RenderUtil Class Reference
#include <ignition/gazebo/gui/plugins/RenderUtil.hh>
 RenderUtil ()
 ~RenderUtil ()
void CreateVisualsForEntities (const EntityComponentManager &_ecm, const std::set< Entity > &_entities)
 Helper function to create visuals for new entities created in ECM. This function is intended to be used by other GUI plugins when new entities are created on the GUI side. More...
void DeselectAllEntities ()
 Clears the set of selected entities and lowlights all of them. More...
std::string EngineName () const
 Get the name of the rendering engine used. More...
bool HeadlessRendering () const
 Get the headless mode. More...
void Init ()
 Initialize the renderer. Must be called in the rendering thread. More...
void InitRenderEnginePluginPaths ()
 Init render engine plugins paths. This lets gz-rendering know paths to find render engine plugins. More...
class MarkerManagerMarkerManager ()
 Get the marker manager Returns reference to the marker manager. More...
int PendingSensors () const
 Count of pending sensors. Must be called in the rendering thread. More...
 Get a pointer to the scene. More...
class SceneManagerSceneManager ()
 Get the scene manager Returns reference to the scene manager. More...
std::string SceneName () const
 Get the name of the rendering scene used. More...
const std::vector< Entity > & SelectedEntities () const
 Get the entities currently selected, in order of selection. More...
void SetAmbientLight (const math::Color &_ambient)
 Set ambient light of render window. This will override other sources, such as from SDF. More...
void SetBackgroundColor (const math::Color &_color)
 Set background color of render window. This will override other sources, such as from SDF. More...
void SetEnableSensors (bool _enable, std::function< std::string(const gazebo::Entity &, const sdf::Sensor &, const std::string &)> _createSensorCb={})
 Set whether to create rendering sensors. More...
void SetEngineName (const std::string &_engineName)
 Set the rendering engine to use. More...
void SetEventManager (EventManager *_mgr)
 Set the event manager to use. More...
void SetHeadlessRendering (const bool &_headless)
 Set the headless mode. More...
void SetRemoveSensorCb (std::function< void(const gazebo::Entity &)> _removeSensorCb)
 Set the callback function for removing the sensors. More...
void SetScene (const rendering::ScenePtr &_scene)
 Set the scene to use. More...
void SetSceneName (const std::string &_sceneName)
void SetSelectedEntity (const rendering::NodePtr &_node)
 Set the entity being selected. More...
void SetSkyEnabled (bool _enabled)
 Set whether to enable sky in the scene. More...
void SetTransformActive (bool _active)
 Set whether the transform controls are currently being dragged. More...
void SetUseCurrentGLContext (bool _enable)
 Set whether to use the current GL context. More...
void SetWinID (const std::string &_winID)
 Set the Window ID. More...
void ShowGrid ()
 Show grid view in the scene. More...
std::chrono::steady_clock::duration SimTime () const
 Get simulation time that the current rendering state corresponds to. More...
void Update ()
 Main update function. Must be called in the rendering thread. More...
void UpdateECM (const UpdateInfo &_info, EntityComponentManager &_ecm)
 Helper Update function for updating the scene. More...
void UpdateFromECM (const UpdateInfo &_info, const EntityComponentManager &_ecm)
 Helper PostUpdate function for updating the scene. More...
void ViewCollisions (const Entity &_entity)
 View collisions of specified entity which are shown in orange. More...
void ViewCOM (const Entity &_entity)
 View center of mass of specified entity. More...
void ViewInertia (const Entity &_entity)
 View inertia of specified entity. More...
void ViewJoints (const Entity &_entity)
 View joints of specified entity. More...
void ViewTransparent (const Entity &_entity)
 View an entity as transparent. More...
void ViewWireframes (const Entity &_entity)
 View wireframes of specified entity. More...
◆ RenderUtil()
RenderUtil ( )
◆ ~RenderUtil()
~RenderUtil ( )
◆ CreateVisualsForEntities()
void CreateVisualsForEntities ( const EntityComponentManager _ecm,
const std::set< Entity > &  _entities
[in]_ecmConst reference to the entity component manager
[in]_entitiesEntities to create visuals for.
