include/gz/sim/components/JointType.hh File Reference
#include <memory>#include <sdf/Joint.hh>#include <gz/sim/components/Factory.hh>#include <gz/sim/components/Component.hh>#include <gz/sim/config.hh>Go to the source code of this file.
Classes | |
| class | JointTypeSerializer |
Namespaces | |
| ignition | |
| ignition::gazebo | |
| ignition::gazebo::components | |
| Components represent data, such as position information. An Entity usually has one or more associated components. | |
| ignition::gazebo::serializers | |
| A Serializer class is used to serialize and deserialize a component. It is passed in as the third template parameter to components::Component. Eg. | |
Typedefs | |
| using | JointType = Component< sdf::JointType, class JointTypeTag, serializers::JointTypeSerializer > |
| A component that contains the joint type. This is a simple wrapper around sdf::JointType. More... | |
