Components represent data, such as position information. An Entity usually has one or more associated components. More...
Classes | |
| class | BaseComponent |
| Base class for all components. More... | |
| struct | BatteryPowerLoadInfo |
| Data structure to hold the consumer power load and the name of the battery it uses. More... | |
| class | Component |
| A component type that wraps any data type. The intention is for this class to be used to create simple components while avoiding a lot of boilerplate code. The Identifier must be a unique type so that type aliases can be used to create new components. However the type does not need to be defined anywhere eg. More... | |
| class | Component< NoData, Identifier, Serializer > |
| Specialization for components that don't wrap any data. This class to be used to create simple components that represent just a "tag", while avoiding a lot of boilerplate code. The Identifier must be a unique type so that type aliases can be used to create new components. However the type does not need to be defined anywhere eg. More... | |
| class | ComponentDescriptor |
| A class for an object responsible for creating components. More... | |
| class | ComponentDescriptorBase |
| A base class for an object responsible for creating components. More... | |
| class | ComponentDescriptorQueue |
| A class to hold the queue of component descriptors registered by translation units. This queue is necessary to ensure that component creation continues to work after plugins are unloaded. The typical scenario this aims to solve is: More... | |
| struct | DetachableJointInfo |
| Data structure to hold information about the parent and child links connected by a detachable joint. More... | |
| struct | EnvironmentalData |
| Environment data across time and space. This is useful to introduce physical quantities that may be of interest even if not modelled in simulation. More... | |
| class | Factory |
| A factory that generates a component based on a string type. More... | |
| struct | RegistrationObjectId |
| A wrapper around uintptr_t to prevent implicit conversions. More... | |
| struct | TemperatureRangeInfo |
| Data structure to hold a temperature range, in kelvin. More... | |
Typedefs | |
| using | Actor = Component< sdf::Actor, class ActorTag, serializers::ActorSerializer > |
| This component contains actor source information. For more information on actors, see SDF's Actor element. More... | |
| using | Actuators = Component< msgs::Actuators, class ActuatorsTag, serializers::MsgSerializer > |
| A component type that contains a msgs::Actuators message. This is used for example, to communicate between the MulticopterMotorModel and MulticopterVelocityControl systems. More... | |
| using | AirPressureSensor = Component< sdf::Sensor, class AirPressureSensorTag, serializers::SensorSerializer > |
| A component type that contains an air pressure sensor, sdf::AirPressure, information. More... | |
| using | AirSpeedSensor = Component< sdf::Sensor, class AirSpeedSensorTag, serializers::SensorSerializer > |
| A component type that contains an air speed sensor, sdf::AirSpeed, information. More... | |
| using | Altimeter = Component< sdf::Sensor, class AltimeterTag, serializers::SensorSerializer > |
| A component type that contains an altimeter sensor, sdf::Altimeter, information. More... | |
| using | AngularAcceleration = Component< math::Vector3d, class AngularAccelerationTag > |
| A component type that contains angular acceleration of an entity represented by gz::math::Vector3d. More... | |
| using | AngularVelocity = Component< math::Vector3d, class AngularVelocityTag > |
| A component type that contains angular velocity of an entity represented by gz::math::Vector3d. More... | |
| using | AngularVelocityCmd = Component< math::Vector3d, class AngularVelocityCmdTag > |
| A component type that contains the commanded angular velocity of an entity, in its own frame, represented by gz::math::Vector3d. More... | |
| using | Atmosphere = Component< sdf::Atmosphere, class AtmosphereTag, serializers::AtmosphereSerializer > |
| This component holds atmosphere properties of the world. More... | |
| using | AxisAlignedBox = Component< gz::math::AxisAlignedBox, class AxisAlignedBoxTag, serializers::AxisAlignedBoxSerializer > |
| A component type that contains axis aligned box, gz::math::AxisAlignedBox, information. The axis aligned box is created from collisions in the entity. More... | |
| using | BatteryPowerLoad = Component< BatteryPowerLoadInfo, class BatteryPowerLoadTag > |
| A component that indicates the total consumption of a battery. More... | |
| using | BatterySoC = Component< float, class BatterySoCTag > |
| using | BoundingBoxCamera = Component< sdf::Sensor, class BoundingBoxCameraTag, serializers::SensorSerializer > |
| A component type that contains a BoundingBox camera sensor, sdf::Camera, information. More... | |
| using | Camera = Component< sdf::Sensor, class CameraTag, serializers::SensorSerializer > |
| A component type that contains a camera sensor, sdf::Camera, information. More... | |
| using | CanonicalLink = Component< NoData, class CanonicalLinkTag > |
| A component that identifies an entity as being a canonical link. More... | |
| using | CastShadows = Component< bool, class CastShadowsTag > |
| A component used to indicate that an entity casts shadows e.g. visual entities. More... | |
| using | CenterOfVolume = Component< math::Vector3d, class CenterOfVolumeTag > |
| A component for an entity's center of volume. Units are in meters. The Vector3 value indicates center of volume of an entity. The position of the center of volume is relative to the pose of the parent entity, which is usually a link. More... | |
| using | ChildLinkName = Component< std::string, class ChildLinkNameTag, serializers::StringSerializer > |
| A component used to indicate that a model is childlinkname (i.e. not moveable). More... | |
| using | Collision = Component< NoData, class CollisionTag > |
