SceneManager Class Reference
Scene manager class for loading and managing objects in the scene. More...
#include <SceneManager.hh>
 SceneManager ()
 ~SceneManager ()
AnimationUpdateData ActorAnimationAt (Entity _id, std::chrono::steady_clock::duration _time) const
 Get the actor animation update data given an id. Use this function to let the render engine handle the actor animation. by setting the animation name to be played. More...
rendering::MeshPtr ActorMeshById (Entity _id) const
 Get a rendering mesh given an id. More...
common::SkeletonPtr ActorSkeletonById (Entity _id) const
 Get a skeleton given an id. More...
std::map< std::string, math::Matrix4dActorSkeletonTransformsAt (Entity _id, std::chrono::steady_clock::duration _time) const
 Get the skeleton local transforms of actor mesh given an id. Use this function if you are animating the actor manually by its skeleton node pose. More...
bool AddSensor (Entity _gazeboId, const std::string &_sensorName, Entity _parentGazeboId=0)
 Ignition sensors is the one responsible for adding sensors to the scene. Here we just keep track of it and make sure it has the correct parent. More...
std::pair< rendering::VisualPtr, std::vector< Entity > > CopyVisual (Entity _id, const std::string &_visual, Entity _parentId=0)
 Copy a visual that currently exists in the scene. More...
rendering::VisualPtr CreateActor (Entity _id, const sdf::Actor &_actor, const std::string &_name, Entity _parentId=0)
 Create an actor. More...
rendering::VisualPtr CreateCollision (Entity _id, const sdf::Collision &_collision, Entity _parentId=0)
 Create a collision visual. More...
rendering::VisualPtr CreateCOMVisual (Entity _id, const math::Inertiald &_inertial, Entity _parentId=0)
 Create a center of mass visual. More...
rendering::VisualPtr CreateInertiaVisual (Entity _id, const math::Inertiald &_inertial, Entity _parentId=0)
 Create an inertia visual. More...
rendering::VisualPtr CreateJointVisual (Entity _id, const sdf::Joint &_joint, Entity _childId=0, Entity _parentId=0)
 Create a joint visual. More...
rendering::LightPtr CreateLight (Entity _id, const sdf::Light &_light, const std::string &_name, Entity _parentId)
 Create a light. More...
rendering::VisualPtr CreateLightVisual (Entity _id, const sdf::Light &_light, const std::string &_name, Entity _parentId)
rendering::VisualPtr CreateLink (Entity _id, const sdf::Link &_link, Entity _parentId=0)
 Create a link. More...
rendering::VisualPtr CreateModel (Entity _id, const sdf::Model &_model, Entity _parentId=0)
 Create a model. More...
rendering::ParticleEmitterPtr CreateParticleEmitter (Entity _id, const msgs::ParticleEmitter &_emitter, Entity _parentId)
 Create a particle emitter. More...
rendering::VisualPtr CreateVisual (Entity _id, const sdf::Visual &_visual, Entity _parentId=0)
 Create a visual. More...
std::vector< rendering::NodePtr > Filter (const std::string &_node, std::function< bool(const rendering::NodePtr _nodeToFilter)> _filter) const
 Filter a node and its children according to specific criteria. More...
bool HasEntity (Entity _id) const
 Check if entity exists. More...
std::unordered_map< std::string, unsigned int > LoadAnimations (const sdf::Actor &_actor)
 Load Actor animations. More...
rendering::NodePtr NodeById (Entity _id) const
 Get a rendering node given an entity id. More...
void RemoveEntity (Entity _id)
 Remove an entity by id. More...
 Get the scene. More...
void SequenceTrajectories (std::vector< common::TrajectoryInfo > &_trajectories, std::chrono::steady_clock::time_point _time)
 Sequences Trajectories. More...
void SetScene (rendering::ScenePtr _scene)
 Set the scene to manage. More...
void SetWorldId (Entity _id)
 Set the world's ID. More...
rendering::NodePtr TopLevelNode (const rendering::NodePtr &_node) const
 Get the top level node for the given node, which is the ancestor which is a direct child to the root visual. Usually, this will be a model or a light. More...
rendering::VisualPtr TopLevelVisual (const rendering::VisualPtr &_visual) const
 Get the top level visual for the given visual, which is the ancestor which is a direct child to the root visual. Usually, this will be a model or a light. More...
