include/gz/sim/components/LogicalAudio.hh File Reference
#include <chrono>
#include <cstdint>
#include <istream>
#include <ostream>
#include <ratio>
#include <gz/sim/config.hh>
class  LogicalAudioSourcePlayInfoSerializer
 Serializer for components::LogicalAudioSourcePlayInfo object. More...
class  LogicalAudioSourceSerializer
 Serializer for components::LogicalAudioSource object. More...
class  LogicalMicrophoneSerializer
 Serializer for components::LogicalMicrophone object. More...
struct  Microphone
 Properties of a logical audio microphone. A microphone also has a pose, which can be stored as a component of a microphone entity via gz::sim::components::Pose. More...
struct  Source
 Properties of a logical audio source. A source also has a pose, which can be stored as a component of a source entity via gz::sim::components::Pose. More...
struct  SourcePlayInfo
 A source's playing information. Useful for keeping track of when to start/stop playing a source. More...
 ignition
 ignition::gazebo
 ignition::gazebo::components
 ignition::gazebo::logical_audio
 ignition::gazebo::serializers
using LogicalAudioSource = Component< logical_audio::Source, class LogicalAudioSourceTag, serializers::LogicalAudioSourceSerializer >
 A component that contains a logical audio source, which is represented by logical_audio::Source. More...
using LogicalAudioSourcePlayInfo = Component< logical_audio::SourcePlayInfo, class LogicalAudioSourcePlayInfoTag, serializers::LogicalAudioSourcePlayInfoSerializer >
 A component that contains a logical audio source's playing information, which is represented by logical_audio::SourcePlayInfo. More...
using LogicalMicrophone = Component< logical_audio::Microphone, class LogicalMicrophoneTag, serializers::LogicalMicrophoneSerializer >
 A component that contains a logical microphone, which is represented by logical_audio::Microphone. More...
Enumerations
enum class  AttenuationFunction { LINEAR , UNDEFINED }
 Audio source attenuation functions. AttenuationFunction::Undefined is used to indicate that an attenuation function has not been defined yet. More...
enum class  AttenuationShape { SPHERE , UNDEFINED }
 Audio source attenuation shapes. AttenuationShape::Undefined is used to indicate that an attenuation shape has not been defined yet. More...
Functions
std::ostream & operator<< (std::ostream &_out, const logical_audio::AttenuationFunction &_func)
 Output stream overload for logical_audio::AttenuationFunction. More...
std::ostream & operator<< (std::ostream &_out, const logical_audio::AttenuationShape &_shape)
 Output stream overload for logical_audio::AttenuationShape. More...
std::ostream & operator<< (std::ostream &_out, const std::chrono::steady_clock::duration &_dur)
 Output stream overload for std::chrono::steady_clock::duration. More...
std::istream & operator>> (std::istream &_in, logical_audio::AttenuationFunction &_func)
 Input stream overload for logical_audio::AttenuationFunction. More...
std::istream & operator>> (std::istream &_in, logical_audio::AttenuationShape &_shape)
 Input stream overload for logical_audio::AttenuationShape. More...
std::istream & operator>> (std::istream &_in, std::chrono::steady_clock::duration &_dur)
 Input stream overload for std::chrono::steady_clock::duration. More...