| A component that identifies an entity as being a collision. More... | |
| using | ContactSensor = Component< sdf::ElementPtr, class ContactSensorTag > |
TODO(anyone) Substitute with sdf::Contact once that exists? This is currently the whole <sensor> element. More... | |
| using | ContactSensorData = Component< msgs::Contacts, class ContactSensorDataTag, serializers::MsgSerializer > |
| A component type that contains a list of contacts. More... | |
| using | CustomSensor = Component< sdf::Sensor, class CustomSensorTag, serializers::SensorSerializer > |
| A component type that contains a custom sensor's information. A custom sensor is any sensor that's not officially supported through the SDF spec. More... | |
| using | DepthCamera = Component< sdf::Sensor, class DepthCameraTag, serializers::SensorSerializer > |
| A component type that contains a depth camera sensor, sdf::Camera, information. More... | |
| using | DetachableJoint = Component< DetachableJointInfo, class DetachableJointTag, serializers::DetachableJointInfoSerializer > |
| A component that identifies an entity as being a detachable joint. It also contains additional information about the joint. More... | |
| using | Environment = Component< std::shared_ptr< EnvironmentalData >, class EnvironmentalDataTag > |
| A component type that contains a environment data. Ownership is shared to avoid data copies unless necessary. More... | |
| using | ExternalWorldWrenchCmd = Component< msgs::Wrench, class ExternalWorldWrenchCmdTag, serializers::MsgSerializer > |
| A component type that contains the external wrench to be applied on an entity expressed in the world frame and represented by gz::msgs::Wrench. Currently this is used for applying wrenches on links. Although the msg::Wrench type has a force_offset member, the value is currently ignored. Instead, the force is applied at the link origin. The wrench uses SI units (N for force and N⋅m for torque). More... | |
| using | ForceTorque = Component< sdf::Sensor, class ForceTorqueTag, serializers::SensorSerializer > |
| A component type that contains an FT sensor, sdf::ForceTorque, information. More... | |
| using | Geometry = Component< sdf::Geometry, class GeometryTag, serializers::GeometrySerializer > |
| This component holds an entity's geometry. More... | |
| using | GpuLidar = Component< sdf::Sensor, class GpuLidarTag, serializers::SensorSerializer > |
| A component type that contains a GPU Lidar sensor, sdf::Lidar, information. More... | |
| using | Gravity = Component< math::Vector3d, class GravityTag > |
| Store the gravity acceleration. More... | |
| using | HaltMotion = Component< bool, class HaltMotionTag > |
| A component used to turn off a model's joint's movement. More... | |
| using | Imu = Component< sdf::Sensor, class ImuTag, serializers::SensorSerializer > |
| A component type that contains an IMU sensor, sdf::IMU, information. More... | |
| using | Inertial = Component< math::Inertiald, class InertialTag, serializers::InertialSerializer > |
| This component holds an entity's inertial. More... | |
| using | Joint = Component< NoData, class JointTag > |
| A component that identifies an entity as being a joint. More... | |
| using | JointAxis = Component< sdf::JointAxis, class JointAxisTag, serializers::JointAxisSerializer > |
| A component that contains the joint axis . This is a simple wrapper around sdf::JointAxis. More... | |
| using | JointEffortLimitsCmd = Component< std::vector< gz::math::Vector2d >, class JointEffortLimitsCmdTag, serializers::VectorSerializer< gz::math::Vector2d > > |
| Command for setting effort limits of a joint. Data are a vector with a Vector2 for each DOF. The X() component of the Vector2 specifies the minimum effort limit, the Y() component stands for maximum limit. Set to +-infinity to disable the limits. More... | |
| using | JointForce = Component< std::vector< double >, class JointForceTag, serializers::VectorDoubleSerializer > |
| Force applied to a joint in SI units (Nm for revolute, N for prismatic). More... | |
| using | JointForceCmd = Component< std::vector< double >, class JointForceCmdTag > |
| Commanded joint forces (or torques) to be applied to a joint in SI units (Nm for revolute, N for prismatic). The component wraps a std::vector and systems that set this component need to ensure that the vector has the same size as the degrees of freedom of the joint. More... | |
| using | JointPosition = Component< std::vector< double >, class JointPositionTag, serializers::VectorDoubleSerializer > |
| Joint positions in SI units (rad for revolute, m for prismatic). The component wraps a std::vector of size equal to the degrees of freedom of the joint. More... | |
| using | JointPositionLimitsCmd = Component< std::vector< gz::math::Vector2d >, class JointPositionLimitsCmdTag, serializers::VectorSerializer< gz::math::Vector2d > > |
| Command for setting position limits of a joint. Data are a vector with a Vector2 for each DOF. The X() component of the Vector2 specifies the minimum positional limit, the Y() component stands for maximum limit. Set to +-infinity to disable the limits. More... | |
| using | JointPositionReset = Component< std::vector< double >, class JointPositionResetTag, serializers::VectorDoubleSerializer > |
| Joint positions in SI units (rad for revolute, m for prismatic). More... | |
| using | JointTransmittedWrench = Component< msgs::Wrench, class JointTransmittedWrenchTag, serializers::MsgSerializer > |
| Joint Transmitted wrench in SI units (Nm for torque, N for force). The wrench is expressed in the Joint frame and the force component is applied at the joint origin. More... | |
| using | JointType = Component< sdf::JointType, class JointTypeTag, serializers::JointTypeSerializer > |
| A component that contains the joint type. This is a simple wrapper around sdf::JointType. More... | |
| using | JointVelocity = Component< std::vector< double >, class JointVelocityTag, serializers::VectorDoubleSerializer > |
