PerfectComms Class Reference
An example of a comms model. This model always delivers any message to its destination. More...
#include <PerfectComms.hh>
 PerfectComms ()
void Step (const ignition::gazebo::UpdateInfo &_info, const comms::Registry &_currentRegistry, comms::Registry &_newRegistry, EntityComponentManager &_ecm) override
 ICommsModel ()
 Configure the system. More...
◆ PerfectComms()
PerfectComms ( )
◆ Load()
void Load ( const Entity _entity,
EntityComponentManager _ecm,
EventManager _eventMgr
Implements ICommsModel.
◆ Step()
void Step ( const ignition::gazebo::UpdateInfo _info,
const comms::Registry _currentRegistry,
comms::Registry _newRegistry,
[in]_ecm- Ignition's ECM.
