gz/sim/rendering/RenderUtil.hh
16 */
17 #ifndef GZ_GAZEBO_RENDERUTIL_HH_
18 #define GZ_GAZEBO_RENDERUTIL_HH_
20 #include <memory>
21 #include <set>
22 #include <string>
23 #include <vector>
24
25 #include <sdf/Sensor.hh>
26
27 #include <gz/sim/config.hh>
28 #include <gz/sim/rendering/Export.hh>
29 #include <gz/sim/System.hh>
30
33
34
35 namespace ignition
36 {
37 namespace gazebo
38 {
39 // Inline bracket to help doxygen filtering.
40 inline namespace IGNITION_GAZEBO_VERSION_NAMESPACE {
41  // forward declaration
42  class RenderUtilPrivate;
43
45  class IGNITION_GAZEBO_RENDERING_VISIBLE RenderUtil
46  {
48  public: explicit RenderUtil();
49
51  public: ~RenderUtil();
52
54  public: void Init();
55
61  public: int PendingSensors() const;
62
64  public: void Update();
65
68  public: rendering::ScenePtr Scene() const;
69
73  public: void UpdateECM(const UpdateInfo &_info,
75
77  public: void UpdateFromECM(const UpdateInfo &_info,
78  const EntityComponentManager &_ecm);
79
86  const std::set<Entity> &_entities);
87
90  public: void SetEngineName(const std::string &_engineName);
91
94  public: std::string EngineName() const;
95
98  public: void SetHeadlessRendering(const bool &_headless);
99
102  public: bool HeadlessRendering() const;
103
106  public: void SetSceneName(const std::string &_sceneName);
107
110  public: std::string SceneName() const;
111
114  public: void SetScene(const rendering::ScenePtr &_scene);
115
119  public: void SetBackgroundColor(const math::Color &_color);
120
124  public: void SetAmbientLight(const math::Color &_ambient);
125
128  public: void SetSkyEnabled(bool _enabled);
129
131  public: void ShowGrid();
132
135  public: void SetUseCurrentGLContext(bool _enable);
136
139  public: void SetWinID(const std::string &_winID);
140
146  public: void SetEnableSensors(bool _enable, std::function<
147  std::string(const gazebo::Entity &, const sdf::Sensor &,
148  const std::string &)> _createSensorCb = {});
149
153  public : void SetRemoveSensorCb(
154  std::function<void(const gazebo::Entity &)> _removeSensorCb);
155
158  public: void ViewTransparent(const Entity &_entity);
159
162  public: void ViewCOM(const Entity &_entity);
163
166  public: void ViewInertia(const Entity &_entity);
167
170  public: void ViewJoints(const Entity &_entity);
171
174  public: void ViewWireframes(const Entity &_entity);
175
178  public: void ViewCollisions(const Entity &_entity);
179
182  public: class SceneManager &SceneManager();
183
186  public: class MarkerManager &MarkerManager();
187
191  public: std::chrono::steady_clock::duration SimTime() const;
192
195  public: void SetSelectedEntity(const rendering::NodePtr &_node);
196
199  public: const std::vector<Entity> &SelectedEntities() const;
200
202  public: void DeselectAllEntities();
203
207
211  private: std::vector<Entity> FindChildLinks(const Entity &_entity);
212
215  private: void HideWireboxes(const Entity &_entity);
216
219  public: void SetTransformActive(bool _active);
220
223  public: void SetEventManager(EventManager *_mgr);
224
226  private: std::unique_ptr<RenderUtilPrivate> dataPtr;
227  };
228 }
229 }
230 }
231 #endif
Definition: gz/sim/EventManager.hh:55
Creates, deletes, and maintains marker visuals. Only the Scene class should instantiate and use this ...
Definition: gz/sim/rendering/MarkerManager.hh:39
Definition: gz/sim/rendering/RenderUtil.hh:46
Set the headless mode.
class SceneManager & SceneManager()
Get the scene manager Returns reference to the scene manager.
void Init()
Initialize the renderer. Must be called in the rendering thread.
View wireframes of specified entity.
class MarkerManager & MarkerManager()
Get the marker manager Returns reference to the marker manager.
Set the Window ID.
Set the scene to use.
Set the rendering engine to use.
Get the name of the rendering engine used.
Set whether to use the current GL context.
Get simulation time that the current rendering state corresponds to.
Set whether to enable sky in the scene.
View center of mass of specified entity.
View joints of specified entity.
void CreateVisualsForEntities(const EntityComponentManager &_ecm, const std::set< Entity > &_entities)
Helper function to create visuals for new entities created in ECM. This function is intended to be us...
View an entity as transparent.
void SetEnableSensors(bool _enable, std::function< std::string(const gazebo::Entity &, const sdf::Sensor &, const std::string &)> _createSensorCb={})
Set whether to create rendering sensors.
void ShowGrid()
Show grid view in the scene.
Set the event manager to use.
void UpdateECM(const UpdateInfo &_info, EntityComponentManager &_ecm)
Helper Update function for updating the scene.
Get a pointer to the scene.
const std::vector< Entity > & SelectedEntities() const
Get the entities currently selected, in order of selection.
Clears the set of selected entities and lowlights all of them.
View collisions of specified entity which are shown in orange.
Set background color of render window. This will override other sources, such as from SDF.
void UpdateFromECM(const UpdateInfo &_info, const EntityComponentManager &_ecm)
Helper PostUpdate function for updating the scene.
Set ambient light of render window. This will override other sources, such as from SDF.
void SetRemoveSensorCb(std::function< void(const gazebo::Entity &)> _removeSensorCb)
Set the callback function for removing the sensors.
Count of pending sensors. Must be called in the rendering thread.
View inertia of specified entity.
Get the headless mode.
Set whether the transform controls are currently being dragged.
void Update()
Main update function. Must be called in the rendering thread.
Get the name of the rendering scene used.
void InitRenderEnginePluginPaths()
Init render engine plugins paths. This lets gz-rendering know paths to find render engine plugins.
Set the entity being selected.
Scene manager class for loading and managing objects in the scene.
Definition: gz/sim/rendering/SceneManager.hh:94
uint64_t Entity
Definition: include/gz/sim/Types.hh:39