| Base class which can be extended to add serialization. More... | |
| using | JointVelocityCmd = Component< std::vector< double >, class JointVelocityCmdTag, serializers::VectorDoubleSerializer > |
| using | JointVelocityLimitsCmd = Component< std::vector< gz::math::Vector2d >, class JointVelocityLimitsCmdTag, serializers::VectorSerializer< gz::math::Vector2d > > |
| Command for setting velocity limits of a joint. Data are a vector with a Vector2 for each DOF. The X() component of the Vector2 specifies the minimum velocity limit, the Y() component stands for maximum limit. Set to +-infinity to disable the limits. More... | |
| using | JointVelocityReset = Component< std::vector< double >, class JointVelocityResetTag, serializers::VectorDoubleSerializer > |
| Joint velocities in SI units (rad/s for revolute, m/s for prismatic). More... | |
| using | LaserRetro = Component< double, class LaserRetroTag > |
| A component used to indicate an lidar reflective value. More... | |
| using | Level = Component< NoData, class LevelTag > |
| This component identifies an entity as being a level. More... | |
| using | LevelBuffer = Component< double, class LevelBufferTag > |
| A component that holds the buffer setting of a level's geometry. More... | |
| using | LevelEntityNames = Component< std::set< std::string >, class LevelEntityNamesTag, serializers::LevelEntityNamesSerializer > |
| A component that holds a list of names of entities to be loaded in a level. More... | |
| using | Lidar = Component< sdf::Sensor, class LidarTag, serializers::SensorSerializer > |
| A component type that contains a Lidar sensor, sdf::Lidar, information. More... | |
| using | Light = Component< sdf::Light, class LightTag, serializers::LightSerializer > |
| This component contains light source information. For more information on lights, see SDF's Light element. More... | |
| using | LightCmd = Component< gz::msgs::Light, class LightCmdTag, serializers::MsgSerializer > |
| A component type that contains commanded light of an entity in the world frame represented by msgs::Light. More... | |
| using | LightType = Component< std::string, class LightTypeTag, serializers::StringSerializer > |
| A component that contains the light type. This is a simple wrapper around std::string. More... | |
| using | LinearAcceleration = Component< math::Vector3d, class LinearAccelerationTag > |
| A component type that contains linear acceleration of an entity represented by gz::math::Vector3d. More... | |
| using | LinearVelocity = Component< math::Vector3d, class LinearVelocityTag > |
| A component type that contains linear velocity of an entity represented by gz::math::Vector3d. More... | |
| using | LinearVelocityCmd = Component< math::Vector3d, class LinearVelocityCmdTag > |
| using | LinearVelocitySeed = Component< math::Vector3d, class LinearVelocitySeedTag > |
| A component type that contains linear velocity seed of an entity expressed in the local frame of the entity and represented by gz::math::Vector3d. This seed can used to generate linear velocities by applying transformations and adding noise. More... | |
| using | Link = Component< NoData, class LinkTag > |
| A component that identifies an entity as being a link. More... | |
| using | LogicalAudioSource = Component< logical_audio::Source, class LogicalAudioSourceTag, serializers::LogicalAudioSourceSerializer > |
| A component that contains a logical audio source, which is represented by logical_audio::Source. More... | |
| using | LogicalAudioSourcePlayInfo = Component< logical_audio::SourcePlayInfo, class LogicalAudioSourcePlayInfoTag, serializers::LogicalAudioSourcePlayInfoSerializer > |
| A component that contains a logical audio source's playing information, which is represented by logical_audio::SourcePlayInfo. More... | |
| using | LogicalCamera = Component< sdf::ElementPtr, class LogicalCameraTag > |
TODO(anyone) Substitute with sdf::LogicalCamera once that exists? This is currently the whole <sensor> element. More... | |
| using | LogicalMicrophone = Component< logical_audio::Microphone, class LogicalMicrophoneTag, serializers::LogicalMicrophoneSerializer > |
| A component that contains a logical microphone, which is represented by logical_audio::Microphone. More... | |
| using | LogPlaybackStatistics = Component< gz::msgs::LogPlaybackStatistics, class LogPlaybackStatisticsTag, serializers::MsgSerializer > |
| A component type that contains log playback, systems::LogPlayback, information. The log playback is created from world entity upon the playback plugin being loaded. More... | |
| using | MagneticField = Component< math::Vector3d, class MagneticFieldTag > |
| Stores the 3D magnetic field in teslas. More... | |
| using | Magnetometer = Component< sdf::Sensor, class MagnetometerTag, serializers::SensorSerializer > |
| A component type that contains a magnetometer sensor, sdf::Magnetometer, information. More... | |
| using | Material = Component< sdf::Material, class MaterialTag, serializers::MaterialSerializer > |
| This component holds an entity's material. More... | |
| using | Model = Component< NoData, class ModelTag > |
| A component that identifies an entity as being a model. More... | |
| using | Name = Component< std::string, class NameTag, serializers::StringSerializer > |
| This component holds an entity's name. The component has no concept of scoped names nor does it care about uniqueness. More... | |
| using | NavSat = Component< sdf::Sensor, class NavSatTag, serializers::SensorSerializer > |
| A component type that contains an NavSat sensor, sdf::NavSat, information. More... | |
| using | NoData = std::add_lvalue_reference< void > |
| Convenient type to be used by components that don't wrap any data. I.e. they act as tags and their presence is enough to infer something about the entity. More... | |
| using | ParentEntity = Component< Entity, class ParentEntityTag > |
| This component holds an entity's parent entity. More... | |
