SetVisibilityMask (uint32_t _mask)
 Set the user camera visibility mask. More...
void SetWorldName (const std::string &_name)
 Set the world name. More...
void SetXYZSnap (const math::Vector3d &_xyz)
 Set the XYZ snap values from the user input. More...
void UpdateSelectedEntity (Entity _entity, bool _sendEvent)
 An update function to apply the rules of selection to the passed in node. The rules are as follows: More...
void mouseMoveEvent (QMouseEvent *_e) override
void mousePressEvent (QMouseEvent *_e) override
void mouseReleaseEvent (QMouseEvent *_e) override
void wheelEvent (QWheelEvent *_e) override
◆ RenderWindowItem()
RenderWindowItem ( QQuickItem *  _parent = nullptr)
[in]_parentParent item
◆ ~RenderWindowItem()
~RenderWindowItem ( )
◆ CameraPose()
math::Pose3d CameraPose ( ) const
Pose of the user camera.
◆ DeselectAllEntities()
void DeselectAllEntities ( bool  _sendEvent)
[in]_sendEventTrue to notify other widgets. This should be true when the deselection is initiated from this plugin.
◆ HandleKeyPress()
void HandleKeyPress ( QKeyEvent *  _e)
[in]_eThe key event to process.
◆ HandleKeyRelease()
void HandleKeyRelease ( QKeyEvent *  _e)
◆ mouseMoveEvent()
void mouseMoveEvent ( QMouseEvent *  _e)
overrideprotected
◆ mousePressEvent()
void mousePressEvent ( QMouseEvent *  _e)
overrideprotected
◆ mouseReleaseEvent()
void mouseReleaseEvent ( QMouseEvent *  _e)
overrideprotected
◆ OnContextMenuRequested
void OnContextMenuRequested ( QString  _entity)
slot
[in]_entityScoped name of entity.
◆ OnHovered()
void OnHovered ( const gz::math::Vector2i &  _hoverPos)
[in]_hoverPos2D coordinates of the hovered mouse position on the render window.
◆ openContextMenu
void openContextMenu ( QString  _entity)
signal
◆ Ready
void Ready ( )
slot
◆ RendererInitialized()
bool RendererInitialized ( ) const
True if the renderer is initialized.
◆ RenderUtil()
class RenderUtil* RenderUtil ( ) const
Set the renderer.
◆ ScreenToScene()
math::Vector3d ScreenToScene ( const math::Vector2i &  _screenPos)
[in]_screenPos2D coordinates on the screen, in pixels.
3D coordinates of a point in the 3D scene.
◆ SetCameraPose()
void SetCameraPose ( const math::Pose3d &  _pose)
[in]_posePose to set the camera to
◆ SetDropdownMenuEnabled()
void SetDropdownMenuEnabled ( bool  _enableDropdownMenu)
[in]_enableDropdownMenuThe boolean to enable or disable the menu
◆ SetErrorCb()
void SetErrorCb ( std::function< void(const QString &)>  _cb)
[in]_cbError callback
◆ SetFollowOffset()
void SetFollowOffset ( const math::Vector3d &  _offset)
[in]_offsetCamera follow offset position.
◆ SetFollowPGain()
void SetFollowPGain ( double  _gain)
[in]_gainCamera follow p gain.
◆ SetFollowTarget
void SetFollowTarget ( const std::string &  _target,
bool  _waitForTarget = false
slot
[in]_targetTarget to follow
[in]_waitForTargetTrue to continuously look for the target to follow. A typical use case is follow a target that is not present on startup but spawned later into simulation
◆ SetFollowWorldFrame()
void SetFollowWorldFrame ( bool  _worldFrame)
[in]_worldFrameTrue to use the world frame.
◆ SetInitCameraPose()
void SetInitCameraPose ( const math::Pose3d &  _pose)
◆ SetModel()
void SetModel ( const std::string &  _model)
[in]_modelSdf string of the model to load in for the user.
◆ SetModelPath()
void SetModelPath ( const std::string &  _filePath)
[in]_filePathFile path of the model to load in for the user.
◆ SetMoveTo()
void SetMoveTo ( const std::string &  _target)
[in]_targetTarget to move the camera to
◆ SetMoveToPose()
void SetMoveToPose ( const math::Pose3d &  _pose)
[in]_poseThe new camera pose in the world frame.
◆ SetRecordVideo()
void SetRecordVideo ( bool  _record,
const std::string &  _format,
const std::string &  _savePath
[in]_recordTrue to start video recording, false to stop.
[in]_formatVideo encoding format: "mp4", "ogv"
[in]_savePathPath to save the recorded video.
◆ SetRecordVideoBitrate()
void SetRecordVideoBitrate ( unsigned int  _bitrate)
[in]_bitrateBit rate to set to
◆ SetRecordVideoLockstep()
void SetRecordVideoLockstep ( bool  _lockstep)
[in]_lockstepTrue to record video in lockstep mode
◆ SetRecordVideoUseSimTime()
void SetRecordVideoUseSimTime ( bool  _useSimTime)
[in]_useSimTimeTrue record video using sim time
◆ SetRPYSnap()
void SetRPYSnap ( const math::Vector3d &  _rpy)
[in]_rpyThe RPY snap values
◆ SetScaleSnap()
void SetScaleSnap ( const math::Vector3d &  _scale)
[in]_scaleThe scale snap values
◆ SetTransformMode()
void SetTransformMode ( const std::string &  _mode)
[in]_modeNew transform mode to set to
◆ SetViewAngle()
void SetViewAngle ( const math::Vector3d &  _direction)
[in]_directionThe pose to assume relative to the entit(y/ies). (0, 0, 0) indicates to return the camera back to the home pose originally loaded in from the sdf
◆ SetViewCollisionsTarget()
void SetViewCollisionsTarget ( const std::string &  _target)
[in]_targetTarget to view collisions
◆ SetViewCOMTarget()
void SetViewCOMTarget ( const std::string &  _target)
[in]_targetTarget to view center of mass
◆ SetViewController()
void SetViewController ( const std::string &  _viewController)
[in]_viewController.Values are "orbit", and "ortho"
◆ SetViewInertiaTarget()
void SetViewInertiaTarget ( const std::string &  _target)
[in]_targetTarget to view inertia
◆ SetViewJointsTarget()
void SetViewJointsTarget ( const std::string &  _target)
[in]_targetTarget to view joints
◆ SetViewTransparentTarget()
void SetViewTransparentTarget ( const std::string &  _target)
[in]_targetTarget to view as transparent
◆ SetViewWireframesTarget()
void SetViewWireframesTarget ( const std::string &  _target)
[in]_targetTarget to view wireframes
◆ SetVisibilityMask()
void SetVisibilityMask ( uint32_t  _mask)
[in]_maskVisibility mask to set to
◆ SetWorldName()
void SetWorldName ( const std::string &  _name)
Set the world name.
[in]_nameName of the world to set to.
◆ SetXYZSnap()
void SetXYZSnap ( const math::Vector3d &  _xyz)
[in]_xyzThe XYZ snap values
◆ UpdateSelectedEntity()
void UpdateSelectedEntity ( Entity  _entity,
bool  _sendEvent
  • If control is held, append the node to the selected entity list.
  • If control is not held, deselect all other entities.
  • If the user is currently in a transform mode, attach the control to the latest selected node and deselect all others. Note that this function emits events to update other widgets.
    [in]_entityThe entity to select.
    [in]_sendEventTrue to notify other widgets. This should be true when the selection is initiated from this plugin.
◆ wheelEvent()
void wheelEvent ( QWheelEvent *  _e)
overrideprotected
