SystemLoader Class Reference
Class for loading/unloading System plugins. More...
#include <gz/sim/SystemLoader.hh>
 SystemLoader ()
 ~SystemLoader ()
void AddSystemPluginPath (const std::string &_path)
 Add path to search for plugins. More...
std::optional< SystemPluginPtr > LoadPlugin (const sdf::ElementPtr &_sdf)
 Load and instantiate system plugin from an SDF element. More...
std::optional< SystemPluginPtr > LoadPlugin (const sdf::Plugin &_plugin)
 Load and instantiate system plugin from name/filename. More...
std::optional< SystemPluginPtr > LoadPlugin (const std::string &_filename, const std::string &_name, const sdf::ElementPtr &_sdf)
std::list< std::string > PluginPaths () const
 Get the plugin search paths used for loading system plugins. More...
std::string PrettyStr () const
 Makes a printable string with info about systems. More...
◆ SystemLoader()
SystemLoader ( )
◆ ~SystemLoader()
◆ AddSystemPluginPath()
void AddSystemPluginPath ( const std::string &  _path)
[in]_pathNew path to be added.
◆ LoadPlugin() [1/3]
std::optional<SystemPluginPtr> LoadPlugin ( const sdf::ElementPtr &  _sdf)
[in]_sdfSDF Element describing plugin instance to be loaded.
Shared pointer to system instance or nullptr.
Deprecated:
Use sdf::Plugin interface.
◆ LoadPlugin() [2/3]
std::optional<SystemPluginPtr> LoadPlugin ( const sdf::Plugin &  _plugin)
[in]_pluginSDF Plugin to be loaded.
◆ LoadPlugin() [3/3]
std::optional<SystemPluginPtr> LoadPlugin ( const std::string &  _filename,
const std::string &  _name,
[in]_filenameShared library filename to load plugin from.
[in]_nameClass name to be instantiated.
Deprecated:
◆ PluginPaths()
std::list<std::string> PluginPaths ( ) const
Paths to search for plugins
◆ PrettyStr()
std::string PrettyStr ( ) const
A pretty string