| using | ParentLinkName = Component< std::string, class ParentLinkNameTag, serializers::StringSerializer > |
| Holds the name of the entity's parent link. More... | |
| using | ParticleEmitter = Component< msgs::ParticleEmitter, class ParticleEmitterTag, serializers::MsgSerializer > |
| A component that contains a particle emitter. More... | |
| using | Performer = Component< NoData, class PerformerTag > |
| This component identifies an entity as being a performer. More... | |
| using | PerformerAffinity = Component< std::string, class PerformerAffinityTag, serializers::StringSerializer > |
| This component holds the address of the distributed secondary that this performer is associated with. More... | |
| using | PerformerLevels = Component< std::set< Entity >, class PerformerLevelsTag, serializers::PerformerLevelsSerializer > |
| Holds all the levels which a performer is in. More... | |
| using | Physics = Component< sdf::Physics, class PhysicsTag, serializers::PhysicsSerializer > |
| A component type that contains the physics properties of the World entity. More... | |
| using | PhysicsCmd = Component< msgs::Physics, class PhysicsCmdTag > |
| using | PhysicsEnginePlugin = Component< std::string, class PhysicsEnginePluginTag, serializers::StringSerializer > |
| Holds the physics engine shared library. More... | |
| using | Pose = Component< gz::math::Pose3d, class PoseTag > |
| A component type that contains pose, gz::math::Pose3d, information. More... | |
| using | Projector = Component< sdf::Projector, class ProjectorTag, serializers::ProjectorSerializer > |
| A component type that contains a projector, sdf::Projector, information. More... | |
| using | Recreate = Component< NoData, class RecreateTag > |
| A component that identifies an entity needs to be recreated. Currently, only Models will be processed for recreation by the SimulationRunner in the ProcessRecreateEntitiesRemove and ProcessRecreateEntitiesCreate functions. More... | |
| using | RenderEngineGuiPlugin = Component< std::string, class RenderEngineGuiPluginTag, serializers::StringSerializer > |
| Holds the render engine gui shared library. More... | |
| using | RenderEngineServerHeadless = Component< bool, class RenderEngineServerHeadlessTag > |
| Holds the headless mode. More... | |
| using | RenderEngineServerPlugin = Component< std::string, class RenderEngineServerPluginTag, serializers::StringSerializer > |
| Holds the render engine server shared library. More... | |
| using | RgbdCamera = Component< sdf::Sensor, class RgbdCameraTag, serializers::SensorSerializer > |
| A component type that contains a RGBD camera sensor, sdf::Camera, information. More... | |
| using | Scene = Component< sdf::Scene, class SceneTag, serializers::SceneSerializer > |
| This component holds scene properties of the world. More... | |
| using | SegmentationCamera = Component< sdf::Sensor, class SegmentationCameraTag, serializers::SensorSerializer > |
| A component type that contains a Segmentation camera sensor, sdf::Camera, information. More... | |
| using | SelfCollide = Component< bool, class SelfCollideTag > |
| A component used to hold a model's self collide property. More... | |
| using | SemanticLabel = Component< uint32_t, class SemanticLabelTag > |
| A component that holds the label of an entity. One example use case of the Label component is with Segmentation & Bounding box sensors to generate dataset annotations. More... | |
| using | Sensor = Component< NoData, class SensorTag > |
| A component that identifies an entity as being a sensor. More... | |
| using | SlipComplianceCmd = Component< std::vector< double >, class SlipComplianceCmdTag > |
| A component type that contains the slip compliance parameters to be set on a collision. The 0 and 1 index values correspond to the slip compliance parameters in friction direction 1 (fdir1) and friction direction 2 (fdir2) respectively. More... | |
| using | SourceFilePath = Component< std::string, class SourceFilePathTag, serializers::StringSerializer > |
| This component holds the filepath to the source from which an entity is created. For example, it can be used to store the file path of a model's SDFormat file. More... | |
| using | SphericalCoordinates = Component< math::SphericalCoordinates, class SphericalCoordinatesTag, serializers::SphericalCoordinatesSerializer > |
| This component holds the spherical coordinates of the world origin. More... | |
| using | Static = Component< bool, class StaticTag > |
| A component used to indicate that a model is static (i.e. not moveable). More... | |
| using | SystemPluginInfo = Component< msgs::Plugin_V, class SystemPluginInfoTag, serializers::MsgSerializer > |
| This component holds information about all the system plugins that are attached to an entity. The content of each system is populated the moment the plugin is instantiated and isn't modified throughout simulation. More... | |
| using | Temperature = Component< math::Temperature, class TemperatureTag > |
| A component that stores temperature data in Kelvin. More... | |
| using | TemperatureRange = Component< TemperatureRangeInfo, class TemperatureRangeTag, serializers::TemperatureRangeInfoSerializer > |
| A component that stores a temperature range in kelvin. More... | |
| using | ThermalCamera = Component< sdf::Sensor, class ThermalCameraTag, serializers::SensorSerializer > |
| A component type that contains a Thermal camera sensor, sdf::Sensor, information. More... | |
| using | ThreadPitch = Component< double, class ThreadPitchTag > |
| A component used to store the thread pitch of a screw joint. More... | |
| using | Transparency = Component< float, class TransparencyTag > |
| A component used to indicate an entity's transparency value e.g. visual entities. Value is in the range from 0 (opaque) to 1 (transparent). More... | |
| using | VisibilityFlags = Component< uint32_t, class VisibilityFlagsTag > |
