#include <Component.hh>
| std::unique_ptr< BaseComponent > | Clone () const override |
| Clone the component. More... | |
| void | Deserialize (std::istream &_in) override |
| Fills a component based on a stream with a serialized data. By default, it will do nothing. Derived classes should override this function to support deserialization. More... | |
| bool | operator!= (const Component< NoData, Identifier, Serializer > &_component) const |
| Components with no data are always equal to another instance of the same type. More... | |
| bool | operator== (const Component< NoData, Identifier, Serializer > &_component) const |
| void | Serialize (std::ostream &_out) const override |
| Fills a stream with a serialized version of the component. By default, it will leave the stream empty. Derived classes should override this function to support serialization. More... | |
| ComponentTypeId | TypeId () const override |
| Returns the unique ID for the component's type. The ID is derived from the name that is manually chosen during the Factory registration and is guaranteed to be the same across compilers and runs. More... | |
Public Member Functions inherited from BaseComponent | |
| BaseComponent ()=default | |
| Default constructor. More... | |
| virtual | ~BaseComponent ()=default |
| Default destructor. More... | |
Static Public Attributes | |
| static ComponentTypeId | typeId {0} |
| Unique ID for this component type. This is set through the Factory registration. More... | |
| static std::string | typeName |
| Unique name for this component type. This is set through the Factory registration. More... | |
template<typename Identifier, typename Serializer>
class gz::sim::components::Component< NoData, Identifier, Serializer >
using Joint = Component<NoData, class JointTag>;
◆ Clone()
overridevirtual |
◆ Deserialize()
overridevirtual |
[in] _in In stream.
Reimplemented from BaseComponent.
◆ operator!=()
[in] _component Component to compare to
- Returns
- False.
◆ operator==()
- Returns
- True.
◆ Serialize()
overridevirtual |
[in] _out Out stream.
◆ TypeId()
overridevirtual |
Implements BaseComponent.
References Component< DataType, Identifier, Serializer >::typeId.
◆ typeId
inlinestatic |
◆ typeName
inlinestatic |