Entity UniqueId () const
 Create a unique entity ID. More...
void UpdateJointParentPose (Entity _jointId)
 Updates the world pose of joint parent visual according to its child. More...
rendering::ParticleEmitterPtr UpdateParticleEmitter (Entity _id, const msgs::ParticleEmitter &_emitter)
 Update an existing particle emitter. More...
void UpdateTransparency (const rendering::NodePtr &_node, bool _makeTransparent)
 Updates the node to increase its transparency or reset back to its original transparency value, an opaque call requires a previous transparent call, otherwise, no action will be taken Usually, this will be a link visual. More...
rendering::VisualPtr VisualById (Entity _id)
 Retrieve visual. More...
Entity WorldId () const
 Get the world's ID. More...
◆ SceneManager()
◆ ~SceneManager()
◆ ActorAnimationAt()
AnimationUpdateData ActorAnimationAt ( Entity  _id,
) const
[in]_idEntity's unique id
[in]_timeSimulation time
Data needed to update the animation, including the name and time of animation to play, and trajectory animation info.
◆ ActorMeshById()
rendering::MeshPtr ActorMeshById ( Entity  _id) const
[in]_idActor entity's unique id
Pointer to requested entity's mesh
◆ ActorSkeletonById()
common::SkeletonPtr ActorSkeletonById ( Entity  _id) const
Pointer to requested entity's skeleton
◆ ActorSkeletonTransformsAt()
std::map<std::string, math::Matrix4d> ActorSkeletonTransformsAt ( Entity  _id,
) const
[in]_timeSimulationTime
Map from the skeleton node name to transforms
◆ AddSensor()
bool AddSensor ( Entity  _gazeboId,
const std::string _sensorName,
Entity  _parentGazeboId = 0
[in]_gazeboIdEntity in Gazebo
[in]_sensorNameName of sensor node in Ignition Rendering.
[in]_parentGazeboIdParent Id on Gazebo.
True if sensor is successfully handled
◆ CopyVisual()
std::pair<rendering::VisualPtr, std::vector<Entity> > CopyVisual ( Entity  _id,
const std::string _visual,
Entity  _parentId = 0
[in]_idUnique visual id of the copied visual
[in]_visualName of the visual to copy
[in]_parentIdParent id of the copied visual
A pair with the first element being the copied visual object, and the second element being a list of the entity IDs for the copied visual's children, in level order. If copying the visual failed, the first element will be nullptr. If the copied visual has no children, the second element will be empty.
◆ CreateActor()
rendering::VisualPtr CreateActor ( Entity  _id,
const sdf::Actor &  _actor,
const std::string _name,
Create an actor.
[in]_idUnique actor id
[in]_actorActor sdf dom
[in]_nameActor's name
Actor object created from the sdf dom
◆ CreateCollision()
rendering::VisualPtr CreateCollision ( Entity  _id,
const sdf::Collision &  _collision,
[in]_collisionCollision sdf dom
Visual (collision) object created from the sdf dom
◆ CreateCOMVisual()
rendering::VisualPtr CreateCOMVisual ( Entity  _id,
const math::Inertiald _inertial,
[in]_inertialInertial component of the link
Visual (center of mass) object created from the inertial
◆ CreateInertiaVisual()
rendering::VisualPtr CreateInertiaVisual ( Entity  _id,
Visual (inertia) object created from the inertial
◆ CreateJointVisual()
rendering::VisualPtr CreateJointVisual ( Entity  _id,
const sdf::Joint &  _joint,
Entity  _childId = 0,
[in]_jointJoint sdf dom
[in]_childIdJoint child id
[in]_parentIdJoint parent id
Visual (joint) object created from the sdf dom
◆ CreateLight()
rendering::LightPtr CreateLight ( Entity  _id,
const sdf::Light &  _light,
Entity  _parentId
Create a light.