| This component holds an entity's visibility flags (visual entities) More... | |
| using | Visual = Component< NoData, class VisualTag > |
| A component that identifies an entity as being a visual. More... | |
| using | VisualCmd = Component< gz::msgs::Visual, class VisualCmdTag, serializers::MsgSerializer > |
| A component type that contains commanded visual of an entity in the world frame represented by msgs::Visual. More... | |
| using | Volume = Component< double, class VolumeTag > |
| A volume component where the units are m^3. Double value indicates volume of an entity. More... | |
| using | WheelSlipCmd = Component< gz::msgs::WheelSlipParametersCmd, class WheelSlipCmdTag, serializers::MsgSerializer > |
| A component type that contains commanded wheel slip parameters of an entity in the world frame represented by msgs::WheelSlipParameters. More... | |
| using | WideAngleCamera = Component< sdf::Sensor, class WideAngleCameraTag, serializers::SensorSerializer > |
| A component type that contains a wide angle camera sensor, sdf::Camera, information. More... | |
| using | Wind = Component< NoData, class WindTag > |
| A component that identifies an entity as being a wind. More... | |
| using | WindMode = Component< bool, class WindModeTag > |
| A component used to indicate whether an entity is affected by wind. More... | |
| using | World = Component< NoData, class WorldTag > |
| A component that identifies an entity as being a world. More... | |
| using | WorldPoseCmd = Component< math::Pose3d, class WorldPoseCmdTag > |
| A component type that contains commanded pose of an entity in the world frame represented by gz::math::Pose3d. More... | |
Functions | |
| GZ_SIM_REGISTER_COMPONENT ("gz_sim_components.Actor", Actor) using AnimationTime | |
| Time in seconds within animation being currently played. More... | |
| GZ_SIM_REGISTER_COMPONENT ("gz_sim_components.AnimationTime", AnimationTime) using AnimationName | |
| Name of animation being currently played. More... | |
| GZ_SIM_REGISTER_COMPONENT ("gz_sim_components.CanonicalLink", CanonicalLink) using ModelCanonicalLink | |
| A component that contains a reference to the canonical link entity of a model. More... | |
| GZ_SIM_REGISTER_COMPONENT ("gz_sim_components.Collision", Collision) using CollisionElement | |
| A component that holds the sdf::Collision object. More... | |
| GZ_SIM_REGISTER_COMPONENT ("gz_sim_components.CollisionElement", CollisionElement) using EnableContactSurfaceCustomization | |
| A component used to enable customization of contact surface for a collision. The customization itself is done in callback of event CollectContactSurfaceProperties from PhysicsEvents. More... | |
| GZ_SIM_REGISTER_COMPONENT ("gz_sim_components.Level", Level) using DefaultLevel | |
| This component identifies an entity as being a default level. More... | |
| GZ_SIM_REGISTER_COMPONENT ("gz_sim_components.Model", Model) using ModelSdf | |
| A component that holds the model's SDF DOM. More... | |
| GZ_SIM_REGISTER_COMPONENT ("gz_sim_components.Performer", Performer) using PerformerRef | |
| This component contains the performer reference name. More... | |
| GZ_SIM_REGISTER_COMPONENT ("gz_sim_components.PhysicsCollisionDetector", PhysicsCollisionDetector) using PhysicsSolver | |
| The name of the solver to be used. The supported options will depend on the physics engine being used. More... | |
| GZ_SIM_REGISTER_COMPONENT ("gz_sim_components.Sensor", Sensor) using SensorTopic | |
| Name of the transport topic where a sensor is publishing its data. For sensors that publish on more than one topic, this will usually be the prefix common to all topics of that sensor. More... | |
| GZ_SIM_REGISTER_COMPONENT ("gz_sim_components.VisibilityFlags", VisibilityFlags) using VisibilityMask | |
| This component holds an entity's visibility mask (camera sensor entities) More... | |
| GZ_SIM_REGISTER_COMPONENT ("gz_sim_components.Visual", Visual) using VisualPlugin | |
| A component that contains a visual plugin's SDF element. More... | |
| GZ_SIM_REGISTER_COMPONENT ("gz_sim_components.World", World) using WorldSdf | |
| A component that holds the world's SDF DOM. More... | |
| GZ_SIM_REGISTER_COMPONENT ("gz_sim_components.WorldPose", WorldPose) using TrajectoryPose | |
| A component type that contains pose, gz::math::Pose3d, information within a trajectory. More... | |
The set of Components assigned to an Entity also act as a key. Systems process Entities based on their key. For example, a physics system may process only entities that have pose and inertia components.
Typedef Documentation
◆ Actor
| using Actor = Component<sdf::Actor, class ActorTag, serializers::ActorSerializer> |
◆ Actuators
| using Actuators = Component<msgs::Actuators, class ActuatorsTag, serializers::MsgSerializer> |
◆ AirPressureSensor
| using AirPressureSensor = Component<sdf::Sensor, class AirPressureSensorTag, serializers::SensorSerializer> |
◆ AirSpeedSensor
| using AirSpeedSensor = Component<sdf::Sensor, class AirSpeedSensorTag, serializers::SensorSerializer> |
◆ Altimeter
| using Altimeter = Component<sdf::Sensor, class AltimeterTag, serializers::SensorSerializer> |
◆ AngularAcceleration
| using AngularAcceleration = Component<math::Vector3d, class AngularAccelerationTag> |
◆ AngularVelocity
| using AngularVelocity = Component<math::Vector3d, class AngularVelocityTag> |
◆ AngularVelocityCmd
| using AngularVelocityCmd = Component<math::Vector3d, class AngularVelocityCmdTag> |
◆ Atmosphere
| using Atmosphere = Component<sdf::Atmosphere, class AtmosphereTag, serializers::AtmosphereSerializer> |
◆ AxisAlignedBox
| using AxisAlignedBox = Component<gz::math::AxisAlignedBox, class AxisAlignedBoxTag, serializers::AxisAlignedBoxSerializer> |
◆ BatteryPowerLoad
| using BatteryPowerLoad = Component<BatteryPowerLoadInfo, class BatteryPowerLoadTag> |
◆ BatterySoC
| using BatterySoC = Component<float, class BatterySoCTag> |
A component that identifies an entity as being a battery. Float value indicates state of charge.