◆ DeselectAllEntities()
void DeselectAllEntities ( )
◆ EngineName()
std::string EngineName ( ) const
Name of the rendering engine
◆ HeadlessRendering()
bool HeadlessRendering ( ) const
void Init ( )
◆ InitRenderEnginePluginPaths()
void InitRenderEnginePluginPaths ( )
◆ MarkerManager()
◆ PendingSensors()
int PendingSensors ( ) const
Number of sensors to be added on the next Update call
In the case that RenderUtil has not been initialized, this method will return -1.
◆ Scene()
rendering::ScenePtr Scene ( ) const
Pointer to the scene
◆ SceneManager()
◆ SceneName()
std::string SceneName ( ) const
Name of the rendering scene.
◆ SelectedEntities()
const std::vector<Entity>& SelectedEntities ( ) const
Vector of currently selected entities
◆ SetAmbientLight()
void SetAmbientLight ( const math::Color &  _ambient)
[in]_ambientColor of ambient light
◆ SetBackgroundColor()
void SetBackgroundColor ( const math::Color &  _color)
[in]_colorColor of render window background
◆ SetEnableSensors()
void SetEnableSensors ( bool  _enable,
std::function< std::string(const gazebo::Entity &, const sdf::Sensor &, const std::string &)>  _createSensorCb = {}
[in]_enableTrue to create rendering sensors
[in]_createSensorCbCallback function for creating the sensors The callback function args are: sensor entity, sensor sdf and parent name, it returns the name of the rendering sensor created.
◆ SetEngineName()
void SetEngineName ( const std::string _engineName)
[in]_engineNameName of the rendering engine.
◆ SetEventManager()
void SetEventManager ( EventManager _mgr)
[in]_mgrEvent manager to set to.
◆ SetHeadlessRendering()
void SetHeadlessRendering ( const bool &  _headless)
◆ SetRemoveSensorCb()
void SetRemoveSensorCb ( std::function< void(const gazebo::Entity &)>  _removeSensorCb)
[in]_removeSensorCbCallback function for removing the sensors The callback function arg is the sensor entity to remove
◆ SetScene()
void SetScene ( const rendering::ScenePtr &  _scene)
[in]_scenePointer to the scene.
◆ SetSceneName()
void SetSceneName ( const std::string _sceneName)
[in]_sceneNameName of the engine.
◆ SetSelectedEntity()
void SetSelectedEntity ( const rendering::NodePtr &  _node)
[in]_nodeNode representing the selected entity
◆ SetSkyEnabled()
void SetSkyEnabled ( bool  _enabled)
[in]_enabledTrue to enable sky, false to disable sky
◆ SetTransformActive()
void SetTransformActive ( bool  _active)
[in]_activeTrue if active.
◆ SetUseCurrentGLContext()
void SetUseCurrentGLContext ( bool  _enable)
[in]_enableTrue to use the current GL context
◆ SetWinID()
void SetWinID ( const std::string _winID)
Set the Window ID.
[in]_winIDWindow ID
◆ ShowGrid()
void ShowGrid ( )
◆ SimTime()
std::chrono::steady_clock::duration SimTime ( ) const
Simulation time.
void Update ( )
◆ UpdateECM()
void UpdateECM ( const UpdateInfo _info,
[in]_infoSim update info
[in]_ecmMutable reference to the entity component manager
◆ UpdateFromECM()
void UpdateFromECM ( const UpdateInfo _info,
◆ ViewCollisions()
void ViewCollisions ( const Entity _entity)
[in]_entityEntity to view collisions
◆ ViewCOM()
void ViewCOM ( const Entity _entity)
[in]_entityEntity to view center of mass
◆ ViewInertia()
void ViewInertia ( const Entity _entity)
[in]_entityEntity to view inertia
◆ ViewJoints()
void ViewJoints ( const Entity _entity)
[in]_entityEntity to view joints
◆ ViewTransparent()
void ViewTransparent ( const Entity _entity)
[in]_entityEntity to view as transparent
◆ ViewWireframes()
void ViewWireframes ( const Entity _entity)
[in]_entityEntity to view wireframes
