A factory that generates a component based on a string type. More...
#include <Factory.hh>
 Factory ()=default
 Factory (const Factory &)=delete
 Factory (Factory &)=delete
bool HasType (ComponentTypeId _typeId)
 Check if a component type has been registered. return True if registered. More...
std::string Name (ComponentTypeId _typeId) const
 Get a component's type name given its type ID. return Unique component name. More...
template<typename ComponentTypeT >
std::unique_ptr< ComponentTypeT > New ()
 Create a new instance of a component. More...
std::unique_ptr< components::BaseComponentNew (const ComponentTypeId &_type)
std::unique_ptr< components::BaseComponentNew (const ComponentTypeId &_type, const components::BaseComponent *_data)
 Create a new instance of a component, initialized with particular data. More...
std::unique_ptr< ComponentStorageBase > NewStorage (const ComponentTypeId &)
 Create a new instance of a component storage. More...
void Register (const std::string &_type, ComponentDescriptorBase *_compDesc)
 Register a component so that the factory can create instances of the component based on an ID. More...
void Register (const std::string &_type, ComponentDescriptorBase *_compDesc, RegistrationObjectId _regObjId)
void Register (const std::string &_type, ComponentDescriptorBase *_compDesc, StorageDescriptorBase *)
 Register a component so that the factory can create instances of the component and its storage based on an ID. More...
std::vector< ComponentTypeIdTypeIds () const
 Get all the registered component types by ID. return Vector of component IDs. More...
void Unregister ()
 Unregister a component so that the factory can't create instances of the component anymore. More...
void Unregister (ComponentTypeId _typeId)
void Unregister (ComponentTypeId _typeId, RegistrationObjectId _regObjId)
void Unregister (RegistrationObjectId _regObjId)
static FactoryInstance ()
 Get an instance of the singleton. More...
Public Attributes
std::map< ComponentTypeId, std::stringnamesById
 A list of IDs and their equivalent names. More...
std::map< ComponentTypeId, std::stringruntimeNamesById
 Keep track of the runtime names for types and warn the user if they try to register different types with the same typeName. More...
◆ Factory() [1/3]
Factory ( Factory )
delete
◆ Factory() [2/3]
Factory ( const Factory )
delete
◆ Factory() [3/3]
Factory ( )
default
◆ HasType()
bool HasType ( ComponentTypeId  _typeId)
inline
◆ Instance()
static Factory* Instance ( )
static
◆ Name()
std::string Name ( ComponentTypeId  _typeId) const
inline
References map< K, T >::at(), string::end(), map< K, T >::find(), and Factory::namesById.
◆ New() [1/3]
std::unique_ptr<ComponentTypeT> New ( )
inline
Pointer to a component. Null if the component type could not be handled.
Template Parameters
ComponentTypeTcomponent type requested
◆ New() [2/3]
[in]_typeComponent id to create.
◆ New() [3/3]
std::unique_ptr<components::BaseComponent> New ( const ComponentTypeId _type,
const components::BaseComponent _data
inline
[in]_dataThe data to populate the component instance with.
References std::endl(), and BaseComponent::TypeId().
◆ NewStorage()
std::unique_ptr<ComponentStorageBase> NewStorage ( const ComponentTypeId )
inline
[in]_typeIdType of component which the storage will hold.
Always returns nullptr.
Deprecated:
Storages aren't necessary anymore.
◆ Register() [1/3]
void Register ( const std::string _type,
ComponentDescriptorBase _compDesc
inline
[in]_typeType of component to register.
[in]_compDescObject to manage the creation of ComponentTypeT objects.
Template Parameters
ComponentTypeTType of component to register.
◆ Register() [2/3]
ComponentDescriptorBase _compDesc,
inline
[in]_regObjIdAn ID that identifies the registration object. This is generally derived from the this pointer of the static component registration object created when calling IGN_GAZEBO_REGISTER_COMPONENT.
Template Parameters
References map< K, T >::end(), std::endl(), map< K, T >::find(), Factory::namesById, and Factory::runtimeNamesById.
◆ Register() [3/3]
inline
[in]_storageDescIgnored.
Template Parameters
Deprecated:
See function that doesn't accept a storage
◆ TypeIds()
std::vector<ComponentTypeId> TypeIds ( ) const
inline
References vector< T >::push_back().
◆ Unregister() [1/4]
void Unregister ( )
inline
Template Parameters
ComponentTypeTType of component to unregister.
Referenced by Factory::Unregister().
◆ Unregister() [2/4]
void Unregister ( ComponentTypeId  _typeId)
inline
This function will not reset the typeId static variable within the component type itself. Prefer using the templated Unregister function when possible.
[in]_typeIdType of component to unregister.
References Factory::Unregister().
◆ Unregister() [3/4]
void Unregister ( ComponentTypeId  _typeId,
inline
◆ Unregister() [4/4]
void Unregister ( RegistrationObjectId  _regObjId)
inline
Template Parameters
◆ namesById
Referenced by Factory::Name(), and Factory::Register().
◆ runtimeNamesById
std::map<ComponentTypeId, std::string> runtimeNamesById
Referenced by Factory::Register().