◆ BoundingBoxCamera
| using BoundingBoxCamera = Component<sdf::Sensor, class BoundingBoxCameraTag, serializers::SensorSerializer> |
◆ Camera
| using Camera = Component<sdf::Sensor, class CameraTag, serializers::SensorSerializer> |
◆ CanonicalLink
| using CanonicalLink = Component<NoData, class CanonicalLinkTag> |
◆ CastShadows
| using CastShadows = Component<bool, class CastShadowsTag> |
◆ CenterOfVolume
| using CenterOfVolume = Component<math::Vector3d, class CenterOfVolumeTag> |
◆ ChildLinkName
| using ChildLinkName = Component<std::string, class ChildLinkNameTag, serializers::StringSerializer> |
◆ Collision
◆ ContactSensor
| using ContactSensor = Component<sdf::ElementPtr, class ContactSensorTag> |
◆ ContactSensorData
| using ContactSensorData = Component<msgs::Contacts, class ContactSensorDataTag, serializers::MsgSerializer> |
◆ CustomSensor
| using CustomSensor = Component<sdf::Sensor, class CustomSensorTag, serializers::SensorSerializer> |
◆ DepthCamera
| using DepthCamera = Component<sdf::Sensor, class DepthCameraTag, serializers::SensorSerializer> |
◆ DetachableJoint
| using DetachableJoint = Component<DetachableJointInfo, class DetachableJointTag, serializers::DetachableJointInfoSerializer> |
◆ Environment
| using Environment = Component<std::shared_ptr<EnvironmentalData>, class EnvironmentalDataTag> |
◆ ExternalWorldWrenchCmd
| using ExternalWorldWrenchCmd = Component<msgs::Wrench, class ExternalWorldWrenchCmdTag, serializers::MsgSerializer> |
◆ ForceTorque
| using ForceTorque = Component<sdf::Sensor, class ForceTorqueTag, serializers::SensorSerializer> |
◆ Geometry
| using Geometry = Component<sdf::Geometry, class GeometryTag, serializers::GeometrySerializer> |
◆ GpuLidar
| using GpuLidar = Component<sdf::Sensor, class GpuLidarTag, serializers::SensorSerializer> |
◆ Gravity
| using Gravity = Component<math::Vector3d, class GravityTag> |
◆ HaltMotion
| using HaltMotion = Component<bool, class HaltMotionTag> |
◆ Imu
| using Imu = Component<sdf::Sensor, class ImuTag, serializers::SensorSerializer> |
◆ Inertial
| using Inertial = Component<math::Inertiald, class InertialTag, serializers::InertialSerializer> |
◆ Joint
◆ JointAxis
| using JointAxis = Component<sdf::JointAxis, class JointAxisTag, serializers::JointAxisSerializer> |
◆ JointEffortLimitsCmd
| using JointEffortLimitsCmd = Component< std::vector<gz::math::Vector2d>, class JointEffortLimitsCmdTag, serializers::VectorSerializer<gz::math::Vector2d> > |
- Note
- It is expected that the physics plugin reads this component and sets the limit to the dynamics engine. After setting it, the data of this component will be cleared (i.e. the vector will have length zero).
◆ JointForce
| using JointForce = Component<std::vector<double>, class JointForceTag, serializers::VectorDoubleSerializer> |
◆ JointForceCmd
| using JointForceCmd = Component<std::vector<double>, class JointForceCmdTag> |
◆ JointPosition
| using JointPosition = Component<std::vector<double>, class JointPositionTag, serializers::VectorDoubleSerializer> |
◆ JointPositionLimitsCmd
| using JointPositionLimitsCmd = Component< std::vector<gz::math::Vector2d>, class JointPositionLimitsCmdTag, serializers::VectorSerializer<gz::math::Vector2d> > |
- Note
◆ JointPositionReset
| using JointPositionReset = Component<std::vector<double>, class JointPositionResetTag, serializers::VectorDoubleSerializer> |
◆ JointTransmittedWrench
| using JointTransmittedWrench = Component<msgs::Wrench, class JointTransmittedWrenchTag, serializers::MsgSerializer> |
- Note
- The term Wrench is used here to mean a pair of 3D vectors representing torque and force quantities expressed in a given frame and where the force is applied at the origin of the frame. This is different from the Wrench used in screw theory.
- The value of force_offset in msgs::Wrench is ignored for this component. The force is assumed to be applied at the origin of the joint frame.
◆ JointType
| using JointType = Component<sdf::JointType, class JointTypeTag, serializers::JointTypeSerializer> |
◆ JointVelocity
| using JointVelocity = Component<std::vector<double>, class JointVelocityTag, serializers::VectorDoubleSerializer> |
◆ JointVelocityCmd
| using JointVelocityCmd = Component<std::vector<double>, class JointVelocityCmdTag, serializers::VectorDoubleSerializer> |
◆ JointVelocityLimitsCmd
| using JointVelocityLimitsCmd = Component< std::vector<gz::math::Vector2d>, class JointVelocityLimitsCmdTag, serializers::VectorSerializer<gz::math::Vector2d> > |
- Note
◆ JointVelocityReset
| using JointVelocityReset = Component<std::vector<double>, class JointVelocityResetTag, serializers::VectorDoubleSerializer> |
◆ LaserRetro
| using LaserRetro = Component<double, class LaserRetroTag> |
◆ Level
◆ LevelBuffer
| using LevelBuffer = Component<double, class LevelBufferTag> |
◆ LevelEntityNames
| using LevelEntityNames = Component<std::set<std::string>, class LevelEntityNamesTag, serializers::LevelEntityNamesSerializer> |
◆ Lidar
| using Lidar = Component<sdf::Sensor, class LidarTag, serializers::SensorSerializer> |
◆ Light
| using Light = Component<sdf::Light, class LightTag, serializers::LightSerializer> |
◆ LightCmd
| using LightCmd = Component<gz::msgs::Light, class LightCmdTag, serializers::MsgSerializer> |
◆ LightType
| using LightType = Component<std::string, class LightTypeTag, serializers::StringSerializer> |
◆ LinearAcceleration
| using LinearAcceleration = Component<math::Vector3d, class LinearAccelerationTag> |
◆ LinearVelocity
| using LinearVelocity = Component<math::Vector3d, class LinearVelocityTag> |
◆ LinearVelocityCmd
| using LinearVelocityCmd = Component< math::Vector3d, class LinearVelocityCmdTag> |
entity represented by gz::math::Vector3d, expressed in the entity's frame.
