Provides buttons for viewing angles. More...
#include <ViewAngle.hh>
Public Slots
void OnAngleMode (int _x, int _y, int _z)
 Callback in Qt thread when angle mode changes. More...
void OnViewControl (const QString &_controller)
 Callback in Qt thread when camera view controller changes. More...
void OnViewControlReferenceVisual (bool _enable)
 Callback in Qt thread when camera view reference visual state changes. More...
void OnViewControlSensitivity (double _sensitivity)
void SetCamClipDist (double _near, double _far)
 Updates gui camera's near/far clipping distances. More...
void SetCamPose (double _x, double _y, double _z, double _roll, double _pitch, double _yaw)
 Callback to update gui camera pose. More...
void SetHorizontalFOV (double _horizontalFOV)
 Updates gui camera's Horizontal fov. More...
Signals
void CamClipDistChanged ()
 Notify that the gui camera's near/far clipping distances changed. More...
void CamHorizontalFOVChanged ()
 Notify that the gui camera's horizontal fov changed. More...
void CamPoseChanged ()
 Notify that the gui camera pose has changed. More...
void ViewControlIndexChanged ()
 Notify that the camera's view controller has changed. More...
 ViewAngle ()
 ~ViewAngle () override
Q_INVOKABLE QList< double > CamClipDist () const
 Get the current gui camera's near and far clipping distances. More...
Q_INVOKABLE QList< double > CamPose () const
 Get the current gui camera pose. More...
void CamPoseCb (const msgs::Pose &_msg)
 Callback for retrieving gui camera pose. More...
Q_INVOKABLE double HorizontalFOV () const
 Get the current gui horizontal fov. More...
bool OnMoveToModelService (const gz::msgs::GUICamera &_msg, gz::msgs::Boolean &_res)
 Move to model service received. More...
int ViewControlIndex () const
 Get the current index for view controller (on qml side) More...
Properties
QList< double > camClipDist
 gui camera near/far clipping distance (QList order is near, far) More...
QList< double > camPose
 gui camera pose (QList order is x, y, z, roll, pitch, yaw) More...
double horizontalFOV
 gui camera horizontal fov More...
int viewControlIndex
 view controller index for qml side (0: orbit; 1: ortho) More...
Configuration
<service> : Set the service to receive view angle requests. MinimalScene. Defaults to true.
◆ ViewAngle()
ViewAngle ( )
◆ ~ViewAngle()
~ViewAngle ( )
◆ CamClipDist()
Q_INVOKABLE QList<double> CamClipDist ( ) const
◆ CamClipDistChanged
void CamClipDistChanged ( )
signal
◆ CamHorizontalFOVChanged
void CamHorizontalFOVChanged ( )
signal
◆ CamPose()
Q_INVOKABLE QList<double> CamPose ( ) const
◆ CamPoseCb()
void CamPoseCb ( const msgs::Pose &  _msg)
[in]_msgPose message
◆ CamPoseChanged
void CamPoseChanged ( )
signal
◆ HorizontalFOV()
Q_INVOKABLE double HorizontalFOV ( ) const
◆ LoadConfig()
◆ OnAngleMode
void OnAngleMode ( int  _x,
int  _y,
int  _z
slot
[in]_xThe x component of the directional vector for the camera to assume. All 0s for x, y, and z indicate the initial camera pose.
[in]_yThe y component of the directional vector for the camera to assume. All 0s for x, y, and z indicate the initial camera pose.
[in]_zThe z component of the directional vector for the camera to assume. All 0s for x, y, and z indicate the initial camera pose.
◆ OnMoveToModelService()
bool OnMoveToModelService ( const gz::msgs::GUICamera &  _msg,
gz::msgs::Boolean &  _res
[in]_msgGUI camera message
[in]_resResponse
◆ OnViewControl
void OnViewControl ( const QString &  _controller)
slot
[in]_modeNew camera view controller
◆ OnViewControlReferenceVisual
void OnViewControlReferenceVisual ( bool  _enable)
slot
[in]_enableTrue to enable camera view control reference visual, false to hide it
◆ OnViewControlSensitivity
void OnViewControlSensitivity ( double  _sensitivity)
slot
[in]_sensitivityView control sensitivity vlaue
◆ SetCamClipDist
void SetCamClipDist ( double  _near,
double  _far
slot
◆ SetCamPose
void SetCamPose ( double  _x,
double  _y,
double  _z,
double  _roll,
double  _pitch,
double  _yaw
slot
[in]_x,_y,_zcartesion coordinates
[in]_roll,_pitch,_yawprincipal coordinates
◆ SetHorizontalFOV
void SetHorizontalFOV ( double  _horizontalFOV)
slot
[in]_horizontalFOVHorizontal fov
◆ ViewControlIndex()
int ViewControlIndex ( ) const
◆ ViewControlIndexChanged
void ViewControlIndexChanged ( )
signal
Property Documentation
◆ camClipDist
QList<double> camClipDist
read
◆ camPose
QList<double> camPose
read
◆ horizontalFOV
read
◆ viewControlIndex
read
