BaseComponent Class Referenceabstract
Base class for all components. More...
#include <Component.hh>
 BaseComponent ()=default
 Default constructor. More...
virtual ~BaseComponent ()=default
 Default destructor. More...
virtual std::unique_ptr< BaseComponent > Clone () const =0
 Clone the component. More...
virtual void Deserialize (std::istream &_in)
 Fills a component based on a stream with a serialized data. By default, it will do nothing. Derived classes should override this function to support deserialization. More...
virtual void Serialize (std::ostream &_out) const
 Fills a stream with a serialized version of the component. By default, it will leave the stream empty. Derived classes should override this function to support serialization. More...
virtual ComponentTypeId TypeId () const =0
 Returns the unique ID for the component's type. The ID is derived from the name that is manually chosen during the Factory registration and is guaranteed to be the same across compilers and runs. More...
◆ BaseComponent()
BaseComponent ( )
default
◆ ~BaseComponent()
virtual ~BaseComponent ( )
virtualdefault
Default destructor.
◆ Clone()
virtual std::unique_ptr<BaseComponent> Clone ( ) const
A pointer to the component.
Implemented in Component< NoData, Identifier, Serializer >, and Component< DataType, Identifier, Serializer >.
◆ Deserialize()
virtual void Deserialize ( std::istream &  _in)
inlinevirtual
[in]_inIn stream.
Reimplemented in Component< NoData, Identifier, Serializer >, and Component< DataType, Identifier, Serializer >.
References std::endl(), gzwarn, and BaseComponent::TypeId().
◆ Serialize()
virtual void Serialize ( std::ostream &  _out) const
inlinevirtual
[in]_outOut stream.
◆ TypeId()
virtual ComponentTypeId TypeId ( ) const
Referenced by BaseComponent::Deserialize(), Factory::New(), and BaseComponent::Serialize().