◆ LinearVelocitySeed
| using LinearVelocitySeed = Component<math::Vector3d, class LinearVelocitySeedTag> |
◆ Link
◆ LogicalAudioSource
| using LogicalAudioSource = Component<logical_audio::Source, class LogicalAudioSourceTag, serializers::LogicalAudioSourceSerializer> |
◆ LogicalAudioSourcePlayInfo
| using LogicalAudioSourcePlayInfo = Component<logical_audio::SourcePlayInfo, class LogicalAudioSourcePlayInfoTag, serializers::LogicalAudioSourcePlayInfoSerializer> |
◆ LogicalCamera
| using LogicalCamera = Component<sdf::ElementPtr, class LogicalCameraTag> |
◆ LogicalMicrophone
| using LogicalMicrophone = Component<logical_audio::Microphone, class LogicalMicrophoneTag, serializers::LogicalMicrophoneSerializer> |
◆ LogPlaybackStatistics
| using LogPlaybackStatistics = Component<gz::msgs::LogPlaybackStatistics, class LogPlaybackStatisticsTag, serializers::MsgSerializer> |
◆ MagneticField
| using MagneticField = Component<math::Vector3d, class MagneticFieldTag> |
◆ Magnetometer
| using Magnetometer = Component<sdf::Sensor, class MagnetometerTag, serializers::SensorSerializer> |
◆ Material
| using Material = Component<sdf::Material, class MaterialTag, serializers::MaterialSerializer> |
◆ Model
◆ Name
| using Name = Component<std::string, class NameTag, serializers::StringSerializer> |
◆ NavSat
| using NavSat = Component<sdf::Sensor, class NavSatTag, serializers::SensorSerializer> |
◆ NoData
| using NoData = std::add_lvalue_reference<void> |
◆ ParentEntity
| using ParentEntity = Component<Entity, class ParentEntityTag> |
Note that the EntityComponentManager also keeps the parent-child relationship stored in a graph, and that information should be kept in sync with the parent entity components. Therefore, it is recommended that the ParentEntity component is never edited by hand, and instead, entities should be created using the sim::SdfEntityCreator class.
◆ ParentLinkName
| using ParentLinkName = Component<std::string, class ParentLinkNameTag, serializers::StringSerializer> |
◆ ParticleEmitter
| using ParticleEmitter = Component<msgs::ParticleEmitter, class ParticleEmitterTag, serializers::MsgSerializer> |
◆ Performer
◆ PerformerAffinity
| using PerformerAffinity = Component<std::string, class PerformerAffinityTag, serializers::StringSerializer> |
◆ PerformerLevels
| using PerformerLevels = Component<std::set<Entity>, class PerformerLevelsTag, serializers::PerformerLevelsSerializer> |
◆ Physics
| using Physics = Component<sdf::Physics, class PhysicsTag, serializers::PhysicsSerializer> |
◆ PhysicsCmd
| using PhysicsCmd = Component<msgs::Physics, class PhysicsCmdTag> |
◆ PhysicsEnginePlugin
| using PhysicsEnginePlugin = Component<std::string, class PhysicsEnginePluginTag, serializers::StringSerializer> |
◆ Pose
| using Pose = Component<gz::math::Pose3d, class PoseTag> |
◆ Projector
| using Projector = Component<sdf::Projector, class ProjectorTag, serializers::ProjectorSerializer> |
◆ Recreate
The GUI ModelEditor contains example code on how to use this component. For example, the ModelEditor allows a user to add a link to an existing model. The existing model is tagged with this component so that it can be recreated by the server.
