ignition::gazebo::events Namespace Reference
Namespace for all events. Refer to the EventManager class for more information about events. More...
using CollectContactSurfaceProperties = gz::common::EventT< void(const Entity &, const Entity &, const math::Vector3d &, const std::optional< math::Vector3d >, const std::optional< math::Vector3d >, const std::optional< double >, const size_t, physics::SetContactPropertiesCallbackFeature::ContactSurfaceParams< Policy > &), struct CollectContactSurfacePropertiesTag >
 This event is called when the physics engine needs to collect what customizations it should do to the surface of a contact point. It is called during the Update phase after collision checking has been finished and before the physics update has happened. The event subscribers are expected to change the params argument. More...
using LoadPlugins = common::EventT< void(Entity, sdf::ElementPtr), struct LoadPluginsTag >
 Please use the LoadSdfPlugins event. The LoadPlugins event will be deprecrated in Gazebo 7 (Garden). Also make sure to connect to only LoadSdfPlugins or LoadPlugins, and not both events. More...
using LoadSdfPlugins = common::EventT< void(Entity, sdf::Plugins), struct LoadPluginsTag >
 Event used to load plugins for an entity into simulation. Pass in the entity which will own the plugins, and an SDF element for the entity, which may contain multiple <plugin> tags. Makre sure that you don't also connect to the LoadPlugins event. More...
using Pause = gz::common::EventT< void(bool), struct PauseTag >
 The pause event can be used to pause or unpause simulation. Emit a value of true to pause simulation, and emit a value of false to unpause simulation. More...
using Policy = physics::FeaturePolicy3d
using PostRender = gz::common::EventT< void(void), struct PostRenderTag >
 The render event is emitted after rendering updates. The event is emitted in the rendering thread so rendering calls can ben make in this event callback. More...
using PreRender = gz::common::EventT< void(void), struct PreRenderTag >
 The render event is emitted before rendering updates. The event is emitted in the rendering thread so rendering calls can ben make in this event callback. More...
using SceneUpdate = gz::common::EventT< void(void), struct SceneUpdateTag >
 The render event is emitted when the the scene manager is updated with contents from the ECM. This event is emitted before the PreRender event on the server side in the rendering thread. It is also accessible on the GUI side. More...
using Stop = gz::common::EventT< void(void), struct StopTag >
 The stop event can be used to terminate simulation. Emit this signal to terminate an active simulation. More...
Typedef Documentation
◆ CollectContactSurfaceProperties
using CollectContactSurfaceProperties = gz::common::EventT< void( const Entity& , const Entity& , const math::Vector3d & , const std::optional<math::Vector3d> , const std::optional<math::Vector3d> , const std::optional<double> , const size_t , physics::SetContactPropertiesCallbackFeature:: ContactSurfaceParams<Policy>& ), struct CollectContactSurfacePropertiesTag>
◆ LoadPlugins
using LoadPlugins = common::EventT<void(Entity, sdf::ElementPtr), struct LoadPluginsTag>
Note
This will be deprecated in Gazebo 7 (Garden), please the use sdf::Plugin interface.
◆ LoadSdfPlugins
using LoadSdfPlugins = common::EventT<void(Entity, sdf::Plugins), struct LoadPluginsTag>
◆ Pause
using Pause = gz::common::EventT<void(bool), struct PauseTag>
For example, to pause simulation use:
eventManager.Emit<gz::sim::events::Pause>(true);
gz::common::EventT< void(bool), struct PauseTag > Pause
The pause event can be used to pause or unpause simulation. Emit a value of true to pause simulation,...
Definition: gz/sim/Events.hh:46
◆ Policy
◆ PostRender
using PostRender = gz::common::EventT<void(void), struct PostRenderTag>
For example:
eventManager.Emit<gz::sim::events::PostRender>();
gz::common::EventT< void(void), struct PostRenderTag > PostRender
The render event is emitted after rendering updates. The event is emitted in the rendering thread so ...
Definition: gz/sim/rendering/Events.hh:67
◆ PreRender
using PreRender = gz::common::EventT<void(void), struct PreRenderTag>
For example:
eventManager.Emit<gz::sim::events::PreRender>();
gz::common::EventT< void(void), struct PreRenderTag > PreRender
The render event is emitted before rendering updates. The event is emitted in the rendering thread so...
Definition: gz/sim/rendering/Events.hh:56
◆ SceneUpdate
using SceneUpdate = gz::common::EventT<void(void), struct SceneUpdateTag>
For example:
eventManager.Emit<gz::sim::events::SceneUpdate>();
gz::common::EventT< void(void), struct SceneUpdateTag > SceneUpdate
The render event is emitted when the the scene manager is updated with contents from the ECM....
Definition: gz/sim/rendering/Events.hh:45
◆ Stop
using Stop = gz::common::EventT<void(void), struct StopTag>
For example:
eventManager.Emit<gz::sim::events::Stop>();
gz::common::EventT< void(void), struct StopTag > Stop
The stop event can be used to terminate simulation. Emit this signal to terminate an active simulatio...
Definition: gz/sim/Events.hh:55
