gz/sim/components/JointVelocityLimitsCmd.hh File Reference
#include <vector>#include <gz/math/Vector2.hh>#include <gz/sim/components/Component.hh>#include <gz/sim/components/Factory.hh>#include <gz/sim/components/Serialization.hh>#include <gz/sim/config.hh>#include <gz/sim/Export.hh>Go to the source code of this file.
Namespaces | |
| gz | |
| gz::sim | |
| gz::sim::components | |
| Components represent data, such as position information. An Entity usually has one or more associated components. | |
Typedefs | |
| using | JointVelocityLimitsCmd = Component< std::vector< gz::math::Vector2d >, class JointVelocityLimitsCmdTag, serializers::VectorSerializer< gz::math::Vector2d > > |
| Command for setting velocity limits of a joint. Data are a vector with a Vector2 for each DOF. The X() component of the Vector2 specifies the minimum velocity limit, the Y() component stands for maximum limit. Set to +-infinity to disable the limits. More... | |