◆ RenderEngineGuiPlugin
| using RenderEngineGuiPlugin = Component<std::string, class RenderEngineGuiPluginTag, serializers::StringSerializer> |
◆ RenderEngineServerHeadless
| using RenderEngineServerHeadless = Component<bool, class RenderEngineServerHeadlessTag> |
◆ RenderEngineServerPlugin
| using RenderEngineServerPlugin = Component<std::string, class RenderEngineServerPluginTag, serializers::StringSerializer> |
◆ RgbdCamera
| using RgbdCamera = Component<sdf::Sensor, class RgbdCameraTag, serializers::SensorSerializer> |
◆ Scene
| using Scene = Component<sdf::Scene, class SceneTag, serializers::SceneSerializer> |
◆ SegmentationCamera
| using SegmentationCamera = Component<sdf::Sensor, class SegmentationCameraTag, serializers::SensorSerializer> |
◆ SelfCollide
| using SelfCollide = Component<bool, class SelfCollideTag> |
◆ SemanticLabel
| using SemanticLabel = Component<uint32_t, class SemanticLabelTag> |
◆ Sensor
◆ SlipComplianceCmd
| using SlipComplianceCmd = Component<std::vector<double>, class SlipComplianceCmdTag> |
◆ SourceFilePath
| using SourceFilePath = Component<std::string, class SourceFilePathTag, serializers::StringSerializer> |
◆ SphericalCoordinates
| using SphericalCoordinates = Component<math::SphericalCoordinates, class SphericalCoordinatesTag, serializers::SphericalCoordinatesSerializer> |
◆ Static
◆ SystemPluginInfo
| using SystemPluginInfo = Component<msgs::Plugin_V, class SystemPluginInfoTag, serializers::MsgSerializer> |
◆ Temperature
| using Temperature = Component<math::Temperature, class TemperatureTag> |
◆ TemperatureRange
| using TemperatureRange = Component<TemperatureRangeInfo, class TemperatureRangeTag, serializers::TemperatureRangeInfoSerializer> |
◆ ThermalCamera
| using ThermalCamera = Component<sdf::Sensor, class ThermalCameraTag, serializers::SensorSerializer> |
◆ ThreadPitch
| using ThreadPitch = Component<double, class ThreadPitchTag> |
◆ Transparency
| using Transparency = Component<float, class TransparencyTag> |
◆ VisibilityFlags
| using VisibilityFlags = Component<uint32_t, class VisibilityFlagsTag> |
◆ Visual
◆ VisualCmd
| using VisualCmd = Component<gz::msgs::Visual, class VisualCmdTag, serializers::MsgSerializer> |
◆ Volume
◆ WheelSlipCmd
| using WheelSlipCmd = Component<gz::msgs::WheelSlipParametersCmd, class WheelSlipCmdTag, serializers::MsgSerializer> |
◆ WideAngleCamera
| using WideAngleCamera = Component<sdf::Sensor, class WideAngleCameraTag, serializers::SensorSerializer> |
◆ Wind
◆ WindMode
◆ World
◆ WorldPoseCmd
| using WorldPoseCmd = Component<math::Pose3d, class WorldPoseCmdTag> |
Function Documentation
◆ GZ_SIM_REGISTER_COMPONENT() [1/14]
| GZ_SIM_REGISTER_COMPONENT | ( | "gz_sim_components.Actor" | , |
| Actor | |||
A component that stores temperature linear resolution in Kelvin.
A component type that contains pose, gz::math::Pose3d, information in world frame.
The name of the collision detector to be used. The supported options will depend on the physics engine being used.
A component that contains a particle emitter command.
A component type that contains linear velocity seed of an entity in the world frame represented by gz::math::Vector3d. This seed can used to generate linear velocities by applying transformations and adding noise.
A component type that contains the commanded linear velocity of an entity represented by gz::math::Vector3d, expressed in the world frame.
A component type that contains linear velocity of an entity in the world frame represented by gz::math::Vector3d.
A component type that contains linear acceleration of an entity in the world frame represented by gz::math::Vector3d.
A component that contains the second joint axis for joints with two axes. This is a simple wrapper around sdf::JointAxis.
A component type that contains the commanded angular velocity of an entity in the world frame represented by gz::math::Vector3d.
A component type that contains angular velocity of an entity in the world frame represented by gz::math::Vector3d.
A component type that contains angular acceleration of an entity in the world frame represented by gz::math::Vector3d.
◆ GZ_SIM_REGISTER_COMPONENT() [2/14]
| gz::sim::components::GZ_SIM_REGISTER_COMPONENT | ( | "gz_sim_components.AnimationTime" | , |
| AnimationTime | |||
◆ GZ_SIM_REGISTER_COMPONENT() [3/14]
| gz::sim::components::GZ_SIM_REGISTER_COMPONENT | ( | "gz_sim_components.CanonicalLink" | , |
| CanonicalLink | |||
◆ GZ_SIM_REGISTER_COMPONENT() [4/14]
| gz::sim::components::GZ_SIM_REGISTER_COMPONENT | ( | "gz_sim_components.Collision" | , |
| Collision | |||
◆ GZ_SIM_REGISTER_COMPONENT() [5/14]
| gz::sim::components::GZ_SIM_REGISTER_COMPONENT | ( | "gz_sim_components.CollisionElement" | , |
| CollisionElement | |||
◆ GZ_SIM_REGISTER_COMPONENT() [6/14]
| gz::sim::components::GZ_SIM_REGISTER_COMPONENT | ( | "gz_sim_components.Level" | , |
| Level | |||
◆ GZ_SIM_REGISTER_COMPONENT() [7/14]
| gz::sim::components::GZ_SIM_REGISTER_COMPONENT | ( | "gz_sim_components.Model" | , |
| Model | |||
◆ GZ_SIM_REGISTER_COMPONENT() [8/14]
| gz::sim::components::GZ_SIM_REGISTER_COMPONENT | ( | "gz_sim_components.Performer" | , |
| Performer | |||
◆ GZ_SIM_REGISTER_COMPONENT() [9/14]
| gz::sim::components::GZ_SIM_REGISTER_COMPONENT | ( | "gz_sim_components.PhysicsCollisionDetector" | , |
| PhysicsCollisionDetector | |||
◆ GZ_SIM_REGISTER_COMPONENT() [10/14]
| gz::sim::components::GZ_SIM_REGISTER_COMPONENT | ( | "gz_sim_components.Sensor" | , |
| Sensor | |||
◆ GZ_SIM_REGISTER_COMPONENT() [11/14]
| gz::sim::components::GZ_SIM_REGISTER_COMPONENT | ( | "gz_sim_components.VisibilityFlags" | , |
| VisibilityFlags | |||
◆ GZ_SIM_REGISTER_COMPONENT() [12/14]
| gz::sim::components::GZ_SIM_REGISTER_COMPONENT | ( | "gz_sim_components.Visual" | , |
| Visual | |||
◆ GZ_SIM_REGISTER_COMPONENT() [13/14]
| gz::sim::components::GZ_SIM_REGISTER_COMPONENT | ( | "gz_sim_components.World" | , |
| World | |||
◆ GZ_SIM_REGISTER_COMPONENT() [14/14]
| gz::sim::components::GZ_SIM_REGISTER_COMPONENT | ( | "gz_sim_components.WorldPose" | , |
| WorldPose | |||