[in]_idUnique light id
[in]_lightLight sdf dom
[in]_nameLight's name
Light object created from the sdf dom
◆ CreateLightVisual()
rendering::VisualPtr CreateLightVisual ( Entity  _id,
Entity  _parentId
Create a light.
◆ CreateLink()
rendering::VisualPtr CreateLink ( Entity  _id,
const sdf::Link &  _link,
Create a link.
[in]_idUnique link id
[in]_linkLink sdf dom
Link visual created from the sdf dom
◆ CreateModel()
rendering::VisualPtr CreateModel ( Entity  _id,
const sdf::Model &  _model,
Create a model.
[in]_idUnique model id
[in]_modelModel sdf dom
Model visual created from the sdf dom
◆ CreateParticleEmitter()
rendering::ParticleEmitterPtr CreateParticleEmitter ( Entity  _id,
const msgs::ParticleEmitter _emitter,
Entity  _parentId
[in]_idUnique particle emitter id
[in]_emitterParticle emitter data
Default particle emitter object created
◆ CreateVisual()
rendering::VisualPtr CreateVisual ( Entity  _id,
const sdf::Visual &  _visual,
Create a visual.
[in]_visualVisual sdf dom
Visual object created from the sdf dom
◆ Filter()
std::vector<rendering::NodePtr> Filter ( const std::string _node,
) const
[in]_nodeThe name of the node where filtering should start.
[in]_filterCallback function that defines how _node and its children should be filtered. The function parameter is a node. The callback returns true if the node should be filtered; false otherwise.
A list of filtered nodes in top level order. This list can contain _node itself, or child nodes of _node. An empty list means no nodes were filtered.
◆ HasEntity()
bool HasEntity ( Entity  _id) const
[in]_idUnique entity id
true if exists, false otherwise
◆ LoadAnimations()
std::unordered_map<std::string, unsigned int> LoadAnimations ( const sdf::Actor &  _actor)
[in]_actorActor
Animation name to ID map
◆ NodeById()
rendering::NodePtr NodeById ( Entity  _id) const
Pointer to requested entity's node
◆ RemoveEntity()
void RemoveEntity ( Entity  _id)
◆ Scene()
rendering::ScenePtr Scene ( ) const
Get the scene.
Pointer to scene
◆ SequenceTrajectories()
void SequenceTrajectories ( std::vector< common::TrajectoryInfo > &  _trajectories,
[in]_trajectoriesActor trajectories
[in]_timeActor trajectory delay start time (miliseconds)
◆ SetScene()
void SetScene ( rendering::ScenePtr  _scene)
[in]_sceneScene pointer.
◆ SetWorldId()
void SetWorldId ( Entity  _id)
Set the world's ID.
[in]_idWorld ID.
◆ TopLevelNode()
rendering::NodePtr TopLevelNode ( const rendering::NodePtr &  _node) const
[in]_nodeChild node
Top level node containing this node
◆ TopLevelVisual()
rendering::VisualPtr TopLevelVisual ( const rendering::VisualPtr &  _visual) const
[in]_visualChild visual
Top level visual containing this visual
◆ UniqueId()
Entity UniqueId ( ) const
A unique entity ID. kNullEntity is returned if no unique entity IDs are available
◆ UpdateJointParentPose()
void UpdateJointParentPose ( Entity  _jointId)
[in]_jointIdJoint visual id.
◆ UpdateParticleEmitter()
rendering::ParticleEmitterPtr UpdateParticleEmitter ( Entity  _id,
_id Emitter id to update
_emitter Data to update the particle emitter
Particle emitter updated
◆ UpdateTransparency()
void UpdateTransparency ( const rendering::NodePtr &  _node,
[in]_nodeThe node to update.
[in]_makeTransparenttrue if updating to increase transparency, false to set back to original transparency values (make more opaque)
◆ VisualById()
rendering::VisualPtr VisualById ( Entity  _id)
Retrieve visual.
[in]_idUnique visual (entity) id
Pointer to requested visual
◆ WorldId()
Entity WorldId ( ) const
Get the world's ID.
World ID
